School smart laminator problem: motor is not running, any troubleshooting tips?
How to troubleshoot a fellowes laminator?
When plugged in, you can access it through your computer connections. From there, you can have the laminator scan itself for problems. If no problems are found, you can try to reset the whole thing.
Elisa Jed ' http://www.qprintfinishing.com.au
May 15, 2014 | Office Equipment & Supplies
Laminator wont feed
If the motor is running, then the cog that drives the roller system may have failed. Laminators built today are made with plastic (nylon) roller drive cogwheels that crack. Especially if the fed media is too thick. Put the machine into run mode and feed a single piece of card (a playing card will do) into the feed slot. Lightly hold the card and see if you can feel the card moving. To check if the motor is in reverse, feed the card into the output slot.
If you are handy with a screwdriver, then with it disconnected, remove the lid (about six screws underneath) and check the rollers for old lamination sheets that could be stuck to one of them. This would limit the feed gap between the rollers, preventing you from putting your media in.
Nov 23, 2013 | Fellowes Saturn 2 A3 Laminator Laminators
I have a fellowes laminitor and it will not feed
Mon lamineuse marque erreur 02. que signifie ce code
Il faut lire le manuel d'utilisation qui e`tait dans la boi^te de ta laminueuse.
Oct 03, 2013 | Ledco Educator 25" School Laminator - Open...
My gbc creative laminator won't heat up
We have an Ulitma 65 and it won't heat up...Any suggestions on how to fix this? We are at a school and no $ to replace the whole unit. Thanks in advance.
Mar 29, 2013 | Office Equipment & Supplies
Some one at work tried to laminate a card. when it did not come out she put in another sleeve thinking it would push the other out. smart uh! how do we get the 2 pages out?
If you were using GBC brand laminating pouches they don't need a carrier, if you were using another brand of laminating pouches, then a carrier is needed (something they don't clearly specify) and that's why the laminating pouch got stuck.
If you have had the laminator under a year, it should be under warranty, and you can call the company, and they will send a replacement, and they will probably then inform you of the above listed laminating pouch issue.
You may also want to try using the reverse button, but many times the pouches will get stuck between several rollers, and you risk destruction of the entire machine by attempting to take them out manually.
May 31, 2011 | Gbc HeatSeal H425 Laminator
Laminate specifications
A typical laminate trimmer is equipped with a 1/4-inch collet. The motor runs in the 20,000-30,000 rpm range – faster than most routers to compensate for the fact that the bits are smaller in diameter.
Aug 27, 2008 | AMANA TOOL 3400 DOUBLE EDGE LAMINATE...
137 people viewed this question
jasbo
jasbo
