Question about AMD Sempron 3100+ 1.8GHz 256k Socket 754 CPU Retail (GXCPUS3100)
Asus k8v-vm uldra bios, amd sempron processor 2600+. 192mb of ram i want motherboard cd
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 56 Answers
Hello sir please click for this link http://nodevice.in/driver/K8V-VM_Ultra/get34100.html and downlod your asus motherboard's drivers fully.
Posted on Sep 01, 2010
I use an ASUS K8V-VM motherboard with AMD sepmron 2800+ processor. os is XP sp3. which vga driver do i need to install.
video card is better but here is motherboard download area driver http://support.asus.com/download.aspx?SLanguage=en&m=K8V-VM&os=17
Mar 09, 2013 | ASUS K8V-VM Motherboard
Can i fit a bigger processor to my ASUS K8V-MX Motherboard and mybe more ram and if so where can i purchase it from
This motherboard supports a AMD Athlon 64 / Sempron processor (Socket 754). Since this is an older unit you will have to search on Ebay for a processor.
As for the RAM you will need DDR 400, this can easily be purchased at www.newegg.com There is a maximum of 2 gb on your motherboard.
Mar 17, 2011 | ASUS K8V-MX Motherboard
K8n-vm asus motherboard supporting processors?
Here are the compatible processor for this motherboard AMD Athlon 64, AMD Sempron that you can choose from.
Dec 07, 2010 | ASUS K8N-VM Motherboard
Lost my motherboard driver disk of asus k8v-vm, where i can downloard it
go= http://support.asus.com/download/download.aspx?SLanguage=en-us
go download>select>mother board>2nd select socket 754>3rd k8v vm and search and download
Name ASUS K8V-VM Description VIA K8M890, VIA VT8237A, DDR RAM, Micro ATX, Graphics card, Sound card, Network card Form factor Micro ATX CPU Type AMD Ahtlon 64/Sempron Number of CPUs Single Socket Socket 754 Front side bus 800 MHz MHz Chipset VIA K8M890, VIA VT8237A Memory type DDR RAM Number of DIMM-Slots 2 Number of RIMM-Slots 0 Max memory 2048 MB Memory speed DDR400, DDR333, DDR266 Serial Attached SCSI (SAS) No Serial ATA (SATA) Yes Serial ATA ports 2 Serial ATA 2 (SATA II) No Serial ATA 2 (SATA II) ports None IDE Ports 2 IDE Speed 33/66/100/133 MB/sec MB/sec Built in SCSI controller No Built in RAID controller Yes Built in graphics card Yes Built in sound card Yes Built in network card Yes Multiple GPU support No Crossfire support No SLI support No RoHS Compliant No AGP interface No AGP-slots 1 PCI-e (PCI-express) Yes PCI-e slots 2 PCI-e type 16x/1x PCI slots 2 PCI-X No CNR-slot 0 AMR-slot 0 eSATA No Bluetooth No WiFi No FireWire (IEEE1394) No Number of FireWire ports 0 USB type USB 2.0 Number of USB-ports 4 Number of parallel ports 1 Number of serial ports 1 RJ-45 (Ethernet) 1 PS/2 Keyboard 1 PS/2 Mouse 1 Line-out 1 Line-in 1 Microphone Yes Bios 4 Mb Flash ROM, AMI BIOS, (TCAV), PnP, DMI2.0, WfM2.0, SM BIOS 2.3, PXE Boot BIOS Miscellaneous Audio:- Realtek ALC660 6-Channel Codec, LAN:- Realtek RTL8201CL 10/100M LAN PHY
Nov 22, 2010 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
I m having asus k8v-vm bt no space for sound card
The Asus K8V-VM motherboard has an intergrated audio chip on the motherboard, Realtek ALC660. You need to enable it in the bios. If you do not have you're manual down load it from Asus; http://www.asus.com/Search.aspx?SearchKey=K8V-VM You'll also need Adobe reader installed to view the manual. Enter the bios menu. Open Advanced. See the top of page
2-21 in the manual. Set, High definition Audio to [Auto] Save and exit the bios. Also check out page 1-19. You can install the driver software from the Asus CD or download it from the Asus link provided above.
Realtek Audio Driver V5.10.0.5211 for Windows 2000/XP/XP 64bit. (WHQL)
Cheers'
Mike
Jan 10, 2010 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
ASUS M3N78-VM motherboard Problemes
Good Motherboard...BTW... Reset BIOS to Factory defaults. Make sure you have the latest BIOS as well. Then you need to eliminate the other devices. Try running just on the On-Board Video...see if crashes. Run w 2 Gig Ram...same same... and of course the processor which may be impossible. Once you know it is MB or CPU... you make a choice which to buy or test. MB first... you can always return with less stress.
Dec 31, 2009 | ASUS M3N78-VM nVidia GeForce 8200 AM2+/AM2...
Motherboard drivers
go here: http://support.asus.com/download/download.aspx?SLanguage=en-us
in the upper left corner in input model to search type k8v-vm, under category click all then click search info.
Click on k8v-vm, select your operating system and download drivers
Aug 19, 2009 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
The best sistem for k8v-mx
Supports AMD Socket 754 Athlon 64/ Sempron processors, here is a list of processors supported by the motherboard >>>>
http://www.cpu-upgrade.com/mb-ASUS/K8V-MX.html
As for the graphics, the board supports PCI Express graphics cards, its up to you which card to buy, you can either purchase Nvidia Geforce 9 series or ATI Radeon HD series.
Regards.
Aug 01, 2009 | ASUS K8V-MX Motherboard
Asus k8v-vm mother board drivers
boot block compatible version ver 003
bad bios checksum, start recovery
is alone window seen in my computer
Dec 26, 2008 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
AMD Sempron 3100+ 1.8GHz 256k Socket 754 CPU Retail (GXCPUS3100) Logo
336 people viewed this question
Top AMD Computers & Internet Experts
David
David
rafnix
rafnix
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
