Question about Sony Televison & Video
We bought our sony dvd recorder (hi definition multimedia 1080) about 1 month ago. So far we have only recorded one program and use it basically as a player. Last night it was working fine tonight I put my disc in to play and it wont work. It keeps coming up with D32767 on the display screen. I cant find this anywhere in the manual. Also I couldnt eject the disc so I had to turn it off & on to eject. I tried another disc and it did the same. I even tried to reset the recorder making no difference. CAN YOU PLEASE HELP AS THIS IS THE SECOND DVD RECORDER WE HAVE BOUGHT IN THE LAST FEW YEARS AND I CANT BELIEVE ITS HAPPENING AGAIN. MARIA ARSENOGLOU
  • 163 Answers
SOURCE: Cannot play this disc
remove the cover and see if the dvd run, if not you got a motor problem or a motor drive one,if yes then try cleaning the reading eyes(pickup)by blowing dry air (get a can at radio shack)check for goods, if dosent work, take it to a shop for a repair thats all you can do, is a job for a tech....good luck
Posted on Aug 10, 2006
sandrew
  • 2961 Answers
SOURCE: Insignia DVD/Cassette combo player
I imagine you have checked the disk for scratches top and bottom, if so you can purchase a cd/dvd lens cleaner cdrom as the laser may need realigning and cleaning.
Posted on Sep 06, 2007
SOURCE: DVD player recorder won't read or play any disc
For 18 months i've been **** at Best Buy for what I thought was a piece of junk. Then I read the TIPS&TRICKS posting by BobbyR1234. Follow his instructions but add 3B. Theres a black plastic plate blocking access. Remove the 2 Phillips screws and release the plactic clip on each side. Clean as instructed. A tip-off to this being your problem: try playing a music disk. The music will play and data will show but of course there will be no video therefore the disk will work. Thanks bobby!!!!
Posted on Aug 16, 2008
SOURCE: dvd "unknown disc" message coming up
When Your DVD shows "LOADING" for quite some time and then if shows "UNKNOWN DISC" or "NO DISC", Open the cover of your DVD Player, Remove the flap over the disc by opening the screws. Remember that you are not keeping your eyes perpendicular to the lens. Now take Colin liquid in an ear buds and rub over the lens. Now with dry end of the bud, rinse it and make it dry. Keep the disc in the space provided for. Put on the Flap over the disc. And try to run it. I hope this would work fine.
Posted on Jul 13, 2009
  • 87 Answers
SOURCE: Trouble with my Panasonic DVD recorder DMR-E55EB
Its definitely the SCR STRG35353A. I replaced it (not cheap) and put a 1"x2" heat sink on it. no problems any more. FIXED!
Posted on Aug 13, 2009
Records & dubs but very poor resolution
You've got a Dish Network's HD DVR and a Toshiba 720P HDTV - so this part of the mix will maintain the HD pictures and high quality digital audio that you're used to seeing.
The trouble begins when you introduced the Magnavox VCR / DVD device. The highest quality video content that this device can record is the 480 type, regardless of the input or source quality - which in your case would be 720P via HDMI cables. 480 is considered "SD" or "standard definition". This is the weakest link in your setup and is responsible for your unsatisfactory results.
The Magnavox will "upconvert" to 1080 lines of resolution. The key here is the term "upconvert" True HD recordings are taken of a scene and capturing either 720 or 1080 lines of resolution in the image or video (such as a camera taking a photo or video); or recording the playback of a previously recorded 720 or 1080 lines of resolution source. Recording a 480 lines of resolution source with a an 720 or 1080 lines of resolution device will not make the image HD. The recording can not possibly be better than the original. In fact, due to losses, each generation of copy becomes worse and worse. Upconverting simply "fills in" the missing parts between the 480 source and 720 or 1080 output with what it "thinks" is missing data. The results are what you see on the screen. The original capture did not save more info that 480 lines of resolution so it is really impossible to improve it.
The recording can not ever exceed the quality of the original (the Dish Network DVR at 720 or more) and will only be as good as the weakest link (the Magnavox DVD / VCR at 480). Additionally, the moment you change from digital to analog, you lose quality instantly. Digital signals - both video and audio will always be faithfully reproduced do to error correcting technology, etc. that simply isn't available in the analog world.
You need to use a digital recorder capable of capturing and playing back of 720 or 1080 lines of resolution video and AC3 audio for optimum video and audio on a Blu Ray recorder or other device with hard drives or memory such as MP3 recorder. Otherwise you'll have to accept reduced quality of standard L & R analog audio and 480 lines of resolution of SD video. You can not expect HD audio and video if you try to save to equipment designed for SD / analog.
