Question about Canon PIXMA MP210 Photo All-In-One Printer
I cant print,scan & copy
I print some documents,& after while my printer did not work....the printer did not feed the paper & it is very noisy as if its printing....i tried my old printer & also same problem.i tried to scan but it is also not working..can you help me.?what should i need to do?the printer have the problem or do i need to click some icon in my computer?hope u can help me,& thanks in advance
    Novelist:
  • 85 Answers
Hi I have almost 30 inkjet printers...
Usual problem when that happens:
After lots of printing the PAPER FEED ROLLERS usually made of rubber will become very shiny with wear. So instead of feeding the paper they slip like a car on ice.
The printer not knowing prints anyway and wastes your expensive ink.
Solution:
Scuff the paper feed rollers to help traction.
Heres how:
Using a disposable nail file (sandpaper type)
Lift Lid and holding sideways against each roller (usually 3-4)
Press PAPER FEED.
It will scuff as it rotates - Usually does the trick!
Posted on May 10, 2008
Here is possible problem:
From time to time I have the same problem it usually happens when the rubber paper feed rollers become very shiny so the paper does not feed properly. The printer not knowing continues to print and blanks appear.
Solution:
The paper feed rollers just need to be scuffed to allow better tracktion.
Heres how:
Use a disposble nail file *sandpaper type
Lift lid and hold nail file against each paper feed roller and press paper feed button. Scuff roller as it rotates.
Usually does the trick !
    President:
  • 2,712 Answers
Try reinstalling the drivers and/or replacing the cables. Also look for any debris or tiny piece of paper that may be stuck between the rollers..
Posted on May 09, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 14 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
Double printing on pixma mp470
Double printing or double feed??. Double printing means document printed in 2 copies. Double feed means printer feed double paper in one moment. For double printing,please check number of copy of document in printing preference properties.
Double feed occurs when pickup roller fails to pick the paper correctly. It's usually caused by shaft of paper pick up roller which is broken. You should replace drive assembly (include pick up roller) in this case
May 13, 2010 | Canon PIXMA MP470 All-in-One Printer
Can't work out how to use the multiscan? I press scan and it comes up with multiscan and I put the first piece of paper in but don't seem to get asked for any more sheets and it therefore just scans one...
Anita,
Put the pages in the "multiscan" all at once, not just one sheet at a time. The Automatic Document Feeder (ADF) will feed one sheet of your document at a time untill all of the pages are scanned...
Thanks for using FixYa!
Oct 26, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Cannot print double sided
On the machine when a 2 sided document is inserted in the document handler, select the 2x2 button on the console. Press the start button and the machine will feed the document in, and do a reverse of the document for the second scan. In the paper feeder, the machine feeds the paper in and reversed the copy back into the machine, flips the copy then feeds the copy back for the second side to be copied.
If you do not have a m20i, the lower model numbers will not do two sided copies.
Aug 14, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Ink system has fail. unable to copy receive faxes, or print. Refer to printer documentation. Error: 0xc18a001
i can not feed paper at all or copy to paper but i can scan files to my computer how can i fix this
Mar 01, 2009 | HP Photosmart 3210 Printer
HP 6200 without telling it to print, feeds and jams continually
I already encounter that problem lately. when you print your documents, the only response of the printer is paper jam. feed and jam.
try this tip if acceptable of your situation now.
only to do is copy your documents by edit button and then select all or highlight all that your going to print and then right to copy
and then, open a new documents page set up if needed.
and then print it without saving your file because that already save.
Dec 05, 2008 | HP Officejet 6200 All-In-One InkJet...
Can't print
try this first...do a test page from the printer panel...do you have a user guide?
Oct 13, 2008 | Dell 962 Photo All-In-One InkJet Printer
Document feeder works for printing but not for scanning
Hi, When you had the doucment feed jam were you able to clean or remove any paper that might be blocking the paper to be scanned? It sounds like there is paper still in the document feeder , I would open the DF and check very closely to make sure no paper is in the way!Good Luck!
Dec 02, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Canon PIXMA MP210 Photo All-In-One Printer Logo
120 people viewed this question
old marine
old marine
