Question about Black & Decker SK300 Deep Dutch Electric Skillet
Need a new temp control plug part # 177073-00
Air conditioner blows heat, conditioner was charged, freon, checked relay switch, fuse, door blend alol fine still hot air, was told maybe a block in V shape hose is it temp control value Help
Only way to tell if A/C Evaporator Core Orifice tube is plugged is by looking at A/C gauge readings , An if it is plugged you more then likely need a new compressor , they become plugged with metal particles from worn out compressor. Your best bet would be to take your vehicle to a qualified repair shop .
Jun 27, 2016 | 1998 Lincoln Navigator
No cool
TURN THE TEMP CONTROL DOWN. These don't work very well if set above "9". unplug for a while set temp control to off, make sure all ice is removed from freezer, plug back in and set temp control to about 7 - 8. These are primarily sold at home depot and cost very little ( $318.00 for the new model Vissani ). If it is less than 1 year old it is still under warranty from magic chef. If less than 5 years old the compressor is probably covered but you will have to pay labor, It is probably cheaper to buy a new one.
Feb 01, 2014 | Refrigerators
Johnson Controls A419ABG-3C problems
Which thermostat, the one in the freezer, or the one with the new control? Is the new control just supposed to turn the freezer off and on at set temps, or does it do anything else?
Dec 01, 2013 | Johnson Controls A419ABG-3C Pre Wired Temp...
I have a GE Range that has started acting up. it was working fine at 350, i had to have a temp of 425 and the temp went soaring to broil. the oven control knob would not turn the oven off, i had to pull...
Yes, most likely the broil relay got welded shut. The company will want to sell you a whole new control board for about $200.00 -- but if you have any soldering skills, you can purchase a new replay for around $6.50.
Feb 17, 2018 | GE JGBS20 Gas Kitchen Range
Heater blows cold air
may need a new thermostat or just low on coolant
Dec 22, 2010 | Buick Regal Cars & Trucks
Glow plug controler clicks on and off really fast , new glow plugs and controler are installed
Sounds like the temp sensor that is tied into cycling the glow plugs is sensing incorectly.
Feb 04, 2010 | 1990 Ford F350
Jandy aqualin rs air temp malfunction
Check this by swapping your air sensor with your water sensor. (Just swap the plugs) if it still reads off then you may need a new board, if this reads ok then the new sensor may be bad. Good luck.
Jan 06, 2010 | Jandy Aqualink Rs4 One Touch Control...
Whirlpool Range Error code F1 F3
Unplug the range.
Remove the rear panel to access the temp probe.
Unplug the temp probe and test for 1100 ohms.
Test the temp probe to ground also.
Sometimes the connectors are bad.and must be direct wired.
Unplug and re-plug the ribbon connector to the ERC.
F-1 is a connection problem since you have a new control.
Mar 14, 2009 | Kitchen Ranges
Black & Decker SK300 Deep Dutch Electric Skillet Logo
51 people viewed this question
Top Black & Decker Kitchen Appliances - Others Experts
Irene Tulloch
Gerry Harvey
Gerry Harvey
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