Dec 19, 2013 | Magnavox ZV427MG9 DVD Recorder VCR
Connecting JVC television set model AV29LX2 / JVC home theatre system/satellite decoder / Sony DVD recorder
You need to buy a splitter in order to put one to the DVD recorder and one to the tv from the decoder. You should be able to get one at the Local Radio Shack or other electronics store.
If you need help locating a store, please let me know
Otherwise Thank you for using Fixya and Have a Good Day!
and Good Luck...
Apr 19, 2008 | Televison & Video
WONT RUN
I bought the VR3845 on a whim, at a local Costco because of the DVD/VHS combo feature and the price. After 7 months the VR3845 suddenly wouldn't read DVD's anymore, even ones I'd recorded the night before. The GoVideo Web site was of no help and I'm now facing wasting hours of my time to get a replacement or my money back, assuming I can.
Other "features", you can only switch recording channels at the minute. That means you record, say 8pm to 9pm on channel 5, but you can't program the unit to record from 9pm to 10pm on a different channel. The programming interface will only let you start the next recording on a new channel at 9:01PM, so you lose the first minute of your program.
At the end of a programmed recording session the VR3845 automatically shuts off. If you're watching another channel while recording, suddenly all you see is static until you power up the VR3845 again.
Sorry Man but this thing just isn't worth it I would take it back.
Jan 09, 2008 | GoVideo Go Video VR3840 DVD Recorder/VCR
I have a Pioneer DVR5100H which was set up to record Analogue programs - can I change the set up to accept digital programs. I have tried auto setup but it doesn't pick up any programs?
You can't record digital programmes with this recorder unless it is connected to a digital tuner, e.g. a Freeview box or Sky digibox. This recorder has a built in analogue tuner which allows it to record analogue transmissions. Recorders which can record digital transmissions have a built-in digital tuner and usually have a DVB logo (actually looks more like DV3) on the front.
If you want to record digital programmes using this recorder, you need to connect it to a Freeview or Sky digibox, preferably with a scart cable. It is not sufficient to connect it to a TV with a digital tuner or built in Freeview as the player does NOT record directly from the TV, it must be connected directly to the transmission source. A basic stand-alone digital tuner (Freeview box) can be bought for as little as £10-15.
Regards,
BElectric
Nov 18, 2010 | Pioneer DVR-5100H DVD Recorder
Want to record a television program on a channel higher than 16.
there must be a setup feature on the sony for channels that you get in your area?
Dec 18, 2009 | Sony SLV-D370P DVD Player/VCR
The DVD recorder quit finalizing the disks
try cleaning the lens, if your cd's are ok.
May 27, 2009 | RCA DRC8300N DVD Recorder/VCR
Recording vocals while the music tack is playing simultaniously
it's not supported on that or any earlier sony software that I know of. have you tried running the program twice (simultaniously) and playing on one while recording on the other then mixing the tracks together after??
Apr 26, 2009 | Sony Sound Forge Audio Studio 9
Recording Error -- E7
When I bought my emerson ewr10d4 about 2-3 years ago, the machine only recorded on disks that were rated at 2x or 4x speed. And it didn't accept off-brand disks, it only liked the major brands like Maxell, TDK, Memorex, Sony. I learned this quirk the hard way. Eventually, when I called the 1-800 number, they sent me a disk to upgrade the recorder to 8x speed (and it was very simple to do - basically just pop it in). Helped a lot, although this year most disks in stores are 16x speed, and as of a couple months ago (November 2008) emerson didn't have a newer up-to-date upgrade available. But if you didn't do the 8x upgrade yet, call them and start there. It's a small improvement, but an improvement nonetheless. By the way, if anyone wants to buy some lesser-known chinese and japanese-brand disks, I may be able to help!
Dec 28, 2008 | Emerson EWR10D4 DVD Recorder
No sound records on dvd
http://sony.storagesupport.com/dvdrw/vrdmc5dwn.htm
System Software Upgrade
Version: 30R2
Release Date: 01/06/08
New Features:
  • Allows VRD-MC5 to support Sony's 1920 x 1080 AVCHD Handycam.
  • Allows VRD-MC5 to record video directly from a MemoryStick memory card recorded using a Sony's MemoryStick Handycam camcorder.
Improvements:
  • Fixes problems with no audio during playback on certain camcorders recorded through 1394 or i-link connection.
  • Corrects signal detections with some camcorders as copy-protected.
Instructions | Download Updater (4 MB)
Dec 30, 2007 | Sony DVDirect (VRDVC20) DVD±RW Dual...
Televison & Video Logo
49 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
