Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA D52W20 The TV will not turn on. Using either manual or the remote when turning it on, the green LED light will come on for a few seconds then goes out .... then on and off again twice. The TV will eventually come on by itself but it may take an hour or two for this to happen. Once on it will remain on. I was a TV technician by trade years ago so I may be technically able to repair this with some help. Thanks
  • richboc Sep 02, 2010
    I am not trying to be sarcastic here but in the years that I have been fixing TV's you should be able to narrow it down a bit more than that. Generally speaking, when a certain model of television has an adherant problem like this one does it is the fault of one or two components be it a ceramic capacitor in the high voltage circuit that may have changed value or a resistor that has gone high or opened . The set is six years old so the fix must be out there some where. Thanks.
  • RCA Master
  • 12,061 Answers
Hi, well if you were a TV service man then like me you understand the enormity of the task ahead. RPTV's are just the hardest ones to service,as you most likely remember.
Before you can even contemplate attempting repair one MUST obtain a service manual.
Your problem, has to do with your PSU, and/or something causerie it to be Shut Down, I would also think that the problem is Thermal too. So you maybe able to find your faulty components by using Freeze spray, on suspected components.
We call the problem you are having a Hic-upping Power Supply. This is usually caused by a component, that works, initially, until it heats up, then it fails, then, because the power is removed, it cools down, and the set then powers on again, the components heats up, and it shuts down, this cycle is repeated, over and over, until it fails completely, usually. Sometimes it will even go for a bit, and then fail.
using the freeze spray when you chill the correct component, the "Fault" will clear, and stay clear until the suspect component heats up again, so this is well worth a try.
Another thing to remember is , Are your Voltages correct, you MUST check all voltages against the service manual reference voltages, checking these and making them correct will usually clear the fault.
If you find the DIY'ing isn't the way to go. Then please contact an RCA head or local office and ask them for a referral to an authorised service center, when there ask them for a "Quote" before allowing any repair work to commence, this way you can make an informed decision as to what to do, repair or replace.
Posted on Sep 03, 2010
  • RCA Master
  • 6,993 Answers
your TV is having a power problem. The power supply board is defective that's why the TV won't power up. Its receiving power but it cannot transfer the current to the necessary part of the TV because a capacitor, diode, etc may have been faulty. Until these bad components are replaced, the TV might not come on.
If you know about TV repairers, I would suggest that you open the TV and read the power board/panel with a meter, detect the bad component and replace it. Take note that TV stores a lot of current that can shock, so leave the TV for a while before you open it.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you.
Good luck.
Posted on Sep 02, 2010
I have a 60" RCA D56W02B rear projection TV. I've
Yes,the power supply board,where the actual power a/c cord plug into it,are most of the causes of power LED light blinking problems.
Feb 17, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA model D52W20 will not fully power on when we try to turn it on by using the power button on the tv or by using a remote. There is a click and the green light that shows power lights but the tv does...
unfortunatly the rca d52w20 is a flawed tv, they a high rate of problems with the power supply and convergence amps, both parts are no longer available, i have scrapped those sets that were barley a year and a half old. sorry and good luck
Mar 20, 2009 | RCA 20F510TD 20 in. TV/DVD Combo
Tv light turns on and off ,TV never actually comes on.
CK capacitor cp114,120,150 if ant of these caps are puffed up on top it is bad so replace all 3 capacitors cp 150 is 2200uf 16v other two are 220uf 35v
Feb 15, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA d52w20 Power Problem
ore there ares some ribbon cables that need to be reseated going from the deflection board to the signal board
Nov 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Need solution
Appreciate the direct "Ask Me".
Your concern with an RCA D52W26 is when you attempt to turn it on, it powers up as indicated by the LED lights but they then power OFF a few seconds later? or it powers on then you get to see bright line(s) left to right, then the TV powers OFF? or it powers on but only bklinking LED lights? If yes on the last any sequence to the flashing/blinking?
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 28, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA D52W20 will not stay on
Clicking sound is power relay engaging. If all systems are not functioning properly, unit will shut down to prevent further damage and/or fire hazard
Apr 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My tv wont turn on
I am having the same issue. I think it's the bulb.
Aug 04, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
