Question about Peg Perego John Deere Gator HPX Ride on Toy
After charging, will only go slow w a small push. Does it need new battery or gear shift?
    President:
  • 670 Answers
It's unlikely the problem would be caused by a faulty gear shift switch. When you have a switch problem, it usually does not go or it runs intermittently. A new battery should fix your problem especially if it a couple years old, or you have not charged it up every couple of months to maintain the battery.
Posted on Sep 01, 2010
Can not get toyota cororlla out of park. would not turn over. battery good
Start the engine, depress the brake pedal, press the oval push button attached to the upper side of the gear lever stick and shift the lever to R, N, or D. It should work. If not check the following:
- Push button mechanism and the solenoid for malfunction.
- Brake switch assembly.
- Wiring harness.
You can also release the gear lever by pressing the small red button located on the base of gear lever stick. Simultaneously press the small red button and the push button of the gear lever stick to get it out from P.
Aug 05, 2013 | 1996 Toyota Corolla
Battery light, ABS light, and Oil light flashes on and off when driving the car. Dash lights,front marker lights, and tail lights will not come on until the car is warmed up.
Electrical problems are hard to fix. You need a voltage test for the charging system and a battery test.
The oil light, abs light, are not hooked up to the turn signals. Never heard of balance of lights coming on in that manner.
The heater fan, headlights, and wipers will slow if the charging system can not keep up. Battery light is accurate to show discharge.
Trans shifts can be affected by voltage. Some transmissions use electric solenoids to shift and they mix voltage to get different gears.
Jul 12, 2017 | 2002 Ford Escape
My battery is dead and I can't move the car due to the auto gear shift stuck in park. How do I move the car to get a jump on the battery?
if you look on the center council where the shift lever is you will see a small plastic button on the drivers. Remove the button. Insert a small screwdriver into the hole and push down. You will then be able to move the shift lever into nuetral and push the car.
Jan 06, 2012 | 1997 Toyota Camry
How do i on a motorcycle go to first gear from 5th
hi, if when you start your bike you press the gear lever down to go to 1st from neutral and then pull it back up to go to 2nd,3rd,4th and 5th then the only way to get back into first gear is to press the gear lever down 4 times to get it back into 1st gear their is no quicker way to do this you have to work your way back down the gears.
if your coming to a stop quick then just pull the clutch in and keep pushing the lever down until it dont push down any further it will only go down 1 gear at a time so you will need to push it down 4 times but you dont need to count you can just keep pressing it down the gears until it dont go down any more then you know this is first, you need to keep the clutch in when doing this.
how ever if your slowing down is more gradual then what you can do is go from 5th down to 4th then let engine slow the bike down then when the revs drop down change down to 3rd and so on until you get ot 1st gear.
if your coming to a stop quick say at lights or junction then if the bike is in 5th gear then you can change down the gears once the bike has stopped just hold the clutch in when you stop and keep tapping the gear lever down until you feel that its not going down any more gears this way you know its in 1st without having to cound down the gears, their id no quicker way of going down the gears to get to 1st.
i hope i have read your question right and gave you the answer you was looking for if i got the question wrong then please explain then i can assist you further ok
May 23, 2010 | 2005 Yamaha Xv 250 Virago S
My 1997 grand am will not start &the gear shifter is stuck in park
If you have no electrical power to the car the solenoid will not release the gear shift. You can release it manually, on the under side of the steer colum should be a small button to push, or if it is shift on the floor, there should be a "release" tag.
Make sure you battery is fully charged, and check MAIN fuses in the engine bay.
Feb 04, 2010 | 1995 Pontiac Grand Am
My 1998 Tracer is stuck in park. When I push on the brake, the button on the shifter will not push in.
Hello! It sounds as if your gear shift lock isn't working properly - it should release when you depress the brake pedal. You're not stuck, however. There is a small plastic piece to the side of the gear shift on the console - you can pry this piece up and off, revealing a hole underneath. Insert a screwdriver straight down and you will push on the manual gear shift release button - once you do that you will be able to move the gear shift. This can be caused by a few things - weak battery, or the release button is broken behind the brake pedal.
Hope this helps and good luck!
Sep 24, 2009 | 1998 Mercury Tracer
2002 Ford Escape will not shift into drive
This is the shift lock...you will need battery to release it electrically but there is an over ride by the shifter..either a button to push or a place to put your ignition key. This will release the shifter
Dec 02, 2008 | 2002 Ford Escape
If the battery is dead, the shift interlock solenoid will not disengage the gear shift mechanism. You have to have sufficient current through the brake switch to disengage the interlock. Charging or replacing the battery should do it. Hope this helps
Open Questions:
See all Peg Perego John Deere Gator HPX Ride on Toy Questions
Peg Perego John Deere Gator HPX Ride on Toy Logo
447 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
