Question about HP Photosmart C7180 All-In-One InkJet Printer
Printhead replacement Hp c7180
How do you replace the printheads on an HP C7180.
  • dhcopp Jun 05, 2008
    Color printouts have streaky and weak magenta. Need a new cart? Wrong. Two new carts did not fix the problem. We asked for email support and followed the directions to the letter.
    I strongly suspect that the printhead itself is dirty. How can I get at it? Is there a maintenance manual?  Thanks -- David
SOURCE: printhead replacement
I don't just change the printheads, go to utilities and recover printheads.
If all printheads are playing up, che3ck the magenta cleaner, if it's over full it can cause all printheads to fail, this info was taken from a page on the HP web page, but ?I can't remeber where.
Posted on May 27, 2008
yooperbud
  • 8637 Answers
SOURCE: Printhead replaced; still says yellow is empty
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 27, 2009
SOURCE: HP D135 - replaced printhead - still doesn't print in that color
try this link : I followed the directions and fixed the problem. the instructions that came with the new printhead weren't really complete.
Here's essentially all I did for my fix - Opened the printer top, turned the printer off. Removed the "bad" printhead, cleaned the metal contacts on the printhead and printer with windex. Closed the printer. Turned it on. waited for it to reset. Opened the printer. Turned the printer off again. Installed the printhead. Closed the lid. Plugged the printer in again. When it was ready I accessed the HP toolbox and alligned the printheads and cleaned the printheads. It worked. Here's a link with photos.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa02107&lc=en&cc=ca&dlc=&product=64986
Posted on May 01, 2009
komguy
  • 2306 Answers
SOURCE: Replaced HP 88 Printheads, still receive same
You either got a defective printhead or you are using generic inks, HP got real smart and added chemicals to their ink, if the printer doesn't see the right chemical makeup it will give that error and you need to flush the printhead and the pump and hoses with HP ink or the error will stay.
Posted on Jan 13, 2010
  • 103 Answers
SOURCE: How to put in new printheads to HP Photosmart Pro B 8190
Open the front cover of the printer and replace the catridges. For more info, download the manual for the same from the vendor website.
Revert back for more assistance.
Posted on Jan 28, 2010
Hp 7180 foutcode 0xc 18a0201
http://h30434.www3.hp.com/t5/Ink-Toner-Cartridge-Printhead-Issues/Printer-Ink-System-Failure-on-Photosmart-C7180-with-a-MAC/td-p/1220499
Feb 11, 2015 | HP Photosmart C7180 All-In-One InkJet...
How to remove printhead ?
Printhead is typically part of the ink cart on HP printers. Replace ink cart, get a new printhead.
Sep 01, 2014 | HP Photosmart C7180 All-In-One InkJet...
CAN I REMOVE/REPLACE PRINTHEAD FOR PHOTOSMART C7180?
no printheads are not removable in photosmart c7180 , thats why its not visible.. the printhead and the ink cartridge are attached.
Oct 25, 2012 | HP Photosmart C7180 All-In-One InkJet...
HP Photosmart C7180 printer with clogged print head.
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required. Also try - Removing the print head, run it under hot water for 2 mins, then let soak for 10 min. then used a can of compressed air to dry thoroughly. It may fix the blocked nozzles.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Aug 30, 2012 | HP Photosmart C7180 All-In-One InkJet...
The pink and magenta cartridges won't print. We have replaced them again thinking the cartridges were faulty, but still we just get yellow print. HP Photosmart C7280 All-in_One
Sounds like you need to run a printhead cleaning cycle. Dried inks can block nozzles - if they're blocked no amount of cartridge changing will make them work.
www.inksave.co.uk
Feb 11, 2011 | HP Photosmart C7180 All-In-One InkJet...
Photosmart C7180 - light magenta and magenta not printing. I've cleaned the heads and aligned the printer. The light magenta is printing when I did the 'Align Printer'. I also completed the 'Restore...
The following may work: remove all the ink supplies. Remove the printhead and soak it for about 5 minutes in 0.5" of very hot water. Gently blot the printhead on a soft damp paper towel to remove the excess water, then replace in the printer and then reinstall the ink supplies.
Dec 23, 2010 | HP Photosmart C7180 All-In-One InkJet...
INK CARTRIDGES ARE LEAKING IN HP PHOTOSMART PRINTER
Follow the instructions below to replace the printheads in the All-in-One product.
Video of replacing the printhead
The following video demonstrates how to replace the cartridges and the printhead. You do not necessarily need to replace the cartridges. Simply refer to the video for replacing the printhead, and then stop the video.
Aug 23, 2010 | HP Photosmart C7180 All-In-One InkJet...
HP C718 Yellow print cartridge showing cartridge empty or damaged. Tried two new HP cartridges, Cleaned printheads and exhausted HP online and telephone support without success. On inspection it looks as...
If one of the contact pins in the printer is damaged you will need to replace your printer. I don't think it is a problem with the cartridge because it is highly unlikely that you would get three HP cartridges in a row with damaged chips on the cartridges.
Jun 05, 2009 | HP Photosmart C7180 All-In-One InkJet...
HP Photosmart C7180 All-In-One InkJet Printer Logo
1,825 people viewed this question
Ben Johnson
