Question about Garden
I have a Qualcast Power Trak 400 lawnmower which now refuses to start. Before it stopped completely, it sometimes stopped intermiitantly, but I could always get it to continue if I kept my finger pressed down on the starter handle, but now nothing. I have checked the plugs and fuses and they are fine. I have taken off they 'box' containing the handle and red button and there does not appear to be anything wrong with the cables and connections. Can you help please? Regards Frank
SOURCE: Power up problem
One thing u can do also. Open your system case, remove cmos battery clean cmos battery and then insert like same. And restart your system. Other wise check power connections voltage. If it is ok then definitely it will wirk.
Posted on Sep 07, 2007
Master_Tech
  • 770 Answers
SOURCE: Kenmore dryer stopped working, start button does nothing
need the model # from the unit should be where the door closes to the CYE4000AWW is not a Kenmore Model
Posted on Jan 21, 2008
SOURCE: MM875 electric lawnmower
The lawn mower starts, then cuts and the motor produce smoke.
Posted on Feb 20, 2009
shadtremonky
  • 353 Answers
SOURCE: i own a Snapper Lawnmower, model number sr 1030.
check the oil for the presents of fuel
may be full of gas due to stuck bowl float
Posted on Jun 20, 2009
emissionwiz
  • 80339 Answers
SOURCE: 2001 rodeo won't start. the solenoid on the
the clicking is the start relay which u don't hear unless the starter doesn't work, u have a defective starter solenoid, the internal contacts are burned, this is a NipponDenso style starter and they all have this same problem, u can replace the starter, replace the starter solenoid or replace the copper contacts in side the solenoid for around $12.00 USD
Posted on Feb 03, 2010
Replacing Tap on Qualcast petrol tank
It should just screw out, there is a thread on the plastic fuel tap, they can be pretty tight.
Jun 09, 2013 | Garden
I need the size of the poly v belt for a qualcast 4000 lawnmower.
Most time you don't have to get original parts like belts from the manufacturer. Suggest you go to a reputable lawn and tractor supply store where they can easily measure the belt and give you a comparable one for your machine. Hope this helps!
Mar 26, 2012 | Computers & Internet
Qualcast Suffolk Punch 35s lawnmower running problems
There is a small idling mixture screw on the side of the carburettor.
As the engine is not well suited to the carb. it mainly runs on the idle setting!
As long as you are not leaving the choke on. This is a little tab on the top of the carb. You start with it set on C then soon set it on the middle position, and after about 3 mins turn it off.
Jul 12, 2010 | York Yankees Bedding MLB Comforter
Can't remember how to keep my Qualcast Suffolk running!
There is a video on u tube and a wed site the old lawnmowers club .
Jan 10, 2018 | Garden
Been standing idle for about 12 months , starts & runs for a while then cuts out , it seems as if the revs are not high enough ? its a qualcast , quad trak 45 , lawn mower about 15 years old , thanks
did you drain the fuel and replace or just top it up?
when equipment sits the fuel sometimes evaporates leaving **** in the carb this may need to be cleaned out as may have a blockage not letting enough fuel thru...
Brad:)
Sep 16, 2009 | Garden
Electric motor on Qualcast Power Trak 4000 not working. It will not trun the blade. There is electricity going to the motor at the connection point and at the brushes on top of the motor. There is no sign...
I'd first check the brushes for wear and dirt buildup. If worn badky, replace -- otherwise clean, replace, try motor. I doubt the motor is shot unless you've really been abusing it.
May 08, 2009 | Garden
Garden Logo
65 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
