Question about Jenn-Air JDS8850 Dual Fuel (Electric and Gas) Kitchen Range
I have a Dual -Fuel oven (JDS8850BDS) with warming drawer. The low setting for the drawer does not work; Hi setting works fine. I have had the control panel replaced after using the self cleaning setting 2 years ago. The oven was purchased in 2006.Besides having to pay the service charge again, what can I do?
  • 26 Answers
SOURCE: Jenn-Air electric range
I believe f3 means a bad oven sensor
Posted on Jan 09, 2008
  • 26 Answers
SOURCE: clock on Model F120 stove Serial 53031577
just set the clock as if to clean , just remember to turn oven off in 2- 3 hrs wait 30 min then before trying to open dr.
  • 16 Answers
SOURCE: Oven won't lock and self clean.
Shut off the oven for at least a minute and turn it on, set the clock, and it worked. I had tried a short power cycle before and it didn't fix it. The extended power cycle did the trick.
Posted on May 02, 2008
docjohn174
  • 943 Answers
SOURCE: Problem with the oven - control panel?
hi .thanks for the question. i would check the cord going ito the stove plug .pull it out and look for a discoloring of the brass prongs. also look for loose connection in the stove where the cord attaches to the stove .that could be the problem .thanks the appliance doc rate me please
Posted on Oct 01, 2008
  • 70 Answers
SOURCE: LOST POWER TO OVEN AND CONTROL PANEL
there is no reset buton ,but there are some basic things u can do.first u can chk the power coming into the stove.open the back and u will see power cord connected to the stove.use a multimeter and chk voltage between black and red wire.it should read 240v and black/red with respect to green should read 120 volt.if that is ok look for any burnt wires etc.if all is ok then most likely could have control board.
Posted on Aug 21, 2009
How to reset error codes
Dual Fuel Range Error Code 07 ' FAQ ' Sub-Zero and Wolf
www.subzero-wolf.com/.../dual-fuel-range-error-code-07
Sub?ZeroCore Issue: Dual Fuel Range error code 7; ERR 07 displays on Dual Fuel; Error 07 on control panel of Dual Fuel ... Convection Steam Oven Error Code E75.
L Series Built-In Oven Error Code COMM ERR ' FAQ ' Sub ...
www.subzero-wolf.com/.../l-series-built-in-oven-error-code-co...
Sub?ZeroCOMM ERR displayed on an L Series Built-In Oven indicates a communication error.Reset the unit's power at the circuit breaker. Turn the unit back on to see if ...
WWD30 Warming Drawer Error Code 40 - Sub-Zero and Wolf
www.subzero-wolf.com/.../wwd30-warming-drawer-error-cod...
Sub?ZeroError 40 on a Wolf Warming Drawer. Steps to Verify Issue: With error 40 on WWD30 warming drawer try the following before calling service: ... x. PF Error Code on Warming Drawer ... Whether you're shopping for appliances or have questions about those you already own, we've got the resources you need. ... Wolf Cooking.
Wolf DF304 beeping after turning off the oven - The Kitchen ...
appliantology.org > ... > The Kitchen Appliance Repair Forum
Dec 25, 2015 | Wolf Range Kitchen Ranges
Electric stove top. Only the warmer drawer knob works. Why don't the others?
THE HEATING ELEMENTS COULD NOT BE MAKING A GOOD CONNECTION,TRY PUSHING THEM IN.
Jul 05, 2015 | Kenmore Kitchen Ranges
I have a jds8850bds and i have error code ef206 and m206 can you please help me
For the codes EE206 and M206 need to replace the Electronic Control Assembly this could also solve the EF206 code you have! Do you have a list of the codes in a manual?
Oct 23, 2014 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Oven turns off without warning
I had to replace the thermo coupler in mine. Would heat up then go out.
Aug 17, 2014 | Dacor Epicure ERD30 Dual Fuel (Electric...
Oven takes way too long to ignite and or warm to temp
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Feb 11, 2011 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Water spilled down the stove top causing the oven
ater spilled (4-5 cups) on the stove top running down into the stove control panel face (where you view oven temp, timer, etc). No water ever dripped into the oven or oven window. The stove top still works but the oven, warming drawer, clock are all non responsive after three days. No buttons on the control panel work at all. What repair is needed?
Jan 06, 2010 | KitchenAid KDRS807SSS Dual Fuel (Electric...
Jenn-Air JDS8850BDS control panel malfunction
You need a new control board. I bought similar range in 2004 and I just got my 3rd control board. Heating the oven over 400 degrees and using the self-clean function kills the board.
Aug 11, 2009 | Kitchen Ranges
Thermador over/microwave/heating drawer model SMW272YP Bake bottom element will not heat up. I have replaced the element. The display pannel has been replaced in the past, but still keep having the same...
I just found out my baking oven doesn't work and I hear the fan for the convection roast, but no heat. I had the appliance man out and he said that I need a relay board! Big bucks and they don't make this model anymore. Moreover, the microwave and warming drawer work fine. This is ridiculous!
Mar 07, 2009 | Thermador C302U Electric Double Oven
Electric warming drawer will not heat
Found that there is an electrical connection at the point the main electric enters the back of the stove. There is a connector for the element that was not connected. Now it works!
Feb 18, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Jenn-Air JDS8850 Dual Fuel (Electric and Gas) Kitchen Range Logo
55 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
