Question about Irons
My iron is a Black & Decker model with a short circuit in the cord, I need a special screw dri8ver to open the Iron where can I purchase this screwdriver?
    Scholar:
  • 97 Answers
Any auto parts store with selling tools should have the tool you need take the item down and have them look at it so they can get you the right one.
hope this helps
Posted on Sep 01, 2010
How do you repair the retractable cord on a 1500w iron
So many people make a copy of that iron maybe a local repair shop for tefal, black n decker, or another can do it. Taking things apart sometimes is not worth the trouble of putting back together. sometimes it requires special tools. call around first before you try it yourself
Jan 26, 2015 | Rowenta DW2090 Effective Comfort Cord Reel...
I HAVE A BLACK AND DECKER IRON-DIGITAL ADVANTAGE, POWER IN THE IRON GOES ON AND OFF NEED TO KEEP ON HOLDING THE POWER WIRE INTO THE IRON, SO I TRIED TO OPEN THE WIRE SECTION,BUT IT NEED A SPECIAL TOOL TO...
Bring the iron to a Hardware store, ask for a set of tools right for the type of screws (maybe Torx, Security Torx, tri-wing, bristol and others).
Once you can open the iron and access to the cord you may change the power cord. it is easy.
Power goes on & off because the power cord is broken. This failure is very common on irons.
Good luck
Apr 19, 2011 | Black & Decker Steam Xpress AS250 Iron...
The electrical cord is very hot at the point where the cord enters the iron
mcdevito75 here, You may have a problem with the heating element in your iron, Check to see if you have a Warrantee if so, return the iron to Black & Decker. In the meantime look for an appliance repair shop in your area and have the iron checked out.
Aug 07, 2010 | Black & Decker Prestige Plus Premium X830...
Iron Blck & Decker: model D2020. I would like to clean my iron because is stared to stain all my clothes. I just open the white plastic parte on the back, but i dont see any other screws or how to get...
No need to dismantle the iron. Just fill it with a 50/50 white vinegar/distilled water solution and allow the iron to expel all of it as steam. Rinse with distilled water and allow to pass as steam. If you use distilled water from now on, you should no longer have staining problems. Hope this helps!
Jul 18, 2010 | Black & Decker D2020 Iron
The cord gets hot
You have a short somewhere in the cord. As this is a risk for fire, the Iron should either be taken for repair or replaced.
Aug 03, 2009 | Black & Decker Irons
Retractable Iron Cord Stuck
under the knob to press to retract the cord there is a screw,
slacken it ad try to adjust it again.
Jul 26, 2009 | Black & Decker Irons
Cord short ccircuit
The back comes straight off. All you need to do is take a small screwdriver and pry against the bottom metal piece, then it should start to come off. Make sure you take it off carefully so as not to break anything. Pry evenly all around the plastic end cap until it comes off.
After that, you can replace the cord. It's connected via two crimp caps. Easy to replace. Just make SURE you purchase a cord rated for an iron.. DO NOT clip the plug end from an extension cord or similar and use it. The iron uses 16 gauge HEATER CORD. Easy to find, but you could melt your power cord and possibly cause a fire if you don't replace it with the correct type.
Mar 13, 2009 | Black & Decker D2020 Iron
My iron needs a new cord
purchase it from==
http://www.powercord-manufacturers.com/
thank you for using FixYa
Nov 14, 2008 | Black & Decker Irons
Does anyone know how to open a Black and Decker digital advantage iron? - I suspect a loose connection where the power cord attaches to the iron and have taken the two screws out of the back plate but the...
I think I have the solution now!
First of all, remove the temperature knob. Than remove the temperature indicator (it's like a little disc). Theres a hidden screw under the temperature indicator! Remove that screw and continue with your fixes.
I hope it could help you.
Jardel
p.s. - Sorry for my noob english...
Sep 21, 2008 | Black & Decker D2030 Iron
Irons Logo
62 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
