Question about Master Lock 1 12" Weatherproof Padlock
MASTERLOCK 175 WONT CLOSE - Master Lock 1 12" Weatherproof Padlock
I have a similar weatherproof lock (different brand) that has the same problem. Remove the key. Line up the end of the u-shaped part with its hole, and put the u-shaped part against a surface that will not give (like the garage door frame, in my case). Hit the bottom as hard as you can with your hand. I had to do this more than once, but it did eventually lock.
I've locked and unlocked it only 2 or 3 times since it became hard to close (I had it for years without incident). The above is only a temporary solution.
Posted on Jan 06, 2011
  • Cosmo Kenyon
    Cosmo Kenyon Sep 16, 2012
    thanks for the quick response but iv tried that. iv tried spraying it and with penetrating oil and hitting all sides if the lock including the u shape part.
I need schematic diagram barako 175
Hi, Gladys there is absolutely nothing out there in cyber world for free or to buy but I did manage to find a Kawasaki KE175 diagram that should be close to the Barako you need a service manual it has a wiring diagram you can try the forums below also for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Kawasaki Motorcycle Wiring Diagrams
Kawasaki Barako 175 Service Manual
barako 175 wiring diagram Google Search
barako 175 harness diagram
http://www.symbianize.com/showthread.php?t=509203
Oct 19, 2016 | Motorcycles
LOST COMBO TO MASTERLOCK BOX
Contact Master Lock with proof of ownership for information.
Dec 12, 2012 | Master Lock Door Security Bar Masterlock...
I got the master lock speed dial combination lock but forgot my combination and it won't open. can somebody please tell me if i can reset the password?
1. Contact Masterlock.com and fill out the form, get it notarized and send it in for the combination to unlock it based on the S/N which is on the lock.(http://www.masterlock.com/faq/LostCombinations/). Good luck on this since Masterlock will end up finding something that will prevent them from giving you the combination. Its quite frustrating and NOT worth the trouble.
2. Go to home depot. Buy a 24in bolt cutter ($22) cut the stem of the lock. and replace with a new lock that you can buy from home depot for $ 29.00. If you have a key that is inside the lock box that you really need, You will now need to drill out the combinations piece by piece and the door will pop open or send the lock back to Masterlock. They will retrieve the key for you and send it back.
Aug 27, 2012 | Master Lock 5400d: Portable Select Access...
I have a 175D combination lock. I recently changed the combination # and it worked in the morning and now does not close. Iv'e tried changing the combination but mstill won't close?
I hate to say this, because Masterlock makes a fine product: It sounds like something inside the wheel assembly is broken. If it's still under warranty, send it to Mster Lock for a replacement. If not, replace it with a Corbin Sesame. Corbin originated the design, and they've been making the lock for several decades, now.
Dec 09, 2010 | Master Lock 5400d: Portable Select Access...
Master Lock 5400D Key Storage Combination Lock box i reset it combination a couple of days ago and it worked fine until today. Now it won't open with the new combination. How can I get in to it without...
Two solutions: (if the box is closed and it is attached to something)
Jun 25, 2010 | Master Lock 5400d: Portable Select Access...
I want to change my Master Lock combination
open the shackle twist 180 degrees...shut it as if u were closing it into the locking device..hold it down, put in what ur new combination is..pull the shackle up and shut it into locking device, and test it out.
Jan 25, 2009 | Master Lock 5400d: Portable Select Access...
Master Lock 1 12" Weatherproof Padlock Logo
1,026 people viewed this question
Top Master Lock Boating Experts
Mike
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Master Lock Boating Expert? Answer questions, earn points and help others
