Question about Kenmore 63942 Dryer
Dryer works but timer doesn't work. It will keep going and gets really hot
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 12, 2010
Hotpoint TVM572 timer is faulty
It is important not to open the door of the dryer if it is still running. The timer controls the cooling cycle otherwise the clothes will get damaged if kept on hot.
It is very likely the timer contacts are frozen at some point and the timer will need some attention.
It is not hard to locate it. I cannot find the actual parts drawing for your model (it is good you have provided the full model details). But to help you locate the part I have found another Hotpoint model that may be similar to yours. Check this drawing to see if the front panel is similar.
Item 100 is the timer.
HOTPOINT Electric Dryer Backsplash blower moto Parts Model NWSR483EB1WW
The actual timer for your model looks like this.
Hotpoint TVM572P Timer
As the clothes are not getting burnt or singed I will assume the thermostat is ok and keeping the temperature within the range.
Aug 07, 2014 | Hotpoint Dryers
My kenmore 400 dryer timer doesnt move causing the electric switch go of every three minutes
Wow! Sounds like a couple different issues. First, make sure you have a free flow of air through your dryer duct work. The first place to check is where your dryer vent exits the home. With the dryer running, is there a good volume of air flowing through? No? Unplug dryer, ensure there are no kinks in the duct work, check for lint buildup in the duct work and on the back side (Inside of unit) of the lint trap. If you find no obstructions the blower motor may be bad or have a bad connection. The timer/selector switch could have a loose connection, gone bad or be dirty from lint buildup. If it's lint buildup around the switch you may be able to clean it with an old narrow 2" paint brush and some electrical contact cleaner. Make sure the appliance is unplugged when working inside the unit! Also, if you use electrical contact cleaner make sure you give it ample time to evaporate before testing dryer. If none of this helps, time to get on the phone. Good luck! :)
Feb 17, 2014 | Kenmore 400 6943 Dryer
Dryer problem
You really should post your make and model number and any error messages you get if any , I would guess the heat sensor or timer. Here is a website where professional appliance repairmen will answer your questions. Hope that helps you.
http://forum.appliancepartspros.com/dryer-repair/112843-dryer-shuts-off-after-getting-too-hot.html
Jun 09, 2013 | Dryers
Moisture control
Dryers have 2 basic types: AUTODRY and Electronic. The electronic moisture control relies on 2 bars inside the dryer. As wet clothes rub these bars the wetness discharges the capacitor on the moisture control board. As long as the cap don't get a full charge the timer motor will not advance forward to the end of cycle. What goes wrong on these? Wax buildup on moisture bars form a barrier that keeps wetness off them bars. The control thinks them clothes is dry and shuts her down. On autodry the timer motor advances very slowly, The motor does not work while the heating element is on. Only when the heating element is off does the timer motor advance. As them clothes gets dryer the temp inside the dryer stays warmer and therefore the dryer thermostat keeps the heater off long and the timer motor advances. Like being on a highway with traffic jam you go a little bit then stop then go a little bit more then stop. Finally you get there. So what goes wrong? The control thermostat is not functioning properly causing the heater limit to do all the work . Instead the heater limit has to do the work and it ain't a real happy camper. Makes them clothes get too hot. They come out wrinkled.
Aug 30, 2012 | Maytag Dryers
Replaced timer with part #8299779 in Kenmore Dryer. The timer would run by the off and keep on running. The dryer got really hot to. The new timer did not cur the problem.
Unplug the dryer. Access the 'Start' switch and its terminals. Check the 'Start' switch with an ohmmeter. It is probably fused together internally. It should read zero ohms when not activated.
Good luck from Detroit, MI.
Jul 19, 2011 | Kenmore Dryers
Whrilpool washer/dryer stack the dryer doesn't get hot
You will find that the drier wont get hot because the timer is not forwarding onto the heating part of the cycle. Possibly if you click one click at a time, you will possibly get to the heating part of the cycle but its not safe as it wont go any further. Install a new timer and you will be happier I'm sure.
Sep 28, 2009 | Dryers
We just bought this dryer and after drying a load I touched the top of the dryer and it was incredibly hot? is this normal?
Check your vent it may be stopped up this will cause the top to get overly hot and the bearing to squeak
May 31, 2009 | Frigidaire GLER341A Electric Dryer
Clothes dryer don't run
sounds like a bad cycle timer switch
Apr 22, 2009 | General Electric Clothes Dryer Knob -...
My maytag dryer drum turns but the air will not get hot
Look insid door and get me the model number so I can help you better, Thanks, Sea Breeze
Mar 29, 2009 | Maytag Dryers
Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
Jun 11, 2008 | GE DBXR463EBWW Electric Dryer
Kenmore 63942 Dryer Logo
100 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
