Question about Kenmore 62602 Electric Dryer
Runs for a few min then trips one of the 2 breakers. to make sure it was not the breakers,i switched the hot leads in the plug, and just as i thought the other breaker then tripped. so i assume the problem is in the machine. drum spins, heat is there and air does come out of the vent but dryer will trip one breaker after a few min.
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
I would say that the motor is going bad...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 12, 2010
Our glass top range quit last night. The breaker threw and when reset, it snaps. All 4 burners, lights, etc not working.
any electrician knows that besides a short activating a breaker , items such as leaking insulation , moisture , or control unit problems will trip a breaker
so get in an electrician to test everything
Jul 05, 2017 | Dryers
My TB 302 cranks and runs at high idle does not idle down. I have power at all recepticals but no power at welding leads. I have checked all breakers and fuses, they are ok. what do I need to do next
there are a few things you can check on your machine,
make sure your machine is not in the remote control position, make your process switch is in the electrode hot position, the trailblazer has three slip rings, make sure the carbon brushes are not "stuck" in the holders, there are 2 circuit boards in your machine, make sure the plugs are properly inserted into the receptacles and making good contact, also make sure your ignition switch plug is clean and making good contact
Mar 17, 2016 | Miller Trailblazer 302 AC/DC Welder...
Dryer trips breaker after only a few mins of operation
Check to power at outlet for 220 volts
Check the breaker for the correct amperage cut off.
If the unit had an obstruction in the air flow, it would not trip the breaker.
Try running the unit with just cool air and see if it trips the breaker.
Odds are, you have a defective breaker.
Also, if the home is newly built, check the panel for loose connections at the breaker.
Or you could try a different power outlet, like the hot water heater.
If the unit continues to trip breakers on other outlets, you may have a short in unit.
Apr 29, 2014 | LG DLE2140W Dryer
Why is the gfci tripping on my hot tub after being on for 30 min. After resetting the breaker after the 30 min. run, it trips immediately!!!
You will want to make sure that all of your spa equipment is functioning properly. It is best for a spa technician or electrician to determine this issue.
It is likely that a particular piece of equipment is turning on around the 30 min time frame and causing the breaker to trip. Pump, ozonator or similar. Also check the heater element, a pin sized hole in the element will cause it to fail. Lastly your spas breaker itself could be bad.
Nov 20, 2012 | Pool & Spa
Have just installed a 1P 20-QOB shunt trip breaker in the panel. Landed the 120 v circuit back on the breaker ...have a hot(common) from the relay and a return leg ....just not sure if i put the common...
Treat the shunt trip as if it were a switch. The neutral (usually white wire) on the shunt trip connects to the neutral busbar. The other (usually black) wire is the "switched leg", so to speak. The hot that goes out to the relay comes off a _separate_ breaker. The return from the relay connects to the black "switched leg" on the shunt tip. Most shunt trips have 2 wires coming off the shunt trip, a white and a black. If your breaker has contacts instead of wires coming off the shunt trip, the concept is still the same.
Feb 12, 2011 | Square D Qob120 Circuit Breaker With Shunt...
My colman rooftop ac unit shuts off after 5 min of use wait 5 more and you can turn it back on again when its running it works great its on a 1984 holiday rambler and has very low hours?
Try a new fan motor. It runs about $125.00, It will run a few min. then will trip the motor themal switch. you can probably still here the compressor running. It may also trip the breaker on shore power . good luck! the part you are looking for is a 1/3 hp 115vac 2 speed 1580/1020 rpm part number #1468-3069
Aug 25, 2010 | Coleman Mach III Air Conditioner
My roper electric dryer heats when running for 5 mins. then trips circuit breaker
May not be your dryer. Many times a loose wire at the circuit breaker panel will cause the breaker to get hot and then thermal trip the breaker. It may be worth a look. Remove circuit breaker panel. Turn dryer breaker off. Check wire lug screws for being loose. Make sure screws or snug but do not tighten and strip the threads. Be especially careful if the wire/cable is silvery aluminum colored. If that is the case make sure there are not any broken strands at the breaker lugs. If possible use a clamp on amp meter to check the operating current. The current should not exceed 80 percent of your breaker rating. It is most likely a 30 Amp 2 pole. You may also have a bad breaker. If a breaker has a weak spring or bad contacts it will easily get hot under load and trip. My best guess other than a dryer motor locking up or dragging. New breakers are inexpensive at HD or Lowes etc. Be sure to get the exact brand and model if replacing.
Feb 27, 2010 | Roper REX3614KW Electric Dryer
Intermittent breaker tripping
Have your installer check your wire connections first. These use a lot of power in turn the connections get hot leading to oxzidation leading to more heat...A vicous cycle. Other than that 40a sounds a little light depending on elect run and load on heater.
Aug 13, 2009 | Hayward 116k BTU HeatPro Digital Heat Pump...
Unit shuts off on hot days
It may be low on refrigerant. On hotter days, the compressor has to run longer to reach the temperature you have on your thermostat. Have it checked for the proper refrigerant charge and have them test how many amps that the compressor is pulluig as well. With the proper breaker installed, the unit should not be tripping out. Make sure that the breaker that is in there now is actually the proper one for your unit.
Best regrds, --W/D--
Aug 01, 2009 | Dometic Rooftop RV Air Conditioner
Kenmore 62602 Electric Dryer Logo
57 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
