Question about Western Digital WD2500BEVSRTL Scorpio 250GB 2.5" SATA Notebook 250 GB SATA Hard Drive
New WD2500BEVS 250 Sata drive trying to use it as an external drive
The drive is not recognized by xp.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 268 Answers
Try these
i.Close all explorer windows
ii. open task manager and kill the "explorer" program
iii. in task manager select "File--New Task(Run)-- explorer
and the USB drive appeared in explorer
Or
Just try doing flea power & the power cycle.
1. Disconnect all the peripherals like keyboard,mouse,printer,scanner & monitor and power supply from the CPU.
And press & hold the power button for 1 min, it will release the flea power from the mother board.
Restart the system & check.
2. Disconnect everything.wait for 5-10 minutes and then connect every thing & start the system.
Or
1. Connect the USB enclosure to the computer and turn on the computer.
2. Go to Control Panel - Administrative Tools - Computer Management. In the Computer Management window click on Disk Management.
3. In the Disk Management window you should see 2 hard drives. Disk 0 – that’s your primary hard drive and Disk 1 – that’s the hard drive in the USB enclosure.
For the Disk1 you’ll see the HDD size inside the bar and also it should say Unalocated. It means that the new hard drive is not partitioned and formatted.
4. Right click on the unallocated space and click on new partition entry, the wizard for creating a new partition on the hard drive will appear.
In most cases you should chose: Primary partition, partition size would already in there (entire drive), assign any free letter or leave it default, file system NTFS (default), check the Perform a quick format (faster) box, NEXT and FINISH.
It might take some time. You’ll see that the LED on the USB enclosure (if you have any) will start flashing.
5. After it’s done, you should see that Disk1 says: New Volume, HDD size, and Healthy.
Now, if you go to My Computer you should see the second hard drive and you can use it as a regular drive.
If so, it can hide drive letters. Look up TWEAKUI and use that to see if drive letters are hidden.
You can download it from here
http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx
Or
you can use the usb hub 2.0 instead of 1.1.
Completely shutdown?
That is, shutdown and remove all power from all devices and power bricks for a 10 count and try again?
How about plugging that into another USB port? Some discover some ports will not work, but report "OK".
Or
You can run the diags on the drive, you can get from here
http://support.wdc.com/download/index.asp?cxml=n&pid=999&swid=3
Error definition :
http://support.wdc.com/techinfo/general/errorcodes.asp
You need to test the drive on another machine and if it behaves the same, time to call its maker to get it exchanged.
Good Luck.
Live, Love, Laugh.
Posted on May 10, 2008
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
Need disk manager
Boot the system from the Installation diskette. Install will happen automatically.
Jun 13, 2013 | Western Digital WD2500BEVS Scorpio 250 GB...
Jumper setting sata drive western digital scorpio scsi eide
Look for your model number on Western Digital's support site:
http://support.wdc.com/product/install.asp?groupid=701&lang=en
Apr 29, 2013 | Western Digital WD2500BEVS Scorpio 250 GB...
My computer does not recognize External Hard Drive?
Try a new usb cable. Or take it out of the enclosure and connect direct to a sata port on a desktop pc.
Aug 29, 2012 | Computers & Internet
I want to use my wd2500bevs as an external drive but i don't know which style enclosure to buy. any suggestions?
pick one
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007705%20600006255%20600006269&IsNodeId=1&name=SATA
Jan 21, 2011 | Western Digital WD2500BEVSRTL Scorpio...
Laptop cannot find new sata disk
Can you provide me the details of the laptop. Also; are to trying to install Windows XP OS on your notebook.
If you are trying to install Windows XP on your notebook; then we need to disable the SATA on the notebook by using the external USB based floppy drive or using the nlite application burning the XP OS disc with a set of SATA drivers to install and recognize the hard drive.
Mar 03, 2010 | Computers & Internet
Acomdata 250 external (SATA) hard drive not showing up on desktop
be safe
go on line to acomdata web site and down load the driver from there
Oct 11, 2017 | Acomdata (HD250SE5-72-PCI) (HD250SE572PCI)...
Installing new sata drive in HP pc
a clean xp installation does not recognize sata drives at all. you can either use nlite to build a custom install cd, press f6 during setup to load additional drivers, try to change your sata mode from native to compatible in your bios or use your restore cds.
Mar 18, 2009 | Western Digital WD2500BEVSRTL Scorpio...
Laptop Won't Recognize External HD
You can try opening the device manager in Window XP and uninstall the external hard disk (make sure you show unplugged devices).
Then replug the drive again, and it should reinstall the drivers.
Jules
Feb 22, 2009 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Western Digital WD2500BEVSRTL Scorpio 250GB 2.5" SATA Notebook 250 GB SATA Hard Drive Logo
1,579 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
