Question about GE Refrigerators
Ice maker won't shut off ge gss25qgpe bb - GE Refrigerators
  • 2,272 Answers
Find the water valve behind the ice maker unit.Remove and check that valve.If its getting short then replace the valve.If not then get the valve reconnected.
  • The icemaker won't stop and is proceeding to fill the freezer with ice. The shut off linkage or switch has failed.
Try this; remove the front cover off the icemaker. On the front of the icemaker you should see holes marked with letters. Make a jumper wire about six inches long skin it about ½ inch on each end (make sure the wire is well insulated). Place one end of the wire in the hole marked L and the other in the hole marked V. This should energize the water valve and run water. Once the water starts running pull the jumper wire out, the water should stop when you pull the wire out. If the water continues to run after you remove the jumper wire the water valve is bad. If the water stops when you pull the wire out, repeat the test. If the water stops each time you remove the wire the motor module is bad.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Sep 01, 2010
I have a MN - TFX24PRXB - BB GE Side by side refrigerator. The Ice maker does not make ice anymore. I have tested the water valve and it is working. If I turn the gears it will start the process to...
Check for freezer temp - if it is not 10 degrees or below the ice maker thermostat will not turn the ice maker cycle on by removing the frozen ice in tray and then refilling it for next dump cycle. And if freezer temp is high you may have leaking door gasket, dirty condenser coils, improperly operating self defroster which raises temps, low refrigerant.
Aug 04, 2017 | GE Refrigerators
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
GE GSH25JFTA BB water dispenser not working but ice cube maker working fine
Ice maker is working. Water dispenser is not working. I did the initial diagnosis and the water line is not frozen. How do I replace the water valve or is that the right next step?
Jan 05, 2012 | GE GSH25JSTSS Stainless Steel Side by Side...
GE TFX24E side by side refrigerator, ice maker won't fill with water.
Hi, I have a GE TFX24E refrigerator. The ice maker is not filling with water. I replaced teh water valve with no joy. If I pour a cup of water into the dispenser the ice maker will freeze and harvest the ice. Any ideas? Is there a replaceable water fill sensor?
Sep 03, 2011 | GE WR30X10093 Refrigerator Icemaker Kit
GE modle GSS22JET BB\ice maker water supply continues to drip
You will need to turn the water supply off to refrigerator and pull away from wall and then take the paper cover off cover the compreesor area. Take the old and defectice water control valve off and Click Here=> WR57X10050 There are two sides, one for ice maker and the other for the water dispenser. Wiring will only go on correct connection. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Mar 18, 2010 | GE Refrigerators
Very Loud Ice Maker in GE gfss6kkxs Fridge
Sorry to inform you but GE refrigerators are known for their noise making machines. I myself have a GE Profile side by side but will never own another GE product. After repairing appliances GE is better priced than their competition and the reason cheaper made product. Sometimes cheaper doesn't mean better. Outside looks really good but what you don't see is ugly. BB
Jan 20, 2010 | GE Refrigerators
Ice maker on GE refrigerator model TBX21C1 BRRWW will not stop making ice cubes even when the shut off arm is in the raise position
You have a stuck micro switch in the ice maker. Try taking out the maker and remove the metal plate 4 screws and you will see the switch that work on a cam rod. I believe you will find your problem. BB
Dec 15, 2009 | GE Refrigerators
Ice maker not working
The solenoid on the back is not working or the ice maker is not calling for water.(check the solenoid first)
Jan 15, 2009 | GE Refrigerators
Water dispenser not working but ice maker does
The water line freezes inside the freezer door. There is now an add-on water line heater you can install to thaw the line.
Mar 01, 2008 | GE 24.6 cu. ft. Side-By-Side Refrigerator...
Refrigerators Logo
126 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
