Question about Gyration Go 2.4 Air-Mouse Handset
My air-mouse will not turn on. The green light doesnt come on and neighter does the red light on the bottom that lets the mouse move
Jet 3 ultra power chair won't move
Move the freewheel levers back and forth so the chair does not move drive position
May 25, 2012 | Jet 3 Ultra Power Chair
I dropped my mouse and it appears that the inside of the mouse moved and now the sensor (red light thingy) moved and thus the pointer won't move much, clicking stuff works however, How do you open the...
try cleaning the sensor reflector b4 opening the mouse(its the light thingy @ the bottom)
if it doesnt work try opening with a screwdriver,normally covered by a sticker at the bottom of the mouse
Feb 10, 2011 | Computers & Internet
Hi, I have M-RAA93 logitech cordless optical mouse for Notebooks. But i dont have any CD to install, what to do? I have Toshiba Satellite L455 S5975, Windows 7 Thank you
Push the black button on the usb transever (part that plugs into the computer) .
Green light on transever will flash repeatedly.
Push and hold the button on the bottom of mouse (light gray, oval button on bottom of mouse) for five seconds, let go.
Light on the transceiver will flash a few times and then go out.
Win7 will notify (or not) that it is ready to use.
Use mouse norma-ly.
Note: Make sure gray slider switch is moved to the right and that you see a red light coming from the bottom of the mouse. If no red light replace batteries. Best not to use rechargeable batteries but if you do us the best Ni-Me (high ma 1000 or better).
Aug 25, 2010 | Logitech Cordless Mouse
My mouse isn't working
Try to put new batteries.
Apr 30, 2017 | Logitech 931150 Mouse
Mouse doesnt work
Press the button on the underside of the USB, the green light will flash. Now press the reset button on the underside of the mouse. Your mouse should now work.
Mar 21, 2009 | Microsoft Wireless Notebook Optical Mouse...
MOUSE LIGHT FLASHES red and green; does not function
The flashing red and green lights means that now it's in discoverable mode and it's time to add it as a bluetooth device.
Mar 14, 2009 | Microsoft Wireless Laser Mouse 5000
Microsoft wireless notebook optical mouse 1023 - not working!
If you know that the battery is good then try this next. There is a VERY tiny shark-fin shaped spring-loaded button on the bottom of the mouse that is pressed in, when you insert the receiver, while the mouse is not in use, that turns off the mouse to save the batteries. If you haven't used the mouse in a while, it can get stuck in the in position, so that when you pull out the receiver, it doesn't spring out and turn the mouse on (indicated by the red light on the bottom). If you notice that the light isn't coming on. Just try manually pushing in the little shark-fin thing a couple times to make it spring back out. After a couple times, you should be able to get it unstuck and the red light should come on.
Feb 24, 2009 | Microsoft Wireless Notebook Optical Mouse...
Red light
If you're talking about the red light on the bottom of the mouse, it is needed for the mouse to track its movement. When the mouse is not being used, this red light blinks only once per second or so to save power, but once it sees movement, it will come back on.
Aug 17, 2007 | Logitech RX600 Mouse
Gyration Go 2.4 Air-Mouse Handset  Logo
105 people viewed this question
Top Gyration Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony Crow
Are you a Gyration Computer and Internet Expert? Answer questions, earn points and help others
