Question about InFocus LP530V Video Projector 2000 ANSI Lumens 6.6 lbs. DLP 4:3 XGA 400:1 (LP-530V, LP 530V) Multimedia Projector
Infocus lp 530
Changed bulb, went into status screen pushed - volume and then source button. It does not reset. Any other options
    Scholar:
  • 167 Answers
Hello, That should absolutely reset the lamp timer.
This is crucial: Press and hold the volume - button, then press the source button (while still holding down the volume - button) for 5 seconds.
Make Sure you hold them both down for 5 Seconds!
I hope this helps you.
Cheers
Posted on Dec 30, 2009
Hey my InFocus LP530 wont detect my pc/laptop, ive changed the auto sorce select to on but still nothing, so i changed it to off and tried all sorces manually but still nothing, Any ideas?
set the pc screen resolution to a low setting.
connect the vga output on the pc to an external monitor and check that the video appears on the external monitor. change the mode of operation on the pc until it does appear.
then disconnect the external monitor at the end of the vga cable, and connect the free cable end to the projector and auto source search for the vga input signal
Apr 20, 2011 | InFocus LP 530 Multimedia Projector
I actually have a 250. bulb is new but stopped working. When plugged in green power indicater lights then flashes two red lights.
The projector is bloked, you need reset the lamp timer. Press and hold the VOLUME + buttom, then press the VOLUME - buttom. Hold both buttons down for 10 seconds.
Jun 16, 2010 | InFocus LP 240 Multimedia Projector
Cannot Reset Infocus LP 350 Projector after replacing a bad lamp
that model has a history of bad ballasts. you'll need to replace it.
Mar 03, 2010 | InFocus LP350 Multimedia Projector
Cannot get computer screen projected by 530
reset the settings to factory default. does the splash screen or a blue screen come up? make sure the correct input is selected, swap out the cables, and make sure the port on your computer is activated. if all else fails, you may need to drop the resolution on your computer to match the projector.
Jan 13, 2010 | InFocus LP 530 Multimedia Projector
InFocus LP530 with burnt original power unit. To use a new bulb, what is required to upgrade the power unit? (Apparently, 5 resistors need to be changed)
unfortunately, infocus no longer makes or even carries parts for that model. you could try getting a bad one on ebay that has a different problem and swap the parts.
Dec 14, 2009 | InFocus LP 530 Multimedia Projector
I have an LP530. Need main circuit board
Try LumenArc. They stock a range of ballasts. If yours is not listed, then email them.
May 09, 2009 | InFocus LP 530 Multimedia Projector
Infocous LP 530 Light comes on then stops
this could be one of three issues. the power supply. the firmware or the lamp. thebulbman.com
Feb 03, 2009 | InFocus LP 530 Multimedia Projector
LP 530 Lamp does not power on
Did you cancell the bulb fault status in the main menu ie bulb hours when you changed your bulbs if not try this turn unit on and see if it works it may do.
To reset the lamp hours counter press and hold down the Volume minus button - , then press the source button whilst still holding down the volume button for 5 seconds .
If this works you can then verify that the lamp counter was reset by viewing the counter in the status window in the OSM
hope this helps... Regards Vortash
Feb 27, 2008 | InFocus LP 530 Multimedia Projector
InFocus LP530V Video Projector 2000 ANSI Lumens 6.6 lbs. DLP 4:3 XGA 400:1 (LP-530V, LP 530V) Multimedia Projector Logo
132 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Juan Carlos Pacheco
Level 1 Expert
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
