Question about Olympus Stylus 7030 Digital Camera
When i want to snap with my stylus -7030 it shows me write protect
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 02, 2010
Olympus stylus 7030. No zoom function when using video setting?
The optical zoom will not work while recording video with sound. To use the optical zoom, turn the sound off. See pages 16 and 33 of this manual.
Jan 06, 2013 | Olympus Stylus 7030 Digital Camera
My Olympus Stylus 7030 won't focus and shuts off when I try to zoom.
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jul 29, 2012 | Olympus Stylus 7030 Digital Camera
How to remove the write protect
Write protect on memory card, should be a small slider on memory card to change lock to unlock.
Feb 08, 2012 | Olympus Stylus 7030 Digital Camera
The camera displayed "IN WRITE PROTECT"
Remove the SD memory card and with the contacts up and facing the back, locate the small tab on the right hand edge. Slide it from the LOCK position to the UNLOCK position. Reinsert the card and try again.
Jan 03, 2012 | Olympus Stylus 7030 Digital Camera
I have a Olympus stylus 7030 and I can't get the lens to close, also it isn't charging. It's quite new and I haven't used it much.
You have two choices: take advantage of the warranty or this:
Copy and paste this website into your browser for solutions:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Nov 04, 2011 | Olympus Stylus 7030 Digital Camera
Can I view pictures that i put back on my memory card using my camera or is that pointless? if so, how do i do so? I have an olympus stylus 7030.
Most cameras will not be able to read pictures put on a card by a computer because of the different operating system....in fact, some cameras may even become corrupted by trying such a process. Are you sure you want to take the chance?
May 28, 2011 | Olympus Stylus 7030 Digital Camera
To download application software and instuction manual pdf file
http://www.olympusamerica.com/cpg_section/cpg_support_product.asp?id=1395
Jul 12, 2010 | Olympus Stylus / mju 1050 SW Digital...
Olympus Stylus 7030 Digital Camera Logo
59 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
