Kids turned vizio to rgb mode without a computer hooked up stayed that way for an hour or so and is now stuck in this input mode, i have unplugged, tried hard reset, etc..etc..no buttons are responsive. I saw you answered a post like this a while back, was looking for further details...you said hold input button, i have held it down while tv is on, while it is unplugged etc i get no response, can you ellaborate or provide any additional methods that may work..?
stonephoenix
  • 563 Answers
SOURCE: Vizio VX32L The screen goes white,no response from buttons
G'Day!
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Jul 28, 2009
  • 8457 Answers
SOURCE: On/Off blue light blinking, TV won't come on.
Ur power ic inverter board is dead.
U need new one.
Posted on Aug 19, 2009
Testimonial: "Thanks for the advice. Will try it."
  • 60 Answers
SOURCE: Toshiba 42HL196. Will not
Replace the digital/siene module
Posted on Sep 13, 2009
SOURCE: what is rgb mode?
help
Posted on Sep 29, 2009
  • 3 Answers
SOURCE: 42" LG 42LC7D LCD TV stuck in demo mode?
Did you have any luck? My LG is stuck in demo mode too. Menu button doesn't work, and keylock was on as default so I can't use the buttons on the TV itself.
Posted on Nov 30, 2009
Vizio e370vl 37" LCD TV powers off by itself. It comes on, displays Vizio logo white, then turns off and goes to yellow. We tried unplugging everything for 5mins. Tried changing inputs, no RGB cable c
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Dec 25, 2017 | Vizio E370VL 37 in. LCD HDTV
Have a Vizio VX37L that when it is turned the
HERE'S THE FIX: I just went through this with my Vizio VX37L. TV is stuck in RGB input. This is the fix.... TV is stuck in RGB input.
(option 1) Power on TV, and press the INPUT button repeatedly and rapidly until you can change to a different input, such as AV.
If that doesn't work, try:
(option 2) With the TV off, press and hold the INPUT button on the side of the TV for about 5 seconds. The TV should power on and the input list will appear. The TV will no longer be locked, and the INPUT button should function properly after that.
Option 2 worked for me!
Jan 24, 2010 | Vizio VX37L Television
TV displays RGB code and then displays, no signal and then shuts off. What does the RGB code mean?
It means the source is not set correctly. Switch the source to input 0 (cable or antenna depending on your particular set up).
http://www.vizio.com/l32hdtv10a.html#support
Will lead you to the manual and quick start information if you need more specific instruction.
Joe
Jan 03, 2010 | Vizio L32 32 in. LCD HDTV
TV will not get off the RGB Screen
I just talked to a tech and fixed mine. unplug tv and hold power button for 1 minute. this drains the compasitors, sometimes they get over charged. if that doesn't work. with tv off hold down input button until tv turns on . it should work. here is tech support # 714-668-0588
Aug 27, 2009 | Vizio VX42L 42 in. LCD TV
While trying to change channels, my t.v. displayed ''no signal'' and then shut itself off. Now, when I turn it on, it says no signal and turns itself off after a few seconds.
Turn the television on and as soon as the screen turns on repeatily press the input button or change the input to whatever input you are using from a source device. As long as you change it to anything other than RGB.
Your television is essentially a big computer monitor with multiple inputs and a tuner. When using your computer and shutting it down the monitor will go in a power save mode. You don't need to shut off your monitor due to this power saving mode. When you power up your computer your monitor automatically turn on.
With the VIZIO and the RGB (computer) input the television will act just like a computer monitor. When you have a computer connected it will power down automatically when you shut off your computer. When you turn your computer on the VIZIO will automatically come out of standby mode. This is through RGB only.
This is normal operation for the VIZIO but can see confusing when nothing is connected to the RGB input. If you change your television input to RGB it will sense no signal on the input and will go into standby mode after about 5 - 10 seconds. If you were to send a signal to the television through RGB it would automatically kick on.
Apr 05, 2009 | Vizio L37 Television
TV will not stay on.
MIne did this at first. Unplug from source for 2-3 minutes, then try again to turn on. Should come up then.
Apr 03, 2009 | Vizio L6 20.1 in. HD-Ready LCD Television
No signal
mine did the same thing...it was on rgb...didn't have ability to plug in computer to tv as suggested previously and I kept trying to hit input button on side of tv after turning tv on..didn't work but when I pushed input button before turning on tv when i turned on tv input screen was up and was able to move input to hdmi...everything works now.
Jan 04, 2009 | Vizio L32 32 in. LCD HDTV
Blue screen - no signal - turns off [visio tv L42hdtv10a]
With out turning on the T.V., Push the [Input] button on the remote control. The TV should turn on and activate the input menu, just continue to push [Input] until it is set on TV (or HDMI, etc.). this should solve your problem.
Oct 29, 2008 | Vizio GV42L 42 in. LCD Television
42 inch LCD Vizio. "no signal"
Just hold down the input button on the right side of the tv. This is the bottom one. So,
With the tv off,
press and hold the bottom button (input)
when the tv turns on, and you see the input menu
release and press the button to put the tv into a mode that works!
Thanks
Apr 15, 2008 | Vizio GV42L 42 in. LCD Television
T.v. will not stay on
Power on your TV and press the INPUT button on the side of the TV repeatedly and rapidly until you can change it to a different input, such as AV.
If this does not work. Try this: With the TV off, press and hold the input button on the side of the TV for about 5 seconds. The TV should power on and the input list will appear. Let me know if either of these work.
Nov 14, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
173 people viewed this question
Top Televison & Video Experts
