Question about HP Scanjet 5470c Flatbed Scanner
HP 5470c scanner
I have a HP 5470c scanner that has worked like a charm. I just had my computer checked and had to disconnect my scanner. When I tried to set up again I am getting no power at all. The software is installed, but I am receiving no power. I have tried to reach them to see about buying a new cord to no avail. Anyone have any suggestions as to where I can obtain a new cord or another suggestion as to how to get this working again. It was fine before I disconnected. I have tried three different outlets and nothing happens.
Thanks
First of all, use a lamp, fan or something to check your electrical outlets. Make sure they are not on a switched circuit, or a power strip that may be turned off. Try unplugging the cord from the scanner and re-inserting it. I don't know if there is a fuse inside the 5470, but I would bet on it. If all else fails and you feel competent to try it, see if you can disassemble the bottom and look for the fuse. Usually sudden problems like this are really something simple (or catastrophic!! :-) Good luck, John
Posted on Jun 04, 2008
What leads to connect scanjet 5470c scanner
First, a power adapter is required to connect your scanner. the power adapter must be supplied with the scanner. If your scanjet 5470c scanner is having USB interface or connectivity, then you need USB cable and if it is SCSI interface, then you need SCSi cable to connect to your PC. The cables are usually be supplied with the scanner. If lost, you may have purchase teh same. For further assistance, please visit the following link:
http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&prodTypeId=15179&prodSeriesId=28456&taskId=115
Hope the above information is helpful.
Thanks,
ScanCare
Jun 25, 2012 | HP Office Equipment & Supplies
Driver for 5470c scanner will not work with windows 7
Hi ,
Scanjet 5470c does'nt work under W 7 . No drivers available .
Here are a few hints :
1° hint :
Do not connect scanner .
Load XP driver ( yes , XP) , reboot , connect scanner and wait for confirmation of successfull operation .
Reboot .
Dowload and install FreeKapture ( yes , it's free ) from http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html
Open Freekapture , clic on Scan and select WIA-Hewlett-Packard . Scanjet 4470c works fine in this mode but if you choose HP PrecisionScan Pro , program will hang .
In any case , no slides or negatives scans possible but the rest works .
2° hint :
If you have the W XP install disc , you could install a virtual version of W XP on your HDD ( http://downloads.vmware.com/d/info/desktop_downloads/vmware_player/3_0 ) You could also partition your HDD ( http://www.partitionwizard.com/free-partition-manager.html ) and install W XP on the new one . Regards .
Jan 06, 2011 | HP Scanjet 5470c Flatbed Scanner
My hp scanjet 5470c has worked fine in the past, now after wanting to use it again, it won't power up at all. I know my connections from the wall to my scanner are good?????
Dec 30, 2009 | HP Scanjet 5470c Flatbed Scanner
64 bit driver for HP 5470c scanner
Dear go to www.hp.com click on support and drivers then enter your product model now you choose your operating system and download driver free.
First install its software or driver only then you should attach your scanner (when your computer demand or required for its attachment).
Good Luck
Aug 13, 2009 | HP Scanjet 5470c Flatbed Scanner
HP Scanjet 5470c xpa negative scanner not lighting up
as my friends answer, the xpa will light up when the software related to scan negative is run
May 02, 2009 | HP Scanjet 5470c Flatbed Scanner
Original hp scanjet 5470c software disc won't work; need new
have u contact hp in u'r region? maybe they have the cd..
Mar 30, 2009 | HP Scanjet 5470c Flatbed Scanner
HOW TO CONNECT SCANJET 5470c to computer
Hope you have a hp 5400 software CD which will install the programme of the scanner to your PC. Once this is done then you will be able to connect and operate your scanner with PC.Your PC should have a USB port to connect the scanner with it.
Ajit bhutani
May 20, 2008 | HP Scanjet 5470c Flatbed Scanner
Solid background tint
I bought a power supply from ebay paid $22 with shipping thought it was better than getting a new scanner.
Screen is all Green and resolution is 72 no matter what the settings.
I guess it is time for a new scanner.
Dec 25, 2007 | HP Scanjet 5470c Flatbed Scanner
HP Scanjet 5470c Flatbed Scanner Logo
164 people viewed this question
Ben Johnson
