Question about Kenwood Audio Players & Recorders
Cd's skip when playing even after I use a cd cleaner.
  • 52 Answers
Make sure it plays well in another machine. If it does then you cd player could defective
Posted on Sep 01, 2010
4 Suggested Answers
mikeymiddles
  • 58 Answers
SOURCE: CD SKIPS
  OK.  I think I can help.  There are two very simple solutions to a skipping CD player.  You have tried one already, that is, clean the laser-reading eye.  Lets assume you did that correctly and that is not the problem.         So, to continue, the machine must be opened. Equipment required: Jewellers screwdrivers, small number one screwdrivers, cottonswabs or Q-tips, Petroleum jelly, 100% isopropyl alchohol is ok but if you can use Denatured alchohol that is the best.        Using a set of fine jewelers screwdrivers or just a small #1 Regular or Philips screwdriver to remove the top cover of the CD player.  Don't force anything and place the screws in a cup so they are not lost or misplaced. I work in a plastic cafeteria tray to contain any dropped screws    The problem here usually occurs in trusty old CD players that have always worked fine and the problem (skipping) starts out small and gradually progresses to always skipping.  The problem and solution are mechanical in nature.    First locate the laser eye and check it physically for any optical obstructions (dust, dust-bunnies, lint, feathers, hair, lumber, etc.)    When you are sure the laser-eye is clean find two parallel small (usually 1/8" or about 3mm wide by about 3 to 6 inches long ) chrome metal bars that the laser eye rides back and forth on.  The eye assembly has a small contact-lens looking clear plastic lens mounted on a plastic carriage that moves from the center of the disc toward the outside as it tracks the disc.  It will have a small ribbon wire harness that can expand and retract with the travel of the laser-eye carriage.  Now look at the two-parallel shiny metal bars the carriage should slide on. The lubricant on these bars lets the eye assembly move smoothly without vibration (or skips) over the length of the two steel bars and your CD plays perfectly when they are clean and lubricated.  This skipping problem can occur if something sticky is spilled into the unit. Soda or beer dries out and if it gets on these steel bars the laser-eye assembly can vibrate and chatter as it tries to track over the CD's info causing skips.      So the solution involves carefully testing the unit with the lid off to see what is going on inside when the unit plays (or attempts to play) a CD.  If the obstruction to the path of the eye assembly is severe, the tiny drive gears can be damaged, broken, or stripped and the eye will not move smoothly without new parts (Factory Authorized Service Personnel are recommended in that case)   Use the Denatured Alchohol and swabs to completely clean and dry the steel track rods that the laser - eye slide on, take care to clean any built up old grease (manufacturer lubricant) that may build up on the holes on the sides of the Laser-eye assembly where the steel track rods go through it.  After cleaning the rods use a new swab to apply a TINY amount of petrolatum evenly to each rod.  I cannot stress enough how important it is to use as little lubricant as possible ONLY on the rods and NOWHERE ELSE!  It is very easy to get the petrolatum somewhere you don't want it.  Be Careful!  One mistake here could cost you the entire unit!  after application, physically slide the eye assembly over the bars to smooth out the petrolatum lubricant evenly. (in the event the eye-assembly doesn't manually slide, don't force anything and go to the next step). make sure you did not get any petrolatum where you did not want it, if you did clean it with cotton and good old, denatured alcohol and put a CD in and before playing it, advance the tracks from track 1 to the highest numbered track and back several times to smooth the lube more.  Play the CD and replace the lid and screws in the order you removed them.      Good Luck!
Posted on Dec 11, 2008
SOURCE: Panasonic SA-PM193 5cd stereo system
how do I have all 5 cd's play one after another automatically?
Lost our manual.
Thanks
Posted on Jun 19, 2008
SOURCE: static and skipping
Sounds like the laser breaking down, when you say 'skipping' you mean forward yes? It's losing focus and jumping the bit it can't read, replace it. If you mean skipping backwards (this usualy happens on tracks towards the end of the CD) the laser mechanics need servicing. Put in a CD with lots of tracks and select the last track, play it, forward search through it to the end and eject CD. Repeat this three or four times and that should sort it.
Posted on Dec 30, 2008
How do I clean the laser on a Memorex CD mini stereo with a 3cd changer
It is not even sure your laser is dirty. Perhaps you only have some bad CD's?
Does it also skip, with real music CD's. I mean the ones that are not burned in a computer. Not all self mad disks are good enough to be played and not all players can handle the self produced disks.
The cleaner you could use, is a CD, with a little brush glued on it. Don't try to make one, just buy one.
See the little red bus to the left of the middle.
Nov 18, 2014 | Memorex Computers & Internet
CD player skipping
Make sure the unit is mounted level and not to secured that its pinching down on the unit
Jul 23, 2012 | GE 7-5295 Undercounter DC /Radio Combo -...
I have a CD player problem does not play any CD's Thanks
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load Cd's. The weak lens is also what's making it skip.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all Cd's with no problem at all.
Good luck.
Mar 08, 2011 | JVC XL-MC222BK CD Player
We cannot use this because the CD's all skip. We found out that there aren't replacements to buy, we tried at Best Buy. we really miss being able to play CD's. Can you help.
Take care.
Feb 03, 2011 | Technics SL-PD687 5-Disc CD Changer
I bought a Radio Shack cd cleaner (cd w/little brush on it) to clean the lens of the cd player however the machine won't recognize the disc when inserted so I cannot figure out how to "play" it. Many of...
yes here is a simple easy way to get them to stop skipping, stick them in the freezer portion of your fridge, only if the cds have scratches on them, even the smallest scratch can cause a perfectly working cd player to make the cd skip, stick the cd in the freezer for about 15 or 20 mins and pull it out and play it, i have used this method for a lot of my video games as well and have never had to buy any "cd player cleaner cds" i hope this helps
Jul 16, 2010 | Sony CDP-CE575 5-Disc CD Changer
Hi, I have a set of Denon DN-D4500 mixing CD's that are freezing/skipping, and need to be fixed. Any advice, please? Thanks
The weak lens is also what's making it skip/freeze.
Good luck.
Apr 26, 2010 | Audio Players & Recorders
My Emerson ES30 CD Player skips all of the time and sometimes won't even load the CD. Any idea what can be done? Thanks.
Good luck.
Apr 19, 2010 | Emerson ES30 Shelf System
Professional new karaoke system skipping and lyric problems
your disc is scrath or maybe the lens of your player is already weak,or have dust,if you can do the job,clean it with a soft cotton..wipe carefully with only one direction..try also the lens cleaner.
Feb 23, 2008 | Memorex MKS5009 Karaoke System w/CD/CD+G...
Cd's skip
all the rca's have been released without quality control... you will have to open and adjust the potentiometers (the adjustible resistors on the main board) to re-calibrate the laser timings. However the way that the boards are mounted inside the boombox's chassis you will need to take apart everything to be able to reach the main board (inside vertical right side board with large heatsink and fan) without causing a short (as to be able to properly adjust these you need to have a cd playing and the whole thing needs to be upright.
I would recommend throwing it all way, not worth the time if you don't have the patience.
Nov 25, 2007 | RCA RS2653 Shelf System
75 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
