Question about New Home Sewing Machines
The light is coming on but machine is not working where can it be repaired in Glasgow area?
  • 340 Answers
Try contacting these sewing machine specialists for help or advice.
http://sewmac.co.uk/
Posted on Sep 01, 2010
We replaced the bulb and it doesn't work
If a new bulb does not work, then it is most likely something else, perhaps the wiring or a connection. You can probably have your machine serviced to get it fixed, or go purchase a light that you can place close to your machine to light the sewing area. There are lights available with attachment clips and a bendable neck that well let you get the light in the right spot. There are also strings of LED lights available on eBay that you can attach to the upper part of the throat to light the work area. I replaced my regular sewing machine bulb with an LED bulb and was surprised how much better it lights.
Oct 30, 2015 | Sewing Machines
When I turn on my pfaff only the green lights and light bulb come on. Display area does not and the foot petal does not work. Witch board do I need and where to get one? Thanks
PFAFF Mail-A-Repair Garry's Machine - YouTube
? 10:15
www.youtube.com/watch?v=x1CmpFRr8OU
Apr 20, 2010 - Uploaded by kennsplace Ive been working on sewing machines for the last 18 years. ... a used pfaff 2022, and it works great, except that reverse does not work. When I ...
Sep 19, 2015 | PfaFF Sewing Machines
Sewing machine not working
have you cleaned under the needle plate for lint
also in the bobbin area for lint or loose threads
make sure the bobbin is inserted correctly into the bobbin case
make sure the bobbin is not warped
try changing the needle
try rethreading the machine top & bobbin
if none of these suggestions work,, then it will be a good idea to
have the machine checked at a repair shop
Aug 24, 2012 | Sewing Machines
Singer confidence 7463 all lights flashing
try
clean under the needle plate & in the bobbin area for lint or thread
make sure bobbin is inserted correctly & that it's not damaged
May 20, 2012 | Singer Confidence 7463 Computerized Sewing...
I have an Esante ESI-2 sewing machine which has always worked beautifully. But now it has become so stiff that it is difficult to even turn the balance wheel. I have thoroughly cleaned the lint and...
Probably thread wrapped round the upper needlebar area, which has migrated into the bearings of the take up lever and balance. Pretty major surgery required to make the machine whole. Imminently worth it as an esante is a great machine. Take it to your local sewing machine repair person, preferably a Babylock dealer but any competent repair guy should know and recognize this problem. It's a bit like a major overhaul repair on an automabile but should still not cost much more than $100...the machine is worth much more.
Sep 27, 2011 | Baby Lock Esante
Viking Designer SE that sometimes will not turn completely on - the lights just flicker but no full start? Anyone have this problem or have solution that might work without taking the machine back to...
I am having the same problem with my SE. It recently started doing that. Sometimes it would come on, sometimes not - just flicker. I haven't been able to get it to turn on for 2 weeks now. I earn $ with my machine, so I am really upset! No Vik dealer around to get it fixed either...
Jan 18, 2011 | Husqvarna Designer I
I really need somebody to look at my sewing machine i dont really know what happen to it. I let somebody borrow it and it dosn't work now. Where can i go for a repair? I try some repair stores but they...
Call Brother at 1-877-276-8437 and they can tell you who their service center is in your area. Or go online and see if they list one for your area at brother-usa.com
Sep 05, 2010 | Brother CS-8060 Computerized Sewing...
Machine locked up and makes a beeping sound it is a Singer 7444 the hand wheel is frozen
There may be thread caught in the bobbin area.
Turn off the power and check the manual for maintenance.
Once the area is clean and the bobbin case back in place, turn the machine back on.
If this does not resolve the issue, the machine will need an authorized sewing machine tech to repair it.
Mar 13, 2010 | Singer 7444 Mechanical Sewing Machine
I have the Brother SE270D and when I was winding the bobbin the thread somehow slipped under the bobbin and was wound around the peg under the bobbin winding area. I thought I could remove the screws and...
You can either take the machine in for repairs or, use another sewing machine (if you have one that uses the same type of bobbin) for bobbin winding or purchase a Sidewinder Bobbin Winder - search the Internet for the best price.
Mar 02, 2010 | Brother SE-270D Computerized Sewing...
Simplicity Serger SL370 - Motor runs but it doesn't sew
Years ago I had the same problem with a sewing machine. Took it to a repair shop which cost me $25.00 for the fix. Asked the repairman what he did and was told that he exposed the bottom of the machine and sprayed the entire area twice with wd-40.
May 12, 2009 | Simplicity SL370 Mechanical Sewing Machine
Sewing Machines Logo
Top New Home Sewing Machines Experts
Tally Girl
Tally Girl
Nava Hirshenson
Nava Hirshenson
Level 1 Expert
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
