How do i restore my shuttle xpc glamor back to factory settings?
  • 90 Answers
SOURCE: New psu for Shuttle XPC SB81P won't work!
Try these:
Remove the PSU from the case.
Plug it to power.
Turn it on
Using a paper clip, short circuit the green wire pin with the the black wire pin on the 24 pins connector.
If the PSU fan start, remove the clip. The fan should keep spinning. That means that the PSU is working.
If the PSU is working, then the power up pins on the mother board might not be shortcircuited by the front panel switch.
Connect the PSU to the motherboard and to the power, turn it on. On the motherboard, locate the power up pins and short circuit them with the paper clip. If the computer powers up then there is a problem with the power on switch.
If the PSU does not start at all, return it.
If you can't return it, unplug from power, open it (warrenty voids!) and look for a fuse that looks like a one inch glass tube with metal caps. inside should be a wire. If the wire is broken, buy a new fuse in Radio Shack.
Hope that helps.
Posted on Dec 28, 2007
SOURCE: restoring my pc back to factory
turn off computer, when computer reboots, start tapping on the f8 key until the advanced boot option menu appears and follow instrictions.
lisa
Posted on Mar 21, 2008
  • 244 Answers
SOURCE: need to restore acer to factory settings
just boot from your backup disk. it will guide you to reload the Operating system (factory default).
FYI, if you haven't delete the recovery partition, you can use alt+f10 to reload. just press alt+f10 during boot.
Posted on Aug 01, 2008
  • 34 Answers
contact acer you can get there number from the website and they will let you purchase a restore disc for 15bucks
Posted on Aug 20, 2008
dapidc
  • 111 Answers
SOURCE: how do i restore my dell back to factory settings
If you mean BIOS setting, then enter the BIOS, choose Restore Defaults.
If you mean your windows installation, use the Operating System reinstallation CD from DELL (the green CD, for Windows XP). After operating system installed, use your driver CD (usually the blue CD from DELL). If you don't have the CD, please contact Dell support center to get the CD (charges may apply).
Posted on Dec 27, 2008
Reset cmos, doesn't switch on
Plug out your pc, hold the power button for a few seconds and then take out the battery. Then wait a few minutes and put the battery back in. This should reset your cmos. If this doesn't help then the problem might be a corrupt bios, defective psu, faulty cpu or memory.
Mar 17, 2014 | Shuttle Computer Shuttle Xpc Sn78sh7...
Hard disk led fix after 3-5mn and system freeze
With the items you say you have changed, the only other item that may be causing the problem is the power supply. The RAM would give an immediate fail, not wait a few minutes. The power supply on the other hand could have a faulty Capacitor in one of the output lines. Try a known good power supply.
Oct 27, 2012 | Shuttle XPC Glamor SG31G2 (SG31-G2-BK-V2)...
Glamor PC boot
Ask a question!!! we don't read minds!
Oct 15, 2012 | Shuttle XPC SD32G2 Barebone
My shuttle hangs up when booting. Both the blue and yellow activity light remain solid and the heat sync next to the cpu seems to get very hot. I have removed all peripherals, pci card and reseated ram and...
It's possible that the CPU is overheating. If you leave it alone for a while, the CPU cools down enough to boot, but will hang shortly because the activity heats it up. When it gets too hot, it won't even start. If you removed the heat pipe/radiator at some point in the past, you were supposed to clean up the old thermal grease and apply some new one. Make sure that your room temperature stay's below the mid 70s. Using the default cooling setup, the CPU can rise in temperature to the 60s (in Celcius) with the fan going all out. The CPU's life could shorten if it operates around 70 and fail around 90. Make sure that all the vents are free from dust for better ventilation. What I did on my XPC was to use 2 fans on the radiator: a quieter one on the inside (80mm?) to push and a larger one (120mm) on the outside to pull. I used a fan adapter to accommodate the larger fan. It was measured no higher than 55oC while playing DOOM3 with fans blowing at minimum speed.
Jul 20, 2011 | Shuttle XPC Glamor SG31G2 (SG31-G2-BK-V2)...
Location of cmos in shuttle
the CMOS battery is on the motherboard. it is the size of a quarter dollar, silver is color and it look almost the same like the watch battery
Dec 11, 2009 | Shuttle XPC SN41G2 (XPC-SN41G2-SHUT) PC...
Factory restore
You can export address book:
click File -> Export -> Address Book -> Seleck "Text file(comma separeted values)" -> select folder on your usb drive you want to save address book, click next, select what info about your contacts you want to export.
Apr 26, 2009 | Shuttle XPC SD32G2 Barebone
Shuttle XPC - fan on the back does not stop
I would suggest you have a fan with faulty bearing
and i thing the power supply could want changing
Sep 01, 2008 | Shuttle first SFF barebone with the power...
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
