Question about NexxTech N600D DVD Player
Screen indicates "Wrong Disc" for every disc - NexxTech N600D DVD Player
  • ricky845 Sep 02, 2010
    The lens was cleaned using both a cleaner and with alcohol and a Q-tip. Neither produced a change. The screen still reads "wrong disc".
    Replacement of the lens assembly is not an economic option due to cost.
    Both solutions were helpful.
  • NexxTech Master
  • 11,800 Answers
The dust has been baked directly on the lens by the laser - this is unfixable, the laser head should be replaced. Try to find a defective unit and recover its laser head , otherwise the unit is good for the skip, junk it and buy a new one.
Posted on Sep 02, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. It seems that the lens is unable to read discs. To start with try running a lens cleaning disc, if that does not work then you have to open the unit and clean the lens with a Q-tip dipped in alcohol. If still the issue is not resolved then the lens should be replaced however, replacing a lens will cost you around $75 and a new one will cost you around $50. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 01, 2010
  • Rylee Smith
    Rylee Smith Sep 02, 2010
    If thats not an option then consider buying a new one.
I got a 765 phi lips cd recorder player and every time i put a digital audio cd to rec it indicates no disc but the right tray plays perfectly what can i do it is a very important material for my work plz...
make sure check your manul for the correct disc it could say digital audio,but look carefully on disc for scratches or dust clean lens and check disc for cd-rw or cd-r digital audio i had the 770 and have the same problem and i kept buying the wrong disc.
Jul 30, 2011 | Philips CDR775 2-Disc CD Recorder
How do I format a DVD+RW disc?
Hello and Welcome to FixYa!
Here are the instructions for formatting DVD+RW discs.
  • Locate the CD-ROM drive door on your computer. The location of the drive depends on the computer you have. You will see a small rectangular button on the door.
  • Press the button and the drive door should slightly open. Lightly pull the door open and insert the blank DVD-RW disc into the drive. Close the drive door and wait for the computer to detect the disc, which will trigger an "Auto Play" screen to flash on the desktop's taskbar. The screen will prompt you to choose an action you'd like to perform for the disc.
  • Click "Burn Files to Disc: Using Windows." This link will redirect you to your Windows Explorer disc burning application. You will be prompted to enter a title for the disc.
  • Enter the title of your choice in the form and click "Next." The last screen will ask if you'd like to continue with the formatting; click "Yes" to continue. The "Elapsed Time" screen will appear indicating how long the process will take. When the process is complete, another screen will automatically appear indicating the formatting process is complete.
  • Click "OK" to continue. Your Windows Explorer panel will appear. In the upper-left corner of the panel, you will see a horizontal menu bar with different options for the disc. Now your disc is formatted and you can begin burning files to your disc.
    Have a nice Day,
    Concerned.
  • Jan 28, 2011 | Roxio Easy CD & DVD Burning for PC
    On my Satellite 1415 S-173 laptop, I need to run the Toshiba recovery disc set. I have changed the bios to start with CD-ROM. However upon starting with the cd with recovery disc in, I get the welcome to...
    you may have been given a wrong cd its possible but if you have the reciept where you got it from then you maybe given a free recovery disc or look on the internet for a recovery program what you can burn to disc thanks.
    Mar 31, 2010 | Toshiba Satellite 1415-S173 Notebook
    When I put my disc in it loads...then it displays
    Wrong disc usually indicates a problem with the lens mechanism of the DVD player. It can be dust/lint blocking the path of the laser there by preventing it from reading the disc or it can be a mechanical problem like lens out of alignment. You can attempt to clean the lens using a lens cleaner CD/DVD with liquid and see if it resolves the issue(you can get one for as low as 5$). Perform a dry cleaning first(without the liquid) and then with liquid(two drops on the brushes of the lens cleaner DVD that pop-up after the dry cleaning run. If it doesn't resolve the issue then you may have to get the lens mechanism checked by a qualified technician. You can search the fixya repair directory to find one in your area.
    http://www.fixya.com/repair
    Oct 12, 2009 | TruTech TT320
    TV screen says wrong disc
    I am try to play a movie and it says wrong disc
    Jun 30, 2009 | Memorex MVD2042 DVD Player
    Disc indicator flashes
    lens problem
    clean the lens using a lens cleaning disc
    Oct 21, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
    Wrong Regional Disc.
    DVDs are ecoded with region codes to indicate what area of the world they are made for. These codes may be 1,2,3, etc depending on which region they are made for.
    DVD player read these codes and if the disc region code does not match the region the device is made for, the player will not play the disc.
    Region 1 is for USA so most DVDp players made for use in USA require region 1 discs.
    Some DVD players called multi region DVD players can be set to play different region DVDs but they are typically more expr=ensive then one region players and the code must be changed each time a different region disc is played.
    Aug 27, 2008 | Audiovox D1710 Portable DVD Player with...
    No Disc Signal
    That one disc is damaged or in the wrong format
    Aug 09, 2008 | Philips Magnavox DVD/VCR Dual Player
    Panasonic Camcorder
    thats an indication that no disc or wrong type of disc is present. Have you tryed to clean the laser lens>> or using the approved lens cleaner for this unit?? try it and see you may be surprised. good luck
    Apr 25, 2006 | Panasonic PV-DV53 Mini DV Digital...
    NexxTech N600D DVD Player Logo
    85 people viewed this question
    Top NexxTech Televison & Video Experts
    jasbo
    jasbo
    Computer Repairing
    Computer Repairing
    Tygh Duval
    Tygh Duval
    Are you a NexxTech Televison and Video Expert? Answer questions, earn points and help others
