Question about Foxconn 45CMX socket LGA775 motherboard (16897)
MY MOTHERBOARD JUST STARTED MAKING LONG CONTINUOUS BEEPS THAT DO NOT STOP AND HAS NO OUTPUT, I EVEN TRIED CHANGING THE MEMORY AND PROCESSOR
    President:
  • 2,678 Answers
See here
Posted on Sep 01, 2010
Pc chips m825 v 7.2 hit power button get three beeps every 30 seconds no video output changed processors no beeps still no video sounds like the computer isnt even trying to start any ideas??
check if you new processor is compatible for you mother board..if it is compatible, try reinsert the RAm or replaced it with a new RAM...hope it helps you..
Jul 26, 2011 | PC Chips M825G Motherboard
I have a foxconn mobo model g31mv and has a problem with the video, well it shows nothing at all. Ive changed the memory, power supply, jumped the bios and check all the wiring and nothing. So.. what...
Try this motherboard troubleshooting beeping code first.
No beeping means short circuit,loose parts.
One beep means everything is working good.
Two beeps means CMOS error.
One long beeps,two short beeps means video problem
Three long beeps means keyboard error.
Continuous long beeps means memory not detected.
Continuous Hi-Lo beeps means processor overheat,loose blower fan heat sink.
If no beeps need to change capacitor parts of motherboard for burn, short and open leakage.
Jul 16, 2011 | Foxconn G31MV-K Motherboard
My motherboard stop working i remove the memories and switch on then is beeping i change the memory and stop beeping but doesn't work what i do? change the motherboard?
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
a computer needs its connections to continue its cycle and to have and end to function
obvisously the beeps are windows searching for some hardware it could be RAM cd/dvd hard drive or motherboard all of these must have secure connections for the computer to work
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure make sure the connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
May 17, 2011 | HP COMPAQ - 442031-001 Motherboard
Five long beeps at a range of five seconds then, repeats
Five long beeps for a modern motherboards indicates a processor failure. If you wish to remove the processor and re-seat it (reconnect it to see if it begins to work again) make sure to get some thermal compound to put between the CPU chip and the heatsink. More info at: http://www.hardwaresecrets.com/article/How-To-Correctly-Apply-Thermal-Grease/274
POST AMI BIOS beep codes
  • 1 - Memory refresh timer error
  • 2 - Parity error in base memory (first 64 KiB block)
  • 3 - Base memory read/write test error
  • 4 - Mother board timer not operational (check all PSU to MB connectors seated)
  • 5 - Processor failure
  • 6 - 8042 Gate A20 test error (cannot switch to protected mode)
  • 7 - General exception error (processor exception interrupt error)
  • 8 - Display memory error (system video adapter)
  • 9 - AMI BIOS ROM checksum error
  • 10 - CMOS shutdown register read/write error
  • 11 - Cache memory test failed
  • 12 - Mother board does not detect a RAM module (continuous beeping)
Source: Wikipedia
Feb 28, 2011 | Computers & Internet
My computer cannot boot because of long beep
beep code usually means a basic function was unable to start. A basic function might be reading memory, displaying video, or being able to send information to a hard drive. The most common problems that cause beep codes are memory and heat-related failures caused by a build-up of dust in critical cooling areas. Use the beep code tables in this document to help find what hardware component is causing the problem. This might reduce the time required to find the hardware component that needs adjusted, reseated, or replaced. WARNING: HP recommends that these steps be performed only by someone with experience in working on computer hardware. Incorrectly handling sensitive internal components can further damage the computer and can introduce the risk of personal injury. Using the correct environment for working on computers (ESD precautions and tools), use the following steps to isolate and fix the problem:
  1. Turn on the computer.
  2. Listen to the beep code and write it down. Write down the number of beeps before each pause, if the beeps are long, short, high in tone, or low in tone. You can use the other sections in this document to look up the beep code description. The beep code and its description can be used for further Internet research if needed.
