Question about OKI C9800hn Led Printer
Its saying reset drum basket, the waste toner is not being transported to the waste toner box. but have taken everything out an put a new waste box in. ?????
4 Suggested Answers
  • 97 Answers
SOURCE: My Oki C9600 Printer showed an error message,
940: Error
Waste Toner Transfer Error
The transfer mechanism of the
toner duct for ID is not operating
properly.
Check to confirm that the basket
assembly is in position (if it is
engaged with the gear of the
printer).
Check to confirm that the holder
magnet D contains a magnet,
and check the magnetic polarity.
Replace the HAL IC circuit
board.
Replace the duct assembly
toner.
Posted on Mar 29, 2010
  • 10406 Answers
SOURCE: its saying reset drum basket,
It is the "transport" of the "waste" toner-ink from the toner-cartridge along its path to the "basket" that is the problem.
Take a look for how the waste toner "moves" along its path; the path may be clogged.
Posted on Sep 01, 2010
richie24
SOURCE: I have an Oki ES3640 Pro, the problem is that
Try putting in a new one then pop the old one back in
Posted on Apr 16, 2013
Replace new toner and displeyd mesages "chesk waste toner box". i remove waste toner box and cleaned waste toner in drum unit. no result...
the top of the waste toner container must be cleaned 100% from the toner because it should be a light sensor that has to pass through it , if its spoiled with toner the light cannot pass through it ,so i recommend you to empty the waste toner container first and wash it with water and drying it well before using it again.
Feb 20, 2016 | Kyocera FS-2000D Laser Printer
Konica Minolta 2300DL waste box full message
remove the waste box you'll see blue knob and above there is a sensor now take a look at the waste box and find the place what goes between the sensor. you should cut off one side and clean the other sides and then use some invisible tape to fix the hole. and try again.
Place what goes between the sensor have to be clean. its not good idea to cut or remove the sensor at all because next time the box will be full you don't know that and it will brake your printer
Mar 22, 2008 | Konica Minolta magicolor 2300DL Laser...
What is CF60
CF60 indicates Recycle Toner Transport area lock. U need to take out the process unit, remove developer unit, remove drum, drum blade & recovery blade, disposed all waste toner, make sure the gear can turn properly. Then reassembly back everything.
Feb 02, 2014 | Toshiba e-Studio 232 Black and White...
Sep 01, 2010 | Office Equipment & Supplies
My Oki C9600 Printer showed an error message, Reset Drum Basket - Waste Toner Transfer Error. After removing and replacing the toners, drum and waste toner bottle a new message appeared, 940: Fatal Error....
940: Error
properly.
printer).
board.
toner.
Dec 21, 2009 | OKI C9600hdn Laser Printer
Copier ha a message that says replace toner drum.
It means that the internal drum unit is full of waste toner and that the drum is worn out too. The people at cannon made the drum unit to last when the waste toner internal compartment is full.
When you buy a new drum the instructions are in the box and very easy to install.
hope it helps
Mar 24, 2009 | Canon ImageRUNNER 1670F Copier
Toshiba e-studio550 service code CD1, PLEASE help me to fix the problem and if there is any service call to reset it, thanks
CD1 indicates Abnormal drum cleaning brush motor.
U need to perform followings:
(1)Check if the cleaning brush, recovery toner transport auger and recycle toner transport auger are not locked (no extraneous material or toner clod in both the toner transport sections at the cleaner unit and recycle toner unit.
(2) Check if the connector on the LGC board and connector pins are not disconnected.
(3) Replace the cleaning brush drive motor and recycle toner transport motor.
(4) Replace the LGC board.
Mar 09, 2009 | Toshiba E-STUDIO 550 Copier
Kyocera Printer C5030N
Remove the developer and toner cartridge from the front of your unit. This will allow you to take out your drum where your waste toner box is. Once you have your drum with your waste toner box make sure to detach the waste toner box from the drum. Take a damp linen free cloth and wipe down the inside of the drum unit where your waste toner box goes in. Now take your waste toner box and make sure to secure the waste toner box really well to the drum. This has to be in very tight or else the printer will not think that there is a toner box attached the drum and this error will continue to appear. Important thing is to make sure that the toner box is attached really well to the drum unit.
Oct 18, 2008 | Kyocera Mita FS 3800 Laser Printer
Copier
good day, it wont print, coz you must pul the waste toner out. and replace a new waste box.
Jul 21, 2008 | Ricoh FT5832 Copier
OKI C9800hn Led Printer Logo
210 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
