Question about Boss Rc 50
How do I delete the first five pre sets - Boss Rc 50
Http://www.bossus.com/backstage/product_manuals/?group=2
» Button SYSTEM/USB
» Right arrow until "Sys:PresetProtct" is showed
» Rotate the knob to the left to set it off
» Press biutton WRITE
Posted on Dec 22, 2010
My Ibanez acoustic electric has very weak volume and makes a constant white noise hiss when plugged into an amp or sound system. Batteries are new as is the pre-amp and under saddle piezo. Ideas?
It will be either the saddle pickup or the guitar pre amp. If you unplug the pickup and the hiss is gone, there was your fault. Otherwise fit a known good pre amp.
Feb 02, 2017 | Ibanez Music
Tip
How to Set up Auxiliaries on a Mixer.
Here are some tips to set up the auxiliaries properly on your mixer:
  • Step1:
Your auxiliaries allow you to send the signal from a channel strip to somewhere else while maintaining the signal on the channel strip. For instance, you can use auxiliaries for monitor mixes for performers in a live environment. You can also use auxiliaries for external effects processors or a number of different situations.
  • Step2:
Set the auxiliaries to pre-fader to allow you to change the level for the auxiliary with the auxiliary knob but not with the channel fader. Most mixers have a "Pre" button that allows you to enable pre-fader mode. If you don't have the button pressed, your auxiliaries are in post-fader mode, which means your channel fader will affect the signal level of the auxiliary output. For monitor mixes, you usually want to use pre-fader so you can control monitor mixes independently from the front of house mix. Some effects processors will be better to run post-fader, though, so don't always rely on pre-fader.
  • Step3:
Send out your auxiliary sends. On the back of your board, you there are the auxiliary outputs. For a monitor mix, you will use these outputs to connect to the inputs of the monitors. When using an effects processor, you will use the auxiliary output to connect to the input of the effects processor.
  • Step4:
Plug in a return if necessary. If you are just doing monitors, you do not need returns to the mixer. When using effects processors though, you need a way to get your effected signal back to your mixer. Take the output of the effects processor and connect that to the return input on the back of the mixer. Now you will have to adjust the return section on your channel strip to get the desired signal.
  • Step5:
Use the auxiliary knob to set the desired level. Once you know if you are running pre- or post-fader, and you have your inputs and outputs all correct, you can start sending signal to your auxiliary output. Turn up the auxiliary knob until either your monitors are set correctly or until you have the desired amount of signal going to your effects processor or other outboard equipment.
on Aug 07, 2008 | Yamaha Mg102c Stereo Mixer
Why does my fuse blow out when i turn the amp on?
sounds like you have a dead short internally and unless you find and fix it will continue to blow fuses .
Aug 02, 2015 | SWR La15 Bass Combo Amplifier
Facktory reset my casio ctk-491 keyboard, no sound from speakers
No sounds from speakers.
It may cause by power amp (or pre-amp) inside the CTK is defects.
Or maybe the setting for LOCAL in global mode is set to OFF.
Set it to ON.
Mar 02, 2015 | Casio Music
Free advise for casio keyboard no sound
It may cause by power amp (or pre-amp) inside the Casio is defects.
Set it to ON.
What is the pre out used for
PRE OUT/PWR IN - (1) Effects Loop - Connect PRE OUT to an effects device input, then connect the effects device output to PWR IN. (2) Multiple Amps - Connect the primary unit's PRE OUT to the auxiliary unit's PWR IN. The primary unit is used to control all auxiliary units. (3) Recording or Reinforcement - Connect PRE OUT to sound equipment's input. Both jacks use a TS (Tip-Sleeve) standard type plug for connections. PRE OUT includes onboard tone shaping.
Sep 22, 2013 | Fender Frontman 212R 100W 2x12 Guitar...
My pre amp is loud when it's mixted is this a tube
This unit has a lot of gain. It is probably normal. It is important to balance the inout gain and master gains of guitar amps. Not too high a setting for either.
Feb 06, 2011 | Fender Hot Rod Deluxe Guitar Combo...
Radio switches off automatically every five minutes
Press the power button repeatedly as you turn it on to set the snooze mode, or change back to perpetually on.
Apr 19, 2010 | Digi-Tech Digitech Vocalist Live 4...
I'm looking to get the pre-set patterns to play on my Korg DDD-5
A demo on YouTube shows the owner pressing one of the buttons on the left side to select possibly a bank as well as the start.. I could NOT find a manual online to download.
Jan 09, 2010 | Korg Ma30
Bought a used dtxpress set pre-pogrammed.
The info is on pg.35 of the drum owners manual at http://www.dtxperience.com/dox/dtxp4_en_om_b0.pdf. Hope this helps.
May 11, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
Boss Rc 50 Logo
113 people viewed this question
Top Boss Music Experts
Matthew Spark
Matthew Spark
shaun taylor
Darial Jr Lasaria
Darial Jr Lasaria
Are you a Boss Music Expert? Answer questions, earn points and help others
