Question about Belkin Computers & Internet
Can't Connect my Belkin router FSD7230-4 to the internet. I can connect to my new ADSL service when my computer is directly connected to the modem. When I'm going through the router it's not establishing an internet connection. Accessed the 192.168.2.1 site and after changing the connection type to PPPoE and entering my ADSL user name and password the Internet Connection Status changed from Not connected to Connected, but it's still not connecting. My computer uses Vista. The Vista Network and Sharing Center guesses that there may be a DNS issue. I received suggested Primary and Secondary DNS paths, to be used if the modem needed configuring, in the documentation for the ADSL connection. I tried entering these into the Primary and Secondary DNS in the router's settings but was not successful in getting internet through the router. Can someone please suggest how I can get the internet working through the router?
There are several reasons that this could be happening. Sometimes the DSL modem can be the cause. If it is configured incorrectly then it will not be setup to work in a routed bridge mode (what you need for it to work with the router). Easy fix for this: press the "reset" button in the back or bottom to set the modem to default settings then power cycle everything. Second, on your computer go to network and sharing center and find your adapter settings. right click on your Ethernet or wireless adapter (whichever you use to connect) and go to properties. Go to the TCP/IP protocal properties and check that everything is set to obtain its data automatically. Last thing to double check: Call your ISP and just verify the ip, login info, and DNS info are all correct. I have had an ISP give me the wrong DNS info before on accident and after several hours of troublshooting I called back and a different guy answered and told me that my DNS was wrong. I changed one number and POOF! Fixed! You can find more help for this at www.attivia.com or email us at support@attivia.com.
Posted on Sep 03, 2010
MR814 does not get IP address from my ADSL modem
try power cycle modem to clear out the computers onfo then it should connect to the router
Aug 10, 2012 | NetGear MR814 Wireless Router
I have a DSL502T ADSL Router,and have bought a new emachines computer. I can not connect to the internet. The computer has a wireless connection loaded but I want to connect by dailup Please could you help...
You are a bit confused with the various components required for Internet connections.
If you have a dial-up connection with an Internet Service Provider, all you do is connect your computer's modem port to the phone line and dial the phone number of your Internet Service provider.
If you are connected to the Internet Servise Provider by ADSL and have a combined ADSL router and modem then you connect the phone line to this router/modem. If the ADSL modem is separate component then the phone line is connected to the ADSL modem and this modem is connected to the router with a LAN cable and the computer is connected to the router with another LAN cable. If the route is wireless and the computer has a wireless card then you don't need a LAN cable between the router and the computer.
If you are connected to the Internet by ADSL, to secure your Internet connection and configure your computer so it can connect to the Internet, please follow my instruction - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 17, 2009 | Computers & Internet
New Belkin router wont connect to internet.
your user name and password have been entered incorrectly, they are case sensitive and must be exact. Make sure your ADSL settings are set at 0/38 (you'll see where)
Nov 12, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin router is unable to connect to 2Wire ADSL modem/router. 2Wire router has DHCP server enabled and Belkin has DHCP server disabled. Belkin is set to obtain an IP automagically. 2Wire IP is...
If the Internet light is off then there is a problem with the phone line to the ADSL modem or the modem is faulty or there is a problem at the telephome exchange.
Disconnect the phone cable at the ADSL modem and connect a phone handset to this cable - check for a dial tone and that you can dial out.
If you don't get a dial tone, use a different or new phone cable.
If the phone line is OK then : -
Ring your ISP to get them to test your connection to your ADSL
modem.
Oct 17, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
I'm having issues with the belkin F5D7234-4 and intermittent connectivity with the network, i'm running a compaq c502tu and the belkin G/G+ router, which the router is hooked up to a general custom built...
Of the Belkin Modem Routers I have used and supported, around 60-70% had connectivity issues.
If the Belkin was cabled there appeared to be less issues than if it was used in a Wireless and cabled capacity.
I suggested to another person only moments ago to quickly sketch a diagram to show, how the network is set up. Add labels to the piccy's which provide the following info:
1. Computer Types (Makes, Models) and OS (Vista, Windows7, Leopard etc...)
2. Connection Types (Wireless / Cabeled).
3. The IP Nos.
4. Modem Types (Make, Model). ie, Belkin F5D7234-4 Router.
5. ADSL or ADSL2.
If it is possible to upload the diagram to FixYa then I suggest you scan the diagram (sketch) or take a photo of it and put it on the computer so it can be uploaded to FixYa.
I only discovered FixYa yesterday and joined, so I am not sure what is possible yet, as I have been focussed on trying to find solutions or provide suggestions on where to find the solution.
I would be proactive and submit your problem directly to Belkin via their website, I have provided the Australian Belkin website link below:
http://en-au-support.belkin.com/
I hope this is helpful to you, please rate it. Regards,
Sep 26, 2009 | Belkin F5D7234-4 Router
Belkin Wireless G Plus MIMO router - connectivity problem
Connect one computer directly to the DSL modem using an Ethernet cable. If your DSL service includes a static IP address, then you will need to change the TCP/IP settings on your computer to connect directly to the DSL modem. that the router or other device on your network . For these you need to follow thse steps.
