Question about Belkin (F5D7230-4) Router (587009)
I went to the admin page and i put my passsword was WEP, but when i try to acess , the router ask me for a password that i donĀ“t know whick pass his? May you help me to put in a Open Security again? Thanks for all
jessee007
  • 310 Answers
SOURCE: Help! new users for Belkin wireless router
there are several reasons why this happens. dont use belkins utility use windows utility it will ask you if you right click the icon in the tray.
Posted on Jan 08, 2008
XBRMann
  • 38 Answers
SOURCE: setup of municipal wifi
It sounds like you'll need to reset the router to factory defaults, here's how to do this:
With the router powered on, press and hold the reset button for exactly seven seconds, this will restore the router to factory default.
Note: By default the password on the router is left blank, and the
default IP address is 192.168.2.1
Hope this helps!
Posted on Feb 09, 2008
SOURCE: How can I get the Belkin admin interface up?
Same thing happend to me, but I have tried to reset mine aleast several times, even talked with Belkin tech support and no help there... They didn't seem to know any more than me. I have assumed from reading similar problems to mine, that maybe my router has crashed. If you have followed all the instructions given ( most will tell you to do the same thing every time.) then purhaps you need to purchase a new router. But, before you spend the money, try everything FIRST! Make sure you've tried every option, before having them send you a new one ( but, I would suggest to try another brand other than Belkin.) or going out and purchasing one. Good luck and I hope this helped!
Posted on May 27, 2009
  • 10406 Answers
SOURCE: where is the wep key located on my virgin router
Connect your desktop computer to your Belkin router, and access the router's built-in web-server software. Then, run the "Wireless Network Setup Wizard", to configure the router's wireless networking capabilities. As part of that process, you will be required to _create_ a "WEP-key" value. Use that value when configuring the wireless capability of your PS3.
Posted on Jan 24, 2010
  • 116 Answers
SOURCE: How can I retrive my password or wep key off my
Use a wired computer to access the setup page of the router.
On the browser's address bar, type 192.168.2.1.
By default, leave the password field blank.
Once on the setup page of the router, go to Wireless then Security. You can get the WEP key from this screen.
Or if you would like to turn off wireless security, just change the security mode.
However, I strongly suggest to enable wireless security so that other people will not be able to use your wireless network.
I hope this helps!
Posted on May 17, 2010
How to I find the WEP Key
The default WEP key of linksys router is found at the back of the router. Just flip the device and you will see a sticker on it, it will give you the default SSID and WEP key. If you had change it before, what you need is to directly connect your pc to the router using ethernet cable, then open a browser, type 192.168.1.1 then it will ask you for a password and username. The default username and password is Admin. if it will not work, you can try admin for username then password for password box. If it still does'n't work, then reset the router. Turn off the router for 5 seconds the turn the power on again. access the 192.168.1.1. Enter admin for both the username and password. Next, click on the Wireless tab at the top of the settings. Then click on Wireless Security subsection at the top of the page. from there, you will be able to see the WEP key that was set, that is the page as well wherein you can edit the WEP key if you want. Don't forget to click on save settings if you did some changes so that it will be applied.
Sep 04, 2011 | Linksys Wireless-G WRT54G Router
I wanna change the password of my router DIR-615, but I don't know how to do. I put the ip address, then it was asking for a password after admin. so i couldn't login from there. which password do...
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
May 24, 2011 | D-Link DIR-625 (790069292637) Wireless...
Need wep key
Access the management page from your browser. (Internet Explorer, Firefox, Etc.)
The address is: 192.168.1.1
The default password is admin, leave the username blank
Click on the "Wireless " link
Then click on "Security"
You will see your WEP key there.
If you have forgotten your router passsword, you will need to reset the router.
Linksys reset
The easiest method of resetting your Linksys router's password is to reset your router back to the default factory settings. This is done by simply holding down the reset button located on the back of the unit for at least 30 seconds. Once the router has been reset, it must be reconfigured. Using your web browser go to URL address http://192.168.1.1. You will then be prompted to login to your router. A log-in screen asking for the password will automatically appear. At this time enter the default password "admin", in lower case letters into the password field. The username field may be left blank at this time. (Note: both the default username and default password are set to "admin" on some of the newer Linksys router models).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Apr 27, 2011 | Linksys Wireless-G WRT54G Router
I am trying to connect my wireless printer to the router, but when it comes to the WEP code, the one I have does not work. Is there a way to reset the WEP code?
