Question about Mitsubishi VS-45607 45" Rear Projection Television
Warped picture picture is warped
  • Mitsubishi Master
  • 3,459 Answers
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com
and do the repair yourself. Its a fairly easy DIY fix.
Posted on Mar 09, 2012
  • 927 Answers
Good Day, jamelpp;
Sounds like the warped picture may be caused by the convergence output IC's, but try this first:
E2RESET DOES NOT RESET THE CONVERGENCE. THE CONVERGENCE CAN BE RESET BY PRESSING "MENU 12598970", IF THIS DOES NOT RESET THE CONVERGENCE TRY "MENU 125968970"
Good Luck, big IRISH.
Posted on Jul 31, 2008
PHILIPS 51pp9100d/37, picture is warped ? where do I get the parts i need to fix it ?
If it looks like attached photos it needs both of the convergence IC chips replaced. They should be stk=392=120 OR a few models used the -110 chip.
below is what the parts look like
Jun 15, 2012 | Philips 51PP9100D 51 in. Television
Monoscope signal how to get it Mitsubishi VS-6043 rear tring to adjust the picture its all warped looking got tv out of ditch tring to make it work
does the convergence align or move? how is the picture distorted? if the picture aligns but is just warped, use a jig or some string to have some straight lines to reference for your geometry and convergence. the monoscope signal is hard to find and mits had it on a vhs tape back in the day. it really just helped you get the horizontal and vertical size and get a round circle to fix the warp.. just try to make all the grid points about the same distance apart and make it an even grid.
May 26, 2010 | Mitsubishi VS-6043 60" Rear Projection...
Picture is warped, colors are off.
The ITC222 and ITC222A convergence option missing repair kit should repair that issue. You can get the kit at www.tvrepairworld.com which contains the parts and the CD with instructions its 24.95
Oct 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Gost picture
warped with ghost....is that the same as 3d with bowed picture? might be convergence problems. does your autoconvegence work?
Sep 28, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My Mithsubishi HD-1080 rear projection tv 65 picture warps and distorted when first turned on.
sounds like your convergence ICs are getting weak, or the solder may need to be touched up.
Apr 06, 2008 | Mitsubishi WS-65513 65" Rear Projection...
HCL 4715W Factory Picture Settings Needed
warped screen top & bottom...color convergence? hee haa . move some but so what it's warped...must be an easy solution. any help i'll take it 2002 model....thanks
Aug 28, 2007 | Samsung HCL4715W 47" Rear Projection...
61 inch proj. warped concave picture.
Josh Any chance you could send a photo... Too many ideas come to mind from what you've described. Would actually have to see the "warp" in the picture itself to see if it's one or all colors, any boarders and if the bend is actually pulling from top or bottom.. Bill premtech@willapabay.org
Jun 14, 2007 | RCA P61960 61" Rear Projection Television
Mitsubishi VS-45607 45" Rear Projection Television Logo
147 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
