Can not open remote control to change battery type R11HG/E
4 Suggested Answers
SOURCE: remote control not working for split system
Hey,
I just had the same problem, if the remote slides down, the batteries are at the end of the remote. You need to carefully remove the slider part and the batteries are under there. I found I needed 2 x AAA batteries and I am now able to turn off the air conditioner!
Thanks heaps for the help above - it helped immensely!!
Posted on Sep 29, 2008
SOURCE: Battery Contact points coroded & need replacement
Haven't actually located a purchasing point for these battery contacts but have temporarily overcome the problem by use of aluminium foil which is a commonly known workaround.
Posted on Jan 20, 2010
baraquielnar
  • 247 Answers
SOURCE: have type R11HG/E remote for
try to call the aircon supplier or the carrier service center on your nearest location.
Posted on Feb 05, 2011
How to change battery
Either the remote control is regular size or miniature like the remotes for cars. The only real difference is the type and size batteries it uses. The regular size remotes usually use 1 or 2 "AA" or "AAA" batteries, or occasionally, a 9 volt battery. The miniature remotes take "button" batteries that are available at Radio Shack or the big-chain drug stores like CVS. Whether the batteries are the regular type or miniature here's what you do: On the back side of the remote there will most likely be a small phillips-style screw in the middle. Remove this screw and then you will be able to open the battery compartment door. Write down or take pictures (better) of how the batteries are configured and note this as you remove the old batteries. Radio Shack has a battery tester. If ALL the batteries are still good, then the remote is defective. If ALL the batteries are dead or very weak, then most-likely the remote is working fine & will come right back to life. Enjoy!
Jun 10, 2014 | Sanyo RCS-SH1UA Wireless Remote Control
Buttons not responding. message on screen says "Starting Activity.Please keep the remote pointed at you system"
1) change the batterie with the same type and fully charged
2) clean the contacts battery with c.cleaners
3) retight the spring contacts battery with pliers, for a good contacts.v.iMPORTANTE
4) PROOF
5) if doesnot resolve the problem
6) open the r. control and clean the keypads swithc, for dust,etc, open contacts, or band contacs.
7) otherwise you must go to the repair shop TV
God bless you
Aug 06, 2012 | Logitech Harmony 880 LCD Remote Control
I have Roshan tv,my remote is not working,fell,n,damage.model Hh 21scp
1) change the battery with the same type, and full charged
2) clean contacts battery with contacts cleaner
3) resolder the wires connector battery
4) retigh the springs contacts battery with pliers for GOOD contact
5) open the r. control, and clean the keypads switch, for dirty, dust, bad contacts or open contacts test with VOM.Rmember they send clean infrared beam from Syscon Micro trans to the receiver
6) Otherwise you must go to the repair shop TV for fix it
God bless you
Aug 02, 2012 | One For All URC-3021 Remote Control
How to fix digital stream remote control
1) try to change a new batteries by the same type of batteries and full charged
2) clean the contacts battery with contacts cleaner
3) retight the springs contacts battery with pliers for better contacts
4) resolder the wires contacts battery
5) open the remote control and clean the keypads switchs with contacts cleaner for dirty, dust, oxide, bad contacts, open contact with VOM and fix it. Remember they receive signal from Syscon and emite infrared signal to the receiver
Otherwise you mus go to the repair shop TV for fix it.
God bless you
Jul 31, 2012 | Televison & Video
Type R11HG/E-XLM...how do ya change batteries on remote
Visit this site named [Electro help]; to get more details about how to check remote and to repair it. Googel for it.
Apr 30, 2012 | Televison & Video
Need help changing batteries on Wave Radio remote
Setting up the remote control
WARNING: Keep the remote control battery away from children. It may cause a fire or
chemical burn if mishandled. Do not recharge, disassemble, heat above 100°C (212°F), or
incinerate. Dispose of used battery promptly. Replace only with a battery of the correct type
and model number.
Your remote control may be one of two types. Each is identified by the way
the battery compartment unlocks to install or replace the battery.
1. Place the remote control face down on a flat surface.
2. If your remote has a slot on the back, follow step A. Otherwise, follow step B:
A. Insert the tip of a ballpoint pen into the slot. Push to the side as shown and hold. Slide
the battery compartment open with your finger.
B. Using your finger, push the tab lock to the side as shown and hold. Slide the battery
compartment open.
Setting Up
See operating
instructions for types of
battery to be used
Note: Use only a Duracell, Eveready, Maxell, or Toshiba CR2032 or DL2032 lithium battery
(available at electronics stores). If you have difficulty finding a replacement battery, contact
Bose® Product Support (see phone numbers on the inside back cover).
3. Keeping the remote control face down, insert the new battery into the compartment with
the + symbol facing up.
4. Gently slide the battery compartment closed. It locks automatically.
5. Use the supplied mounting strip if you want to attach the remote to a surface in your
listening room. Peel off the protective backing to stick one piece to the back of the remote
and the other to the selected surface.
Jul 18, 2010 | Bose Wave radio remote control - Graphite...
Jan 17, 2010 | Carrier Heating & Cooling
Remote control not working for split system
slide the slider down until it stops, then lift/prize the middle of the slider lid upward (or outward,, however you concieve it) and continue sliding the final 2cm. Voila! batteries are revealed. 2x AAA.
Don't understand? (Don't worry, my wife can't do it even after watching me do it TWICE !!)
Okay... the slider stops about 2cm from the bottom of the remote (when slid down as far as it will go). The reason for this is a small catch in the middle of the remote, just below the lidof the slider-bit. You need to LIFT the lid of the slider over that catch. The reason I use the word 'prize' beacuse you'll need to dig your fingers downwards, just below the TIME ADJUST button, and at the same time work the lid upwards against this pressure. LIFT / PRIZE the lid up in the middle, and away it comes!!
Still don't get it? YOU ARE USELESS and must go and pay one of the clever people to do it for you, *******!!!!!
Ha Ha aaaahhhh!
Feb 16, 2008 | Heating & Cooling
Heating & Cooling Logo
1,353 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
