Question about Cameras
Flash settings cannot be changed... - Cameras
Check and make sure multi shot or continuous shot is not selected (/BRK button between shutter button and options dial). Flash settings cannot be used with either multi shot or continuous shot, took me forever to figure that out... LOL
Posted on Nov 05, 2010
  • goffin20 Nov 05, 2010
  • Dave Navasquez Oct 09, 2019
    Hi good day
    thanks for the info, It's working .
SOURCE:
How do I set digital watch of UL1159
press MODE button 3 times on left screen DAY will flash press RESET MINUTE will flash, change minute what you want by pressing START.
press again RESET button HOUR will flash press START to change hour.
Press again RESET button DATE will flash change same way.
press again RESET button MONTH will flash change same way.
press again RESET button DAY will flash change same way.
After done press MODE to bring back normal time position.
Changing ALARM ....
press 2 times MODE button. Alarm HOUR will flash press START to set alarm hour.
Press again RESET button Alarm MINUTE will flash press START to change.
After done press MODE to bring back normal position.
SO YOUR TIME & ALARM GET SET. images?q=tbn:and9gctqfaospxemzn5ytb2yvmxsagwhcrw-zhdezmqvoulno244gvhvkgaae8w
Oct 04, 2014 | Kenneth Cole Unlisted Ana-Digi watch
How do you set the clock for manual clock in?
From the manual:
Press the SELECT button and position the cursor at the "TIME". At that moment, the "Hour" flashes. (The flashing means it can be changed.)
Change the "Hour". Press the CHANGE button to set the desired hour. Press the SET button. At that moment, the flashing changes from "Hour" to "Minute"
Change the "Minute". Press the CHANGE button to set the minute. and then press the SET button. At that moment, the "Second" starts to run from "00".
After you finish setting the time, press the SET button once again. Now the time setting has been completed.
Setting the Date
Press the SELECT button and position the cursor mark at the "DATE". At that moment, the "Year" flashes. (The flashing means it can be changed.) Change the "Year". Press the CHANGE button to set the year. Press the "Set" button. At that moment, the flashing changes from "Year" to "Month". Change the "Month". Press the CHANGE button to set the month. Press the "Set" button. At that moment, the flashing changes from "Month" to "Date". Change the "Date". Press the CHANGE button to set the date, and then press the SET button. After you finish setting the date, press the SET button once again. Now the date setting has been completed. Replace the cover.
Feb 28, 2011 | Lathem Time 900E Electronic Recorder,...
I have a Sony Cyber-shot DSC-W90. When I try to change the flash settings, a notification pops up on the screen saying, "Flash settings cannot be changed." I tried setting it in each mode (including Auto)...
Go to Menu/ Home and initialize camera to reset it for factory default settings to fix flash light settings bug.
If problem still not solved, let me know do you see any error code flashing in top right corner of lcd?
Aug 24, 2010 | Sony Cyber-shot DSC-W90 Digital Camera
Flash setting is stuck on "flash off" and wont change
The flash settings don't work in some modes...what mode do you have the camera set to?
Jun 26, 2010 | Casio Exilim EX-S5 Digital Camera
Can't change flash setting in auto mode. (Nikon
Hi Dear,
You cannot change the settings of flash in auto mode. To change the flash settings you need to keep your camera in programmable mode or manual mode so that you can change the flash settings.
Hope this will help you. If you have more queries on the same. Please do write to us again.
Have a nice day.
Nov 11, 2009 | Nikon COOLPIX L4 Digital Camera
Sony cyber shot dsc-t70 unable to change flash setting
The Flash Off setting is fixed and cannot be changed if you are using one of the following modes:
  • High Sensitivity, Twilight or Fireworks Scene Selection
  • Burst or Exposure Bracket REC Mode
If you are using one of the above modes, change the setting to regain flash control.
NOTE: If using Scene Selection modes, the ISO setting is also fixed to ISO AUTO .
Aug 03, 2009 | Sony Cyber-shot DSC-T70 Digital Camera
Flash options for sony camera
I recently had the same frustrating problem. The top of the camera has a little black button that can change from continuous mode or single picture mode. It has to be on single picture mode to change the flash setting. After this is changed you can press the flash setting onthe dial and change the setting. I hope it works for you.
Dec 28, 2008 | Sony Cyber-shot DSC-H7 Digital Camera
SONY DSC-H50 WON'T LET ME CHANGE FLASH SETTINGS ON AUTO ADJ SETTI
Select upper jog dial on Auto (green mark) and have flash options.
you maybe changing desired selections which are preset on that particular selection.
let me know what selections you want to change on what settings?
Dec 24, 2008 | Sony Cameras
My DSC-T100 won't allow any changes to the flash setting.
The flash settings on the Sony Cyber-shot DSC-T100 are Auto, Forced Flash, Slow Syncro and No Flash, if it is not giving you a flash and wont allow you to change the setting you might have to talk to sony or the store you bought the camera from. One long shot would be that depending on what other features you are using on the camera, i could be set up to not allow you to change the flash settings in that "mode". Sorry if this is useless, but good luck and if all else fails use sony support! :)
http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=7
stupid hyperlink not working :(
Nov 21, 2008 | Sony Cyber-shot DSC-T100 Digital Camera
Flash settings Sony DSC-H7
I had the same problem with my DSC-H9. The flash setting is set off when in BURST record mode. Go into MENU, scroll down to REC Mode, change it back to NORMAL.
Now go shoot someone or something... with your camera of course!!
Mar 12, 2008 | Sony Cyber-shot DSC-H7 Digital Camera
Cameras Logo
204 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
