Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Water goes through drain as soon as you turn on
The timer ??
Posted on Sep 02, 2010
HOW DO I GET THE WATER TO DRAIN?
Sounds like your drain needs a strap. Does all the water drain out as soon as the unit turns off?
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jul 26, 2017 | Heating & Cooling
How do I replace the water pump
Not enough information, are you stating when you start the cycle no water enters the tub?
The normal operation at start the washer goes into drain first then starts the cycle.
Jan 07, 2015 | Samsung DMT300RFS Dishwashers : Built in...
My Sears Limited Edition washer starts the drain pump as soon as you turn it on and the pump keeps running continuously(I can hear it) which doesn't allow the water to fill the tub?As soon as it start
check the drain hose,if it's pushed down the stand pipe to far it will cause a syphoning affect and drain the water out as fast as it goes in,also have you unplugged the washer to reset the computer board?if not unplug it for 5 to 10 minutes,plug it back in and see if it resets itself,any error codes coming up?let me know how you make out.
Dec 14, 2014 | Washing Machines
My master bath sink drain worked fine, but was old. I replaced it with a Pfister faucet with a snap to close drain. Now every time we run water we have strong sewer gas smells coming up. As soon as the...
If water is flowing, there is a water brake to stop the drain gasses coming up. If the overflow pipe is draining to the wrong side of the trap, that may do it.
I would check the installation.
Jul 11, 2017 | Plumbing
As soon as the machine starts drawing water for the washing cycle it drains the water immediately. Any suggestions?
Yes, make sure the drain hose where it goes into the drain is higher than the console of the machine. Also make sure it only goes 6 to 8 inches down into the drain. I this is already the case, they make a siphon break that goes on the drain hose that will prevent this. you can find one at any appliance parts house.
Dec 21, 2009 | LG WFT1071TP Top Load Washer
Washing machine doesn't hold water because it drains out as soon as it goes in
if its draining as soon as it goes in
is it draining from the end of the drain hose
or is it pouring out from under the machine.
if its draining from the hose, the end of the hose must be a min. of 6 in above the back of the unit.
if it is not the hose, the you have a leak somewhere
try to gget in the cabinet, and see if you can see where it is going
Oct 13, 2009 | Washing Machines
A/C drain pan not draining.
The drain must have one and only one trap in it. A trap is where the pipe goes up then back down so that water is kept in a section of the pipe - will stop the air from blowing thru the drain and not letting the water drain - may not sound right but it is! I've seen this many times! Drain traps are not understood at all by the HVAC industry.
May 12, 2009 | Heating & Cooling
Water keeps draining LG WF-561SPP top loader
If the cycle does not stop draining that is usually because of a faulty membrane switch that controls the water level in your appliance.
The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely.
Apr 02, 2009 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Dishwasher
make sure the drain hose is at least 20'' above the floor before it goes into a drain pipe. if you have it going directly into the floor it will siphon the water out as soon as it is pumped in
Dec 24, 2007 | Dishwashers
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
13 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
