Question about Sharp 25N-S100 25" TV
I have a Sharp 25N-S100 25" Color TV. I am going to repair a broken 75Ohm RF/Cable connector and need to know the procedure for removing the back panel. Looks like the rear A/V connections are integrated into the back panel and not part of a seperate, removable plate.
  • 7 Answers
If they are integrated they are probably connected with a flat cable to the mainboard of the set.
unplug this and you can remove the rear cover.
Posted on Sep 01, 2010
1996 sharp tv model # 25H-M60 co-ax pulled out from the circurt board. I removed the back of the tv,and can see the female end is snap off the case that houses the board. Can i solder that back to the...
That is what the service provider would do if you took the television in to be repaired. The service provider would attempt to solder the rf connector back to the television or solder a new rf connector to the television.
Mar 29, 2011 | Sharp 19H-M60 TV
How to change the color options on my Sharp TV. I fiddled with them somehow and dont know how to change it back.
Go to menu option. With the help of PR+,PR- and VOL+, VOL- keys come to the colour system option. Change colour system opton to auto, and exit the setup.
Oct 15, 2010 | Sharp 25N-M100 25" TV
I am trying to hook up my Philips 19PR19 (made in 1998) tv to the dish network receiver, it has 3 prongs diff. colors attached and the cable cord is already to go in the wall...I don't see anywhere on the...
Because your TV is an older one, it might not have, what they call RCA inputs (the 3 colored cable) Red-audio right, White-audio left, Yellow-video. If I understand you.
You do have the option of using the 75-ohm coaxial cable inputs. Signal comes in from outside to the 722k, Output of the 722k to the 75ohm coax input on the back of the TV. Tune your TV to ch. 3 or 4. Make sure the switch on the back of the 722k is set to the same.
If you really want to use the RCA colored cables, then you need to buy an RF modulator, which integrates older tv's to newer products. But usually dvd players, not necessarily cable boxes, but it would work if hooked up correctly.
You plug the RCA red, white and yellow from the 722k, into the rf modulator, choose channel 3 or 4 on the modulator
Connect 75ohm coax cable from rf modulator to TV 75ohm coax cable input. Choose channel 3 or 4 on the TV.
Hope this helps.
Apr 07, 2010 | Philips 19PR19 19" TV
Cable hookup broken
Sometimes you can replace the rf connector by resoldering it with a replacement rf. You will have to remove the tuner to do this. The big question is did you crack the tuner board or the board the tuner is connected to. You will really have to examine these. In most of my cases a successful replacement rf connector will fix.
Aug 24, 2009 | Sharp 27N-S300 TV
MY TV CONNECTOR AT THE BACK BROKEN OFF
you can hook it up thru av input..what i mean is the red white and yellow wires hook wires into the OUTPUT on box and the input on tv then change tv to the input u hooked them to..for example if u hooked them into av1 then turn tv to av or hiy input on remote
May 26, 2009 | Sharp 25N-S100 25" TV
Sharp Aquos LC-46D64U need to replace broken tuner
actually you dont need the tuner you just need the rf connector itself which you can easly pick up at a radio shack for a few bucks. you can DIY it will take a bit of soldering and time. First take the broken connector to radio and look for a close match, longer leads better you can always cut to fit.
remove board from tv and un solder the tuner. if solder does not seam to melt apply some fresh solder and then unsolder. pop the tuner lid of carefully both top and bottom to gain access to the circuit. cearfully remove any remains of the old connector. Now find the hole where the last part was and insert new RF connector adjust and cut the lead if nessary and resolder to circuit. place both caps back on and resolder tuner to board.connect board to ther circuit and test.
Mar 17, 2009 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
RF jack completely pulled out from back of tv
To repair this problem you must have soldering equip. and reconnect RF input inside of tuner after removing tuner shield, then heavily solder base of RF connector to tuner frame to avoid same issue. Or you could hook audio/video cables from the output on another product such as a cable/sat. box or vcr to video 1 or video 2 input on back of tv. Wires should be color coded so all you have to do is make sure you go from the output on the other device to the input on your set. That should fixya.
May 30, 2008 | Zenith E44W46LCD 44" Rear Projection...
Broken RF Connector
you would have to get a new part for it. try looking online and out in your model number and put in rf connector needs replacing
Mar 10, 2008 | Apex Digital AT2002S 20" TV
Cable connector repair
use RCA cables instead of ch 3
Oct 24, 2007 | RCA D52W15 TV
Sharp 25N-S100 25" TV Logo
90 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
