Question about Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum
Yesterday, I removed a large amount of fish line from the head of the vacuum. I removed the line completely, Now I cannot get the vacuum cleaner to stay running. It starts running when I push the on switch, but will not stay running when I let go of the switch. Do the two have anything to do with each other?
    President:
  • 1,139 Answers
On the dyson the only thing that would normally cause it to stop running is an overheating problem. The fact that you have now removed the line from the vacuum head should have nothing to do with it. It sounds more like the switch contacts are faulty itself. I have found in the past that if you give Dyson a call they are quite willing to fix faults free of charge even if the hoover is out of warranty. Give them a call and see what they say.
Hope this helps and thank you for using FixYa
Posted on Sep 01, 2010
How can I remove the head/change the nozzle on unidentified vacuum?
Search Results
    DC28 Cleaner Head Replacement Removal - YouTube
    ? 17:19
    https://www.youtube.com/watch?v=yERbv8owKU4
    Apr 2, 2013 - Uploaded by AllVacuumBrandsCTN1
    DC28 Cleaner Head Replacement Removal ... Dyson DC28 Animal - King of Vacuum Cleaner For Pets Hair ...Missing: nozzle ‎unidentified
    Dyson DC24 - Replacing the cleaner head (Official Dyson ...
    ? 0:55
    https://www.youtube.com/watch?v=PeI8N2SuXkM
    Sep 29, 2011 - Uploaded by AskDyson
    How to replace your Dyson DC24's cleaner head. ... Our brush bar reset guide shows how to remove the ...
    How to replace a Henry floor tool on a Numatic ... - YouTube
    ? 0:47
    https://www.youtube.com/watch?v=AUEaFIIFmeg
    Apr 15, 2010 - Uploaded by eSpares
    For all your Numatic vacuum cleaner spare part go to http://bit.ly/1G0FaXS If you've cracked the floor tool ...
Jan 27, 2016 | Vacuums
Dyson DC07 leaves large dust marks on floor while upright
Hi Tracy, it's Jack at Dyson.
If dust is coming back out of your DC07's cleaner head, this suggests that the machine may have a blockage. It's also worth checking that the internal hose isn't damaged, and removing any threads or hair from around the brush bar.
The easiest way to check for and clear any blockages is to follow the steps shown in our online support guide: http://www.dyson.co.uk/support/dc07/dc07-standard/my-machine-is-not-working/my-machine-is-dropping-debris-from-the-base/loss-of-performance
If you haven't washed both parts of the pre-filter recently, it's also a good idea to do this. In normal use this should be done at least once every 3-6 months using cold water without detergent. Make sure both parts of the filter are completely dry before replacing them - this may take at least 12 hours.
This should resolve things, but if you have any further issues after giving these steps a try, please give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU) so our experts can provide further assistance.
Dec 09, 2014 | Dyson DC-O7 Bagless Upright Cyclonic...
Simac evt 100 steam cleaner
Try taking the steam head apart and cleaning. If difficult to remove, fill a basin with white vinegar & a small amount of water and let it soak to remove the built up deposits in the system. Remember to only use distilled water when steaming to avoid build up.
Mar 30, 2014 | Vacuums
Not letting out water
This caan be caused by hard water in the home or by using cleaners not made foryour model. turn the machine upside down and using a sewing needle poke one by one the little holes in the base where the water comes out, this should be the issue any other issues like a hose leak would cause large amounts to come out of the rear and a feed line broken would do the same.
Hope this helps you it did me!
Jun 13, 2012 | Bissell Carpet Cleaner Powerbrush Deep...
Dust and air coming from back side of vacuum cleaner
the bag of ur vacuum cleaner is full. thats y it is happening...
clean the bag of ur vacuum cleaner.
n check is there any blockage in the vacuum pipe, if any then remove that.
Oct 29, 2011 | Sharp Vacuums
Model UH60010, Series X12.0, Mfg code K09A. While attempting to use the hose and the extensions to clean shelves, my wife reported no suction. I removed the brush roller and the plastic piece just below...
There are six different reasons a vacuum can lose suction, a plugged vacuum hose, bad motor, full vacuum bag, or cracked or damage hoses. Purchasing a vacuum cleaner can be a costly expense while repairing the suction on the unit can be virtually free. Most suction loss problems on a vacuum can be easily fixed or remedied with common house hold tools and very little technical expertise.
