Question about HP Photosmart M22 Digital Camera
Even when I change the batteries, when i tried to put on the camera by sliding the front lens cover, the usual display comes in the screen, stay for one or two secs. then went off. I can not take a photo, even i am not been able to see the stored photos. I replace the batteries with new set severel times but the problem remains.
I have the exact same problem. If you hold down your flash button as it powers on, you can run some diagnostics although with mine, it showed the CCD is not functioning. Pretty much that means you now own a paperweight.
Posted on Nov 27, 2010
My cannon powershot sd 1000 camera stays black on the screen all of the time, I tried pressing the display button again and it did not work the shutters in the front seem to be working just fine. last time...
If the menus come on but there is no video or picture from the lens, that is usually the CCD which is a sensor in the camera that picks up the image. If you need to have it fixed, it's only $79 total for the parts, labor, the servicing for the camera included and even the shipping back. Go to: www.CamerasAndParts.com They just service these Canon Powershots exclusively and they are excellent for service on these. Your exact issue is on their site, it's $79 for everything and they do superb work on these models. I hope that helps, good luck with the problem.
Jun 14, 2011 | Canon PowerShot SD1000 Digital Camera
I get a "system error" when I turn on the camera. battery seems to be charged. thank you...
This error usually comes due to faulty sliding mechanism.Put a bit of force on the focusing lens to push it back into camera casing. That's the reason the sliding mechanism won't work. The lens is stuck and if you force it back in, the sliding mechanism will work again. Not responsible if your camera screws up, so try at your own risk.Or else try out this method.Pull the lens fully out and then it will work.It will be bit tricky to get the lens out. Use your nail to "grab" between the outer glass and the little plastic cover.
Thank you !!
Aug 17, 2010 | Nikon Coolpix 2500 Digital Camera
System error
Thank you !!
Jun 19, 2010 | Nikon Coolpix 4300 Digital Camera
Camera won't come on, screen stays black, and the lens is stuck out.
it could possibly be the brand of batteries used sometimes they are not juiced enough to hold out for the camera i have had this problem too i used different batteries til i found one that works
Sep 30, 2008 | Samsung Digimax S630 Digital Camera
Lens do not come out
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
If nothing happens just tell me..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Aug 26, 2008 | Canon PowerShot S70 Digital Camera
No LCD display
TIPS:
..to fix this...
Do as i say..
1.) Remove battery
or...
or...
5.) Turn it on.
Hope this may help;
Regards,
VOTIT
Aug 21, 2008 | Pentax Optio S4 Digital Camera
Lens cover error
TIPS:
..to fix this...
Do as i say..
1.) Remove battery
or...
or...
5.) Turn it on.
Hope this may help;
Regards,
VOTIT
Jun 17, 2008 | Nikon Coolpix S1 Digital Camera
Lens cover only partially opens
This blog post outlines repair procedures for stuck lens covers. An A400 is used as an example. But it should be similar for the A430:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Mar 31, 2008 | Canon PowerShot A540 Digital Camera
Lens cover
Well, I just looked at one, it is not easy to get to the front cover. Everything is removed from the back of the camera. The display, both circuit boards and the battery compartment have to be removed first. You may do better locating another camera, eBay is always a good start.
Mar 28, 2008 | Fuji FinePix 2650 Digital Camera
HP Photosmart M22 Digital Camera Logo
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
