Question about Radio Shack (43-3829) Digital Answering Machine
Had a power outage and need to reset time,day,and greeting. serial no. 90902328
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Radio Shack Master
  • 102,366 Answers
The instructions are on the second column of the manual at
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/4303829_PM_EN.pdf
Posted on Aug 12, 2011
Power interruption and now my plug,n go seems to be frozen. Cannot set time or clear anything. Screen reads 9.80 or something close
I had a similar problem with my Bosch wall oven after a recent power outage-restart-outage-restart cycle that lasted only about thirty seconds altogether. The difference would be in that while I could reset all the things like day, date, time, etc., the oven would arbitrarily go off on its own and make up the day, time, date, year, etc., with no apparent correspondance to reality. Here's what I did: I completely shut down the oven at its outside breaker (you will need to do whatever it takes to remove the power from the 'plug-n-go'). I waited five or ten minutes before turning the power back on and resetting the various items. Two days have passed and there have been no more mind-of-its-own excursions into another time zone. Problem solved, unless/until another power outage cycle comes along. Hope this helps, or at least gives you an idea about where to start.
Dec 15, 2014 | Hardware & Accessories
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
Our 2006 Samsung Microwave has suddenly ceased to heat anything. The clock works and the turn table goes around, but that's it. We had a couple of power outages just before this happened. Could it be...
Press the "Off/Clear' button to cancel anything on the display, and reset the microwave. This is a soft reset and will simply get you out of any program you have started. Press it when the cooking complete reminder appears on the display.
Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the GE microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock.
Nov 29, 2010 | Samsung Microwave Ovens
We have lost power a couple times this week and our system had reset, losing our third line and voicemail greeting will not prompt when suppose to. We still have out greeting, it is just not picking up.
What type of System is it? Norstar systems default to 2 lines if they loose memory (which isn't supposed to happen). That being said, I recently had had to replace an old Norstar 616 that would not hold memory after a power outage. I took the KSU apart and could not find any internal battery to replace. I'm guessing some kind of capacitor ?? In any case the system had to be replaced. Bill C. www.dyna-tech.us We also do remote programming on Norstar CICS ans MICS.
Mar 26, 2010 | NorStar M7310 Corded Phone
Air conditioner compressor runs for about 1-2 min, then cuts off
well when u have outages the voltage drops obviously, the one that suffers are the capacitors the capacitor for the compressor might need to change, change it with the same capacity as the old one example if labels say 55 microfarady ( mf ) ( 55 mf ) get one of the same I am not saying it is a 55 mf capacitor vary depending on motor and brand. So check the label
Jul 23, 2009 | Danby Portable Air Conditioner
Reset after power outage
You just need to reset the time to fix this problem. There were three buttons on the back of the base for the day, hour, and minutes. I didn't know they were there!
Sep 07, 2008 | Uniden Cordless Phone
Cl flashing on display
You need to reset the time after a power outage.  Press the Day/Check, Hour, and Minute buttons until the correct time is heard-- Press Day/Check until you hear the correct day announced. Then do the same with Hour, and then Minute.
Jun 01, 2008 | Motorola Mobility MD761 Cordless Phone
Uniden vtech phone
Hi I found the manual after days of searching
Just had to hold greeting down record message then press set. Easy as that, dont know how my one year son managed to do this.
Feb 07, 2008 | Lands Phones
Radio Shack (43-3829) Digital Answering Machine Logo
Top Radio Shack Lands Phones Experts
ismael castillo
Are you a Radio Shack Lands Phone Expert? Answer questions, earn points and help others
