Question about Toro 42 In 22 Hp Kawasaki Vtwin Hydrostatic Zero Turn Tractor
PTO clutch rattle at low rpm and idle, Toro Z4235 22Hp kawasahi.
4 Suggested Answers
backwoodsctr
  • 169 Answers
SOURCE: Toro 265-6 model 72045 PTO clutch will not engage.
ohm out the clutch......should be 2-4 ohms any less means the clutch has an internal short and will need to be replaced. also check the saftey interlock module, however the modle numbers u gave do not come up, relays checked ok? how did u test them?
Posted on Nov 18, 2009
  • 1169 Answers
SOURCE: I have a Toro LX 500 Lawn tractor the pto clutch will not engage, I have 13 volt at the plug for the clutch , so ordered and installed new clutch... Still will not engage checked volts again had 9.3
Load test the PTO circuit as it may a connection that allows you to a voltage reading when unload and then once loaded drops out.
By load testing I mean leave the PTO clutch coil attached and test while it should be engaged.
Posted on Apr 22, 2015
  • 42218 Answers
SOURCE: Toro ss5000 model 74630 50" deck Mower loosing power after mowing for about 10min. I shut the pto off than the mower star running on idle as soon I engage pto the mower sound want to turn off.
the charging system is not adequate to run the ignition and the electric pto
check charging rate and voltage regulator
Posted on Apr 22, 2017
Toro 11-32 won't start.new battery. i jump the terminals it fires right up. 2nd problem is the deck won't engage I hit the switch and nothing I leave the seat it shuts off when engaged
Check and see if the Engagement termnal on the solenoid is getting power. If it is replace the solenoid.
As for the PTO check for at its connector for voltage. If voltage is there check for about 1.7 ohms resistance across pto coil. If it reads infinity or less than 1.5 ohms replace the pto clutch assembly.
If the pto reads less than 1.5 and there is no voltage at the connector than the pto switch is probably burned up due the shorted pto.
May 14, 2015 | Toro Garden
PTO Clutch will not stay engaged.
There is a very fine one page discussion on evaluating electric clutches at this site:
http://www.messicks.com/Articles/FixingElectricClutch.aspx
My JD tech manual, which covers the entire LA 100 series, agrees with the electrical specifications. It states that the Electric PTO Clutch should show the following:
  • Resistance 3.7 ohms
  • Current Draw 3.25 amps.
It does not give the air gap. It does include a note to check the PTO Clutch Key for damage or if missing. So there is a drive key between the PTO Clutch and the shaft. Additionally, it recommends checking the tightness of the cap screw. That's the screw or bolt that holds the clutch on the shaft.
  • Cap Screw torque 55 lb-ft (75 N.m).
Fixing Electric Clutches
Apr 21, 2015 | Toro Garden
Toro repair manuals
I have this same problem on my 36 in toro pro line sfs i ohmed the clutch the wire the safety switches and the PTO engagement switch all checked out good if u find any thing let me know the clutch its a adjustable clutch and its supposed to be set at .018 at all three springs there will b a slot that's where u check that but. U can get a multimeter and test the clutch by putting it on ohms and hooking up on both sided of the plug once u have unplugged it.the clutch should ohm out at like .003 or .004 max if more the clutch is shorted out
May 07, 2013 | Toro 52" Cut Wide Area Walk Behind Lawn...
Rattling noise sportage 2008
Sorry for the late reply but, no, it is not related to a loose heat shield. It is a louder rattling sound more like a loose bearing vibrating inside either the transmission or the clutch assembly. Only between 1600 and 1900 rpm. and it is not present under ou over these rpm. The rattle desappear when I lock the 4X4. Dealer is out of solution!!
Aug 06, 2012 | Kia Sportage Cars & Trucks
John deere 2210 engine dies when engaging pto, seat switch good
are you sitting in the seat or have you jumped the safety switch under the seat before you engage the PTO I believe our tractors use an electric solenoid to apply hydraulic pressure to a wet clutch inside the trans axle I would think it would be OK with your chipper I have a 450 tiller that was built for the older 400 models 425 445 455 that I now use with my 2210 If I hit a large root or stone when using it with my old 445 it would stall the tractor at full power. Now with the 2210 it will actually slip the clutch on the tiller s PTO shaft I think the correct approach would be to increase your RPM s gradually or start increasing the power just as you trip the PTO switch. You want enough RPM s to create enough hydraulic pressure to run the PTO circuit so that you don t slip the wet clutch anymore than necessary and you want the RPM s low enough so that you don t shock the mechanical systems too severely at start up
Let me know how it works
Feb 02, 2012 | Garden
Just replaced pto clutch brand new ,wont engage.nothing, zip not a movement.
Check that you are getting voltage to the wires that connect to the clutch when you switch on the pto. If not check that you are getting voltage to the pto switch. If you are the pto switch is faulty. Regards Phil
Apr 15, 2011 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Toro 265-6 model 72045 PTO clutch will not engage. PTO checked with 12V and works okay. Both relays checked and working okay. All fuses are good. Not sure how to check PTO switch. Any other suggestions on...
Nov 18, 2009 | Toro Lawn Mower With Toro Power Tools
Toro 42 In 22 Hp Kawasaki Vtwin Hydrostatic Zero Turn Tractor Logo
136 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