Hi glenncj,
Welcome to Fixya. If you need the WEP key or Network Key you need to access the Wireless Settings Page.
To access the router page just open a browser then type 192.168.1.1, the Default username is blank and the password is admin. Go to the Wireless Tab select Wireless Security under the Security Mode you will see there Network Key or Wep Key. The Network Key or Wep Key serves as a password or security code on your network to make it secure.
You can also reset the router by pressing the Reset button at the back of it for 15-30 seconds using a Pen and a Paper Clip.
If this works dont forget to say thanks. Thanks for using Fixya.
Feb 07, 2011 | Linksys Wireless-G WRT54G Router
What is my security key for westell router (black with two antennas?
Connect your router to computer with ethernet cable then you can acess it with following default link. http://192.168.0.1 or http://192.168.1.1 If you have belkin router then http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Click on wireless settings then WEP Security then not down code .It is your password to connect wi fi.. Then you can connect your wi fi network with that code. Let me know if you need further assistance. Thanks for using FixYa.
Jun 14, 2010 | Westell Wirespeed VersaLink...
How do I secure my wireless internet? I just got a new laptop and I need to secure the wireless connection before I start using it. I have a Linksys wireless-g 2.4 GHz broadband router and I never secured...
your router has a driver cd..try to run it and set up it again in the installation process you will be prompt to insert security for your wireless lan...create your passsword and your wi-fi will be secured...
just remember your your password so that you can connect to it...
Feb 12, 2010 | Linksys Wireless-G WRT54G Router
I never set up a password for this router but everytime i tried to conect to internet thru my laptop it asks me for a passowrd. is there anything like a universal password that i should use?
if its asking you for a wep key, you must go into the modems page and get it.
i think best way to find the modem page is goto start and in run type cmd, then type ipconfig, the default gate way is the adress to your modem page type this number with is some thing like 192.168.2.1 into your internet explorer page, this should bring you to your modem. navagate through this untill you find wireless settings and in there you will see the wireless wep key. if it ask you for a password try admin and pass admin or admin with no pass, you can google what your password is to this modem if you have a problem. hope this helps,
you do all this on the computer that is conected.
Nov 29, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I can't find the wep key and it isn't on the back
first connect your router to computer with ethernet cable.
Then you can access it with defaults ip
http://192.168.15.1
if you can't access it then you have to reset router.
for that you can find reset button in back side of router.
Press it for 10 seconds .
Then you can access it with 192.168.15.1
If it ask for user type as "admin" and password as "admin" or blank or "password"
Then go to wi fi security and check wep code it is your passsword to connect internet you can also set new password there.
Let me know if you need more assistance.
Thanks.
Oct 22, 2009 | Belkin (F5D5231-4) Router
My wireless connection is unsecured I'm using a Netgear router,what do I do to secure my line?
1. Goto your web browser
2. Type 192.168.0.1 or 192.168.1.1 (depending on which Netgear router, just try both).
3. Type "admin" for username and "admin" for password.
4. Click on "Wireless settings" on the left frame of the router setup page.
5. Security options are on the main frame of the page now (under security options). Click on WEP and enter a WEP ID (make it unique).
6. Click on "Apply" and repair your wireless connection. It should prompt you for a WEP key.
Hope this helps,
Bill
Sep 05, 2009 | NetGear WGR614 Wireless Router
Tried to get on line with ps3 went to network put in enable went to put in wirless went to scan found my internet and it wants me to put in wep dont no what that wep is
WEP is short for Wired Equivalency Privacy and it is a security protocol for Wi-Fi networks.
If it is asking for your WEP, you will need to know what the password you entered into you wireless router was. That same password will need to be entered into the field on your PS3.
If you are unsure of the password, try logging onto your wireless router and check the settings out under wireless security.
To identify your wireless router web page, type the model into Google and look for the online link. If you didn't set a admin password then the default one will still be active.
If you still have questions, drop another post.
OpenSource13
Apr 17, 2009 | Sony Playstation 3 (PS3) Console
Belkin (F5D7230-4) Router (587009) Logo
21 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
