Question about Dell XPS 200 PC Desktop
Power problem My XPS 200 wont power on checked all the obvious the pilot light inside is on and blinking green so its getting power.. just won't turn on
  • cmurda814 May 12, 2008
    The power supply fans are NOT running... nothing is running.. the only way i know the unit is getting power is because of the pilot light inside that sits between the battery and modem.. that light just flutters green.... tried the graphics card thing and no dice... i also disconnected and reseated just about all connections i could get my hands on. im thinkin its the power button or the motherboard... just troubleshooting before i blow the cash... any other suggestions???
    Novelist:
  • 150 Answers
Hi, Sorry for the delay, my own system was down
and full of gremlins with matches, so I had to re-build it.
Most power supplies have a dedicated wire in the main
mother-board connector, I believe it is green. When this
wire is grounded, the power-supply is turned on.
You can do this with a paper clip to test the power supply,
after disconnecting the supply from all other devices, including
the main board.
Also you can test the front panel power switch with a continuity
checker / ohm meter to see if it shorts to ground when you press
the switch.
The front switch connects to the main board, along with the
reset, speaker and other functions through a set of small
connectors near the corner of the main board.
you DO want to check the manuals for the mother board,
power supply and case if you still have them, other wise
google the model numbers, to make sure you have identified
the correct pins before poking around causing more damage.
If you are replacing the power supply, get a big one, such as
the Xigmatek 1000w. It is worth every penny in preventing
future headaches. Especially if you plan to use fancy
video cards for gaming, a large number of fans, or
hard drives.
Good luck,
Martin.
Posted on May 22, 2008
  • Martin J Stadler
    Martin J Stadler May 23, 2008
    Just to clarify,
    There are four possible reasons why a power supply will
    not power up.
    1) It is internally defective.
    2) It is overloaded due to an external short,
    and the internal protection circuit has kicked in.
    3) It is not getting a power up message, due to
    a bad cable (switch to mother board or
    mother board to power supply)
    4) The mother board is bad and the turn-on message
    is not being sent.
    The first step is to isolate if the problem is inside the
    power supply, or external:
    0) Turn off the power supply with the rear switch,
    unplug it from the wall socket and wait for it to
    discharge (2 mins or so)
    1) Disconnect the (Molex) power supply output cables from
    all loads, including the mother board.
    2) Ground the "Power Supply ON" signal the the 20+4 pin cable
    harness (the one that normally connects to the mother board)
    >>> This should be Pin # 16, green wire <<<
    (opposite to a red wire)
    by using a jumper or paper clip to any of the black wires.
    3) plug the power supply back into the wall socket, turn ON
    the rear switch, and see if the fans spin up.
    If they do, the power supply is probably good and the problem
    is external. If not, the power supply has an internal fault.
    4) If the power supply has an internal fault, wait 30 minutes for
    it to fully discharge, before taking it apart.
    5) Be very careful, because many switching power supplies
    use a capacitive voltage doubler on the primary side of the
    switching unit, to implement dual voltage mode operation
    (i.e. US/Europe)
    This means that you can have large capacitors of several
    thousands Micro-Farads, charged up to 400V or more.
    This CAN kill you if you are not careful.
    6) After removing the cover, discharge all capacitors with a
    screw driver, several times (!!!) to make sure.
    7) Check for blown internal fuses.
    8) Check to see if the fans can spin freely. Many power supplies
    have an internal shut down circuit that detects bad or stuck
    fans and prevents the power supply from turning ON.
    Martin
  • Martin J Stadler
    Martin J Stadler Jun 25, 2008
    Have you solved your problem yet ?
    Martin
  • 24 Answers
Can you tell if the Power Supply Fans are running?. It sounds like you may have a bad power supply. or try this, open the Case up and make sure the Graphic Card is Secure in it's slot oon the Motherboard, i know it sounds weird, but it has wored for me on a lot of computers i have worked with.
Let me know if this helps.
Jack
Posted on May 10, 2008
2 Suggested Answers
worldvet
  • 859 Answers
SOURCE: XPS 200 power problem
Its is probably in hibernation mode. Hold the power button in for about five seconds or more until the lights go out and the restart.
Have an xps 200, monitor suddenly went black the other day in the middle of use. Noticed the power light had gone from green to amber. When I push button on monitor says it is in power save mode, to move...
Try connecting the monitor to a friend's computer. If you get some sort of a display it's not the problem. When you say that the computer makes a new noise like the fans are spinning fast, you might have an issue with the video card , motherboard, or power supply.
Aug 05, 2013 | Dell XPS 200 PC Desktop
My Dell XPS 200 will not turn on.
Have you checked to see if your power supply is still good, or the power supply connection to the motherboard is good?
Sep 14, 2012 | Dell XPS 200 PC Desktop
There is a green blinking LED on my motherboard, and my computer is not turning on. What is wrong? Someone told me to check page 64 of a Dell .pdf file, and all it did was show me a layout of the...
John, pull the power cord and leave the system off for 30seconds. Then reconnect and attempt to power on the system. If it still doesn't boot then listen to hear if there are error beeps. The number of beeps indicate what the possible problem could be. You would check this is the troubleshooting section. -Ravi Shanghavi
Aug 19, 2010 | Dell XPS 200 PC Desktop
Dell xps 200 shuts down without warning. The powe...
Opitions:
1.) Your system may have an over heating problem
Make sure all your fans are running and not making excessive noise.
2.)You may be a victim of spyware/maleware infections. You will need to have your system cleaned. This should help resolve your issue.
I would recommend trying CCleaner first to see if this helps you. Please keep in mind this will not rid your system of everything just keep you a float and offer you a fighting chance.
Please keep me posted and updated on your issue. I am here for you and will see your issues out till resolved.
Have a great and wonderful day :)
Thank You
Please do not hesitate to contact support :)
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com
http://www.itsupport.co.cc
May 20, 2010 | Dell XPS 200 PC Desktop
My XPS 200 keeps shutting down and power light blinks
During when does your computer shutdown? Please check the diagnostic lights at the back as well which ones have light on it during the time it would shutdown.
Since you said that the light is blinking yellow it just says that your power supply is running outside its normal operating range. So most likely you would need a change of power supply. Maybe a higher wattage would be better.
Apr 28, 2010 | Dell XPS 200 PC Desktop
Dell XPS 200 Computer shuts off leaving blinking amber light
3 most common solutions to your problem are:
  1. Bad power supply; once it heats up will quit without warning
  2. Bad heatsink/fan; processor heats up and will lock up your Pc
  3. Bad motherboard
Try opening the machine and give the inside a thorough cleaning, paying special attention to the heatsink and fan. Once clean and you've ensured the fan is operating, put it back together and see if your problem is fixed. If not, a new power supply will likely fix your problem. Best of luck.
Greg
Jul 06, 2009 | Computers & Internet
Dell XPS400 No Start!!
If you fan isn't turning like it should, it is definitely a power supply issue. Go out and purchase a power supply with 250-300 watts...thats a good standard wattage!!
May 12, 2009 | Dell XPS 200 PC Desktop
Dell XPS 200
Is the amber light blinking? Indicates PS not operating within specs. You can look at replacing the PS (~$79-99). GL
Aug 09, 2008 | Dell XPS 200 PC Desktop
May 09, 2008 | Dell XPS 200 PC Desktop
Dell XPS 200 PC Desktop Logo
256 people viewed this question
Alun Cox