Belkin router blinking orange FIX belkin router amber light Issue
This may help you.
Aug 10, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Can't get a wireless connection on Belkin F5D8636
http://en-us-support.belkin.com/app/answers/detail/a_id/3180
check this link
Feb 21, 2009 | Belkin (F5D8231-4) Wireless Router...
No internet connection
I received this solution from Belkin. It worked for me & I hope it does for you. Good luck!
Belkin solution:
Please follow the details given below:
1. Please contact your internet service provider to know the connection type details (Is it PPPOA,PPPOE, Dynamic or static)
2. Belkin router F5D8633 ADSL router works only with ADSL broadband connection and does not support Cable broadband connection.
3. Do not use the Setup CD Assistant; reset the unit and configure it manually. Make sure to set the correct VPI/VCI values in the process as the default settings may not be correct.
4. When using PPPoA, always use VcMux encapsulation, when using PPPoE, always use LLC encapsulation. Keep the VPI and VCI as 0/38.
5. Please follow the instructions given below to configure the router manually:
- Connect the phone line direct to the router, or through the filter.
- Connect the computer to one of the LAN ports on the router.
- Switch off the router and power it back after 5 seconds.
- Restore the router to factory defaults by holding down the reset button on the back of the router.
- The power light will flash and then come back ON solid, indicating that the router is being restored to factory defaults.
- The corresponding lights on the router should be lit-up.
- Check if the computer has an IP address in the range of 192.168.2.x
- Click on `start` & click `Run`.
- Type in `cmd` & click `ok`.
- Type `ipconfig` and Enter. Check for IP address, subnet mask & Default Gateway.
- If not, specify a static IP address, gateway and DNS by following the steps at http://web.belkin.com/support/kb/kb.asp?a=2824
Then follow the below instructions to reset IE.
-Open Internet Explorer
-Click on Tools -> Internet Options
-In the General tab, click on Delete Files under Temporary Internet Files
-Click on Clear History
-In the Connections tab, select Never Dial A Connection and click on LAN settings
-Uncheck all the options and click on OK
-In the Advanced tab, click on Restore Defaults
-Click on Apply and then OK.
- Open a new Internet Explorer window and on the address bar please type in http://192.168.2.1 and click on go.
- You should be able to access the routers set up page.
- By default the password is blank.
- Click on Connection Type and Reconfigure the connection on the router (using your ISP details).
- Save the Changes.
Note: Please obtain the correct values regarding the Internet connection from your Internet Service Provider.
Internet Status should show Connected on the top right hand corner of the web page.
If the problem persists, please get back to us with the following information given below:
1. Type of connection provided by the ISP (Is it PPPOA,PPPOE, Dynamic or static)
2. The ADSL light status on the router. Please let us know if the ADSL light status on the router is solid or flashing.
3. ADSL broadband connection or Cable broadband connection.
4. Operating system on the computer and the version number for the internet explorer like IE 6 or IE 7.
5. Internet Status shows as Connected or Disconnected on the top right hand corner of the router web page.
Log on to the router web interface at http://192.168.2.1
- By default, the password is blank.
- Click on Security log under "Firewall" option (let us know the message you see under the security log or send us the screen short of the message you see under the security log)
6. Then, check the IP address of the computer. For checking the IP address:
- Click on start & click `Run`.
- Type in cmd & click `ok`.
- Type IPCONFIG and Enter. Check for IP address, subnet mask & Default gateway.
- The IP address should be in the range of 192.168.2.x (x=2 to 254)
- In the command prompt type PING 192.168.2.1 & Enter. Check if you are getting replies.
- Type, PING 4.2.2.2 & press Enter. Check if you are getting replies.
- Try pinging yahoo by typing PING yahoo.com and Enter. Check if you are getting replies.
Dec 28, 2008 | Belkin N Wireless Modem-Router F5D8633au4A
I am replacing BT 105 modem with a Belkin adsl2 modem with wireless g router. The 105 has a blue cable with a square connector. I tried to put the yellow supplied cable in the back of my computer but it...
no, but you need to configure the router to connect to the internet, you should have a "quick start guide" that will help you connect to your router and set your ADSL dial settings (as it needs this to connect you to your internet service)
once these connection settings are set you should be able to connect to the internet
you can then explore the other settings including the wireless configuration of your router
Oct 03, 2008 | Belkin Computers & Internet
Belkin Wireless Router won't connect to ADSL
Turn off your modem and your router. Turn your modem back on wait for 2 mins then turn on your router. Try to connect. If that does not work. Connect your computer to the ADSL directly and check if you can get on. if not call your ISP.
Jul 27, 2008 | Belkin (F5D5231-4) Router
Computers & Internet Logo
112 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
