Question about Cameras
I have a coolpix l19 camera-i was taking pictures fine when the screen went to a white-gray when turned on. i tried changing batteries and memory card?
    President:
  • 1,194 Answers
This problem can be due to BAD CCD sensor unit or probably loose RIBBON CABLE inside.
  • Open the camera and reseat all ribbon cables linked to the LCD (screen).
If the problem is still there then contact Nikon for bad CCD.
Thanks for using fixya,
Good luck and have a nice day.
Posted on Sep 01, 2010
P100 was working took 1 picture and froze open. white screen won't charge
Perhaps you have an empty battery?
Just remove the battery and try charging it on an external charger. When it is charged, try again. The camera should start with retracting the lens. Perhaps you again should power down and remove the battery for a few seconds after that, but just try it.
Switching of a camera causes it to start again, like a cold boot from a computer.
Monitor your battery, because if the camera shuts down very soon after that, perhaps you need a new battery?
May 05, 2014 | Nikon Coolpix 4600 Digital Camera
I have a nikon coolpix s60 and when i go to view the pictures, the screen turns black and i cant turn the camera off unless i pull the battery
What name brand memory card do you use? I recently discovered myself that Nikon only supports SanDisk, Toshiba, Panasonic and Lexar. Try taking out the memory card and take pictures without the memory card inside the camera. If you can view the picture saved onto the camera memory then you will know that all you need is a new memory card, with one of the above mentioned name brands. Hope this helps.
Mar 01, 2011 | Nikon COOLPIX S60 Digital Camera
I have a Nikon Coolpix L19, and I was wondering whether it can be used as a webcam. If yes, how?
No. The L19 is designed to store images and videos to memory, not to stream live video to another device.
Oct 01, 2010 | Nikon COOLPIX L19 Digital Camera
I can't on or off my l19 camera and the lens is always coming out.display is blank.
Issue with Ic Prologic.. Fail to initiate ..Camera got drop.. Board defect need service ... Try To...Take Battery off for 5min then put back on the battery then try to set date & time ..Sometime your have to set date and time before the screen apear ...if it so change your Battery memory inside the unit check on the main door battery for slot mini battery for memory
Sep 30, 2010 | Nikon COOLPIX L19 Digital Camera
Why does my camera Nikon COOLPIX L19 Digital Camera turns off when i plug it into the computer
it's still got it's files in the computer, chances are it's either checking the files or saving battery life
(let me know if this helped)
http://finnsharp.daportfolio.com/
Apr 18, 2010 | Nikon COOLPIX L19 Digital Camera
Problems Importing to Computer
maybe you are using the wrong cable i have done that befor.
Nov 01, 2009 | Nikon COOLPIX L19 Digital Camera
Transfer pics to computer
Hi there!
You dont need anything else actually. When you connect the usb cable and turn on your camera the OS on your computer will find your camera, then it will ask you what you want to do, select to open the folder on your camera, now you will see all the pictures on it, mark and copy the ones you want to move to your computer, go to the folder on your computer that you want to store them and past them in there. Thats all there is to do.
Good luck to u
Nic
Aug 11, 2009 | Nikon COOLPIX L19 Digital Camera
Screen black in all lighting. Icons and menu show and can view photos already on card, but screen black in all modes. Can take picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank:
• Camera is off.
• Batteries are not correctly inserted or battery-chamber
cover is not properly latched.
• Batteries are exhausted.
• EH-62B AC adapter (available separately) is not properly
connected.
• Camera is in sleep mode. Press shutter-release button
halfway.
• Monitor is off.
• USB cable is connected.
• AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode.
• Red (!) lamp flickers: flash is charging.
• Green (AF) lamp flickers: camera unable to focus.
• Message "CARD IS NOT FORMATTED" appears in
monitor: memory card is not formatted for use in your
camera.
• Message "OUT OF MEMORY" appears in monitor:
insufficient memory to record picture at current Image
mode setting.
Dec 02, 2008 | Nikon Coolpix 4600 Digital Camera
Camera stuck when using memory card
hi, i had a problem with my camera where i put in memory card and it said 'out of memory' i took the card out turned on camera went to set up mode and found one that said 'rest to factory defaults' pressed that and then put card in and all ok, might be worth a try :-)
Mar 13, 2007 | Nikon Coolpix 3200 Digital Camera
Cameras Logo
32 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
