Question about Malber WD1000 Front Load Washer/Dryer
Need a manual for instalation. Given as a gift. Only # I see is P21 on the front, right side near dial
  • moe1814 Sep 01, 2010
    I was not able to contact anyone in particular. I tried leaving a message on their customer service contact us portion of the site. I am still at loss.
    Maureen
    I will keep checking my email patiently until tomorrow evening. If no response, I will look elsewhere. Thank you.
  • 10,319 Answers
Unfortunately, this manual is not available online. I emailed Malber regarding the manual. Although they do not have an online version, they indicated that they would mail a hard copy of the manual to your home. Email your name and address to
Malber will be glad to send you the manual.
Use the website below to contact them
http://www.manta.com/c/mmnmjk8/malber-usa-inc
Posted on Sep 01, 2010
  • frank thomas wilson
    frank thomas wilson Sep 01, 2010
    It does take a day or so for a response from them for emails are checked every so often there
P21 Digital Back User Manual
You may download a copy of the user manual here.
Oct 01, 2012 | Photography
Need to set up machine was given as gift
There are two ways to use a fax machine in your home or office. You can either have a standalone fax machine, or you can use your computer for this purpose. Either way, setup is very simple. You don't even have to be a tech guru to do it. First, decide if you'd like to have a separate phone line for your faxes so they don't interrupt communications at the office. If so, have the phone company install the line before you get started with fax setup.
Setting Up a Traditional Machine
  • Step 1.Set your fax machine on a flat and even surface. Plug the power cord into the wall. Fill the paper tray and slide it into the front of the machine.
  • Step 2.Plug one end of a standard phone cable into the phone jack and the opposite end into the port on the fax machine. It's usually on the back or the side.
  • Step 3.Turn on the machine and pick up its telephonemag-glass_10x10.gif. If you don't hear a dial tone, check your phone cable to make sure it's secure. Then turn to the LCD screen and start programming your options. Since all machines are different, see the instructions in the owner's manual.
  • Aug 03, 2010 | Office Equipment & Supplies
    I NEED A NEW HOSE " Y - INTO ONE. WHERE CAN A GET ONE? I HAVE A MALBER P21.
    I'm a general contractor. I made up a new hose by using various couplings
    and a speedy connector.
    Jun 25, 2009 | Malber P21 Front Load Washer
    Fridge is not keeping cold
    I will need a little more information to help you better,
    Thanks, Sea Breeze
    Look at following areas for the model number
    • Beneath Or Inside Food Compartment On Cabinet Frame
    • On Plate Lower Front Or Rear Of Cabinet
    • Beside Compressor Door On Right End
    • Near Rear Of Cabinet
    • Inside Liner At Top
    Mar 26, 2009 | Refrigerators
    Machine won't run through cycles automaticly
    Sounds to me it might be a thermal pause, if your unit is running and then is required to heat up at a certain point and reach a certain tempurature before it advances, the heater is probably not coming on. The unit will therefore not advance.
    Sgt 48
    Jun 02, 2008 | Malber P21 Front Load Washer
    JVC KDLHX500 - doesnt let me eject. Comes with error message reset P21
    I was reading through your user manual and did not see any reset p21. I did find an eject error, which may be of help.
    I would first try an emergency eject. Look at page 49 of your user manual. If you do not have a user manual, here is a link to the pdf format version:
    http://resources.jvc.com/Resources/00/00/95/LVT1134-001B.pdf
    If this does not help, you can always try to do a complete system reset, which should reset it to factory specs. That is located on page 2.
    Please let me know here if this helped.
    Dean
    Rollin CBs
    Jan 16, 2008 | Radio Communications
    Water leak
    if you have a second hand appliance shop near you they could help you and it should be really cheap
    Jan 05, 2008 | Malber P21 Front Load Washer
    Open Questions:
    See all Malber WD1000 Front Load Washer/Dryer Questions
    Malber WD1000 Front Load Washer/Dryer Logo
    112 people viewed this question
    Top Malber Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    ashburton
    Dan Webster
    Dan Webster
    Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