If your vacuum cleaner losses suction, the first and easiest solution is to check the bag. If the vacuum cleaner bag is full suction will be greatly reduced and the unit will become ineffective. A vacuum cleaner works by passing air through the bag fibers leaving dirt and debris behind inside the bag. If the refuse bag becomes full, airflow is restricted, limiting the amount of air passing through the vacuum bag resulting in loss of suction. When replacing the vacuum bag always consult your owners manual to insure that the vacuum bag seals with the vacuum inlet hose. If your vacuum cleaner bag is not tightly sealed to the vacuum inlet hose you will decrease the air flow through the bag resulting in loss of suction.
The second and sometimes most common reason for loss of suction on a vacuum cleaner is a plugged vacuum hose. If the hose becomes plugged, air flow will become restricted. To unplug a vacuum hose detach it from the machine and inspect the inside. If there is a restriction in the hose, remove it with your fingers and replace the hose onto the unit. If the hose is long and the debris is hard to get too, a broom handle or other long object can be passed through the hose to dislodge the debris. Most vacuum cleaners contain more that one suction hose, so make sure to check each one by process of elimination. Another area that can become easily plugged on a vacuum cleaner is under the lower base of the unit by the roller brush. Large debris can get caught in this area and restrict air flow to the hose.
If your vacuum refuse bag is not full and the suction hoses are not plugged the next thing to check is the condition of the hoses. Many hoses are made from plastic which can easily tear or crack. If your vacuum cleaner shows signs of wear or are cracked they need to be replaced. Even the smallest hole in a vacuum hose can leak enough air to greatly diminish the suction potential of your unit. Replace your vacuum cleaner parts with OEM parts from the original manufacturer to ensure the tightest fit.
Most vacuum cleaners contain filters. Filters are used as a last line of defense to remove dust and smaller debris particles before the air is recycled back into the environment. If vacuum cleaner filters become dirty or plugged they also can decrease the amount of air traveling through the unit. Some filters can be easily rinsed with water whereas others need to be replaced. It is important to check your owners manual before rinsing a vacuum filter.
The last and probably least common problem for a vacuum cleaner to loose suction is a bad or failing vacuum motor. Over time vacuum motors lose power due to worn carbon brushes or long term damage. A vacuum cleaners worst enemy is moisture. If water or moisture is sucked into the vacuum motor it will greatly diminish the amount of suction the unit has. Replacing a vac motor can be a costly and time consuming ordeal. In some cases, replacing a vacuum motor can outweigh the cost of buying a new vacuum. Vacuum suction is measured in water lift which can easily be measured by using a water lift gauge. If the water lift measured in inches, falls below half the original water lift specifications for the unit, it is time to replace your motor. Most vacuum cleaner repair shops carry this type of equipment and can easily tell you if it is time for a new vac motor.
Jul 25, 2010 | Vacuums
Wont spray water on the carpet
Same Problem here- The hand piece works fine. Bissell 9500 ProHeat2X.
Both tanks full New Belt on the brushes I can not get cleaner/water to spary when trying to clean the floors.
I've taken my air-compressor and with low psi blown back to make sure teh lines are clear from the spary heads. Still not working...
Apr 17, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Machine will not vacuum up the water
Could be a few things
Look for suction at the head. Turn it on and cover the opening with your hand. You should feel suction. If not something is plugging it or one of the following.
You can usually see a clog as the cover is clear. Fish it out with the tool that came with the machine or fine a wire etc to do the job.
When you put the hand held cleaner in place you remove an insert from the front of the machine. This insert must go back when you change to the main carpet cleaner function.
It could be the lid on the dirty water tank is not on properly or is warped. This will cause a suction leak. If it is warped you can fix it with care. Use a heat source such as a blow torch just enough to soften the plastic and then bend it back into shape with pliers (it's too hot to touch). Be very careful with the heat to just soften the plastic enough to bend.
Adrian
Mar 01, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
I have a Filter Queen Majestic 360 and am having problems with the powerhead. There is a loud rattling noise in the powerhead, especially when I vacuum thicker carpet. I have replaced the motor, roller...
Hi there, as per your information i guess its a problem of power transformer. He can't supply the proper power in the motor & thats why the noise will come from the transformer. Thanks & waiting for your feedback.
Feb 20, 2010 | Filter Queen Majestic Canister Vacuum
Nedd power head wand for Fantom Model BPSRLC51
the best bet would be to look on ebay. the fantom line was discontinued
Jul 28, 2009 | Fantom Vacums Lighting Canister Vacuum
Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum Logo
19 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
