Question about Microwave Ovens
Looking for a manual for indesit dishwasher 3200w. thank u
Have new Indesit microwave. Cannot understand manual. How do I set the length of cooking time required. (Didn't ask question clearly before)
Please contact manufacture or return unit to store where bought and get a machine that you understand the directions of operation.
Nov 26, 2015 | Indesit MWI212IX Microwave Oven
Purchased Model # EWDW6505GS from Lowes in Tigard, Oregon today. It was the floor model and did not come with a manual for use and care (I got online) or with a drain hose. Where do I find a drain...
the drain hose for your dishwasher needs to fit the plumbing in your home. Measure the size of the connection at the drain (under the sink) and possible use the old hose as a model for what you will need. Lowes sells a hook up kit but be careful to measure the size of the outlet on bottom of the dishwasher and size and distance to the drain connection. Sometimes addaptors are used to size down the outlet side of the hose. Also if you have the manual it may show the size of the outlet on the dishwasher.
May 01, 2011 | Electrolux Microwave Ovens
My dishes are dirty after the wash. The glasses have small particles dried on the inside. They are upside down. How does it do that? Thanks.
Thanks for using FixYa.
An answer for your question about your dishwasher could be that your jets or spray arms are clogged.
1. Please look inside the dishwasher for obvious obstructions and turn the spray arms to make sure they move freely.
2. Now look at the bottom sprayer and at the little holes. If you see food or stuff in any of the holes, use small tweezers to remove.
3. Also look in the bottom area for items which may be blocking the water delivery hole.
4. Finally, look at the top sprayer arm. Using a flashlight, look closely for food or other particles which may be clogging the holes.
Let me know if this helps or if you have questions.
Thanks again for using FixYa,
Apr 03, 2011 | Microwave Ovens
Thanks for the Installation Manual. Do you also have the Owners Instructions for HotPoint dishwasher model #HDA3600R00CC serial # GT834763B? Thanks again
You hopefully will find one here.
http://www.manualsonline.com/ex/thread/view/idThread/3143793
Hope that helps.
Mar 02, 2011 | Microwave Ovens
Manual for indesit idv65 tumble dryer
This was very difficult to find, but I found it just for you! Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. I would be forever grateful if you could do this for me. To view the manual you will need adobe reader, which you can get for free from http://get.adobe.com/reader/ You probably already have it though, please try opening the file first and find out. If you require some other manual, the file doesn't work, or this isn't what you are looking for PLEASE reply to my answer here and I will correct it for you. Here is the manual / guide please give it a few minutes the file is quite large:
http://micromatikal.dlinkddns.com:8000/cust/idv65.pdf
Thanks
Tim
Oct 15, 2010 | Microwave Ovens
I have a Indesit DI 620 dishwasher that wont empty its water and with an error code of no 2 and 4 flashing rapidly, what can this be please ?
You should consult your owners manual for the error code description in the back under "troubleshooting". The obvious problem is that you are not rinsing your dishes enough and the bottom drain is clogged and needs to be cleaned out. The food will clog the hole and back it up.
Oct 09, 2010 | Microwave Ovens
Indesit K3E1WG manual
You can download and print the instruction manual in PDF format by clicking this link.
Please note: Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
Hope this solves your problem. Thanks for using FixYa.
Sep 13, 2010 | Microwave Ovens
Hi, My slim line bosh dishwasher has stopped heating the water. can you tel me what the problem could be and would it be expensive? Thanks Mandy
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 04, 2010 | Microwave Ovens
Dishwasher will start washing and then trip the power
this is in micrfowave ovens Wrong Category...
However if the circuit contsantly trips when using the dishwasher, take a look to see what other appliances are also being used at that time.
Electric jugs/kettles will overload the circuit, so will TV;s etc. Have an electrician divide the power plugs in that circuit to a new circuit breaker and reduce some of the load. Est cost is 80-$100
Please rate my help++++Thanks for using FIXYA
Jul 29, 2010 | Microwave Ovens
A WESTPOINT WQP12-9011E DISHWASHER, USER MANUAL
Try:
https://www.2instructions.com/results_mm.php?marque=WESTPOINT&materiel=Dishwasher
Jan 12, 2009 | Westpoint TV-201 Microwave Oven
Microwave Ovens Logo
78 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
