Question about Pioneer CDJ-200 CD Player
Built in a complete new laser unit : VXX2909-S and the disc does not spin up ? Any suggestions ? Yes I removed the solder bridge from the laser :)
  • 24 Answers
1. Check the short-circuit switch for the laser. You might switched it when replaced the laser unit and forgot to switch it back.
2. Check the ribbon of the spindle motor, you might have forgot to connect it.
3. Can you load cds in the unit? When you push a cd in does it accept it? If no, then probably the fuse of all the motors is blown and should be replaced. This is the part: http://www.artaudioparts.com/product/aek7009
Posted on Nov 20, 2013
PS2 Modchip and Laser Fix installation Failure ...
I bough ps2 with cracked after 3-4 days not working dvds are not read.
sometime it's working some dvds..
so plz solve my problem...
May 28, 2012 | Sony PlayStation 2 Slimline Console
Have a Denon DN-C635 CD player . Replaced motor spindle / laser assembly (plug and play part assembly from Denon $45 old price $151) It loads disc , voice coil moves laser lens up and down but spindle...
Dave, Holding the motor spindle / laser assembly in a position where the white ribben plug in receptacle is facing in an upward position, look down to the lower left hand corner of the print board just under the plug in. You will see a small blob of solder bridging two contact points. Remove this solder bridge. I have found two new Denon assemblys with this problem.........*****
Mar 11, 2011 | Denon DN-C635 CD Player
Setting up new CD laser
Any new laser will not require any adjustment, most modern CD players do a self calibration on power up. There is a small dot of solder that must be removed somewhere on the circuit board. You'll see it's shaped like two half circles with a small gap between them which is bridged by solder. Remove this and you should be good to go! You should just be able to touch a soldering iron to it and drag it off. Or you can use a "solder ******" or de-soldering braid.
Oct 09, 2008 | Sony CDP-CE375 5-Disc CD Changer
CDJ 800 Bad Laser
Yes, sounds like you have a bad traverse assembly (laser). You can replace it yourself, however, I wouldn't suggest it, as you need to calibrate the assembly after the installation, and remove a solder bridge (which keeps the unit safe during transport). It is a little complicated, if you don't have experiencing doing this type of work. Taking it to a service center would be your best option.
You can purchase the part HERE
- Davis
DJ PRO AUDIO
www.djproaudio.com
www.repairnyc.com
www.1200s.com
Jul 17, 2008 | Pioneer CDJ-800 Turntable
Spindle probs?
These replacement parts are shipped with a solder bridge to short the laser as a precaution for static electricity. Did you remove the solder bridge once the optics were installed?
Dan
May 20, 2008 | Sony PlayStation 2 Slimline Console
PS2 Slim New Lens, Not Spinning
Hi guys,
Well, there is 2 switch. one at  the back left of the cd tray and one one the reset /power switch. both sitch have to be close in order for the disk to spin.
If you try this dont forget to put a disk on the spindle as you will start the laser. this is for your safety. then, if the disk does not spin, then you can try replacing the laser. or at least verify the ribbon cable that is hook to it. if the ribbon cable is not well inside the plug the laser might move but again the disk won t spin.
it is related to each other, the PS2 seem to verify the laser prior to start the spindle so what ever happend to the laser affect the spindle.
and then, if you buy a new laser lens, don't forget to remove the soldering bridge. it is a small ball that is use to avoid static while shiping the lens.
most of the seller will include a small peace of paper with procedure and also there is web site with picture of this soldering bridge.
I replace some of them, and I have to say that the small plastic lock for the ribbon  cable to the lens has been an issue and the soldering bridge another one.
but I got most of the PS2 back and running by replacing the laser.
I hope this will help you.
Feb 26, 2008 | Sony PlayStation 2 Slimline Console
New Laser
If you replaced the tray yourself, then more than likely you did not remove the solder bridge that the manufacturer puts in place to protect the part from damage in shipping.
Detailed instructions on removed this solder bridge are LOCATED HERE. These instructions apply to both the CDJ800 and the CDJ800MK2 models.
- DJ PRO AUDIO
www.DJPROLAB.com
Feb 15, 2008 | Pioneer CDJ-800 Turntable
No spin
Laser spindle motor. Make sure to get one with the same length shaft - will cost $3 or $4 max and a bit of soldering after removing the drive unit.Or if you can't find one, a new complete laser assembly will have a new spindle motor already fitted - price depends on model of laser.
Jan 27, 2008 | Kenwood CD-403 5-Disc CD Changer
CDJ 800 Bad Laser
Yes, sounds like a damaged reader/tray. This is not an easy fix. Although there is no soldering involved, it's sort of like a car. In order to get to the engine, you have to remove a whole lot of other sections first. Often times when you put it back together, you'll find yourself with some extra pieces you didn't have when you started. With that said, I do not suggest you do this yourself, unless you are completely 100% confident in your ability. Or, get some help.
The part is available HERE - at the cost of $49.99
- TWEAK A/V LAB
Nov 06, 2007 | Pioneer CDJ-800 Turntable
Disk is not spining
Don't bother changing the lens. If i understand you correctly you have damaged the motor or some circuitry leading to it. I hope this helps! good luck on finding a new one, they are abundant right now!
Jul 21, 2007 | Sony PlayStation 2 Slimline Console
Pioneer CDJ-200 CD Player Logo
106 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
