Question about Goodman CLT24AER24 Air Conditioner
Blows 3A fuse - Goodman CLT24AER24 Air Conditioner
  • 455 Answers
Hello There are 2 causes 1 :the wire to the outside unit is shorted (touching) something or itself.OR 2 :replace the contactor (outside unit)because the contactor coil is shorted.
Posted on Sep 01, 2010
Boston micro 95pv sub-woofer is blowing 3A Slow Blow fuses.
I would expect a shorted component in the power supply
Sep 06, 2016 | Boston Acoustics Micro90X Speaker
Ball will not launch onto playing field. I do not hear the solenoid being energized??
what blew the fuse ?
you may have a fault that is blowing the fuse or caused the fuse to blow !
Mar 18, 2015 | Data East Star Trek the Next Generation
Blowing fuses on rheem rtgh 84dv
Call service technician
Check polarity of 120 volt outlet
Call Rheem for new PC board
If the 3A glass fuse located on PC board is blowing, then something is drawing too much current or shorted on board... problem is probably bad PC board
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Gene
Oct 12, 2014 | Rheem RTGH-84DVN Indoor Direct Vent...
3a fuse blows stat wiring good
Your heating element could be shorting out inside the tank.If you have 2 elements, disconnect one wire from the top one turn on. if the fuse doesn't blow then the top element is mad.try the same check on the bottom one ,dont forget to put the wire back on the top one first. remove fuse before you disconnect the wires.becarfull
Jan 17, 2014 | Water Heaters
Blowing 3a fuse
If it keeps blowing the fuse, something is shorted. You need to find the short to resolve the problem.
Apr 06, 2013 | Eagle Cuda 350 S/Map Sonar/GPS Portable...
We have Goodman Model GHP 0 75-4 Gas unit. The 3A fuse continues to blow. We replaced the Transformer, (it smoked). The moment we turn on the thermostat to "Cool" the 3A fuse blows on the...
Hello, sounds like something is shorting to ground, make sure all the low voltage wire are secure at tne indoor unit and the outdoor unit, also check the thermostat wiring all the way from tne outdoor unit to the indoor unit aor any cuts or missing insulation.
Jul 22, 2011 | Heating & Cooling
Blew a fuse what kind dose it take is it a slow blow fuse or fast blow one,i took out the old fuse and it reads le.3a/250v is it a 3a or .3a
It is a 3A/250V fuse, also known as a 6A/125V fuse.
Power amps generally have slow blow fuses.
If this is helpful, please be sure to hit the "Thumbs-Up" for me!
Jan 24, 2010 | Polk Audio PSW202 Subwoofer
Pioneer DEH-P2000
Most of the car stereos are 40 to 50 watts output.so they need a stronger fuse than 3A.This kind of radios use 10A fuse.
Jan 12, 2008 | Pioneer DEH-P2000 CD Player
Goodman CLT24AER24 Air Conditioner Logo
32 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