  3. Note which fans are spinning, not spinning, or making strange noises. It might be possible to prevent the beep code by setting the fan speed to a higher setting in the BIOS setup utility or by cleaning the cooling fins and vents.
  5. Check the case fan and power cable.
    1. Turn off the computer by holding the power button for five seconds.
    2. Disconnect the power cord and then disconnect all external cords from the computer.
    3. Remove the side panel to open the computer.
    4. If the case fan was not spinning, make sure the case fan power cable is connected to the correct pins on the motherboard. Replace the fan if it was making excessive noise or was not spinning. If you had to plug in or replace the fan, replace the side panel, plug in the power cord and turn on the computer. If the beeps continue, continue to the next step.
  6. Disconnect the power cord and remove the side panel and perform each of the following tasks, in order, until the beeping stops. Before starting each task, unplug the power cord and remove the side panel. After completing a task, replace the side panel, connect the power cord, turn on the computer, and listen for a beep code. NOTE: If removing or disconnecting a hardware component prevents the beep code, that component is probably causing the problem. However, a failed motherboard might produce beep codes associated with a component other than the motherboard.
    1. Clean cooling components that have become clogged with dust. If beeping continues, continue to the next step.
    2. Remove a memory module. If the computer stops beeping, the memory module might be bad, is the wrong type of memory for the motherboard, or was not fully seated or connected. Reinsert the memory into the socket to see if a connection was the problem; otherwise replace the module. Remove each memory module, replacing the one that was previously removed. If beeping continues after checking all the memory modules, continue to the next step.
    3. If the computer has a graphics adapter, remove it. If the beep code changes or continues with the same beep pattern after removing the graphics adapter, the adapter might still be good. Reseat the graphics adapter into its socket and continue to the next step. If the beep code goes away, the graphics adapter might be bad. Try reseating the graphics adapter, making sure it is fully locked into the connector on the motherboard. If problems continue, replace the adapter.
    4. Remove a PCI card. If the beep code goes away, the card might be bad. Try reseating the card into its connector on the motherboard. If problems continue, replace the card. Remove each PCI card, replacing the one that was previously removed. After checking all cards, if beeping continues, continue to the next step.
    5. Disconnect hard drives and CD or DVD drive cables (IDE and ATA) from the motherboard socket. If the beep code goes away, the cable or socket is probably bad. Look for bent pins inside the IDE socket on the motherboard and straighten any bent pins. Try reseating the cables into the connectors. If problems continue, the drive itself might be bad and might need replacing. Disconnect each drive cable, replacing the one that was previously disconnected, until all have been checked. After checking all connections, if beeping continues, continue to the next step.
    6. At this point, the problem is probably the motherboard or processor. Make sure any jumpers on the motherboard have not fallen off their pins and into the case. Make sure jumpers are set correctly. Otherwise, have the computer serviced by HP or by a qualified service center.
Jul 15, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Long beep and continues on power on when moved to
Make sure motherboard don't touch the cabinet.
Reattach the RAM memory.
Open processor fan and processor Then reattach both.
Reattach pci card or vga card if any installed.
Then check.
Let me know if you need further assistance.
Thanks for using FixYa.
Apr 03, 2010 | ECS C51GM-M Motherboard
3 beeps
Please Try this :-
:- Perform each of the following tasks, in order, until the beeping stops. Before starting each task, unplug the power cord and remove the side panel. After completing a task, replace the side panel, connect the power cord, turn on the computer, and ()listen for a beep code. NOTE: If removing or disconnecting a hardware component prevents the beep code, that component is probably causing the problem. However, a failed motherboard might produce beep codes associated with a component other than the motherboard.
Remove a PCI card.
May 12, 2009 | Intel Motherboard
I tried to install a new motherboard but it didn't work
Your bios needed to be set with the correct memory speed on your old motherboard or it did not support the memory you added or it was in the wrong memory slot or size. The beeping was telling you it was a memory error. I need more info such as processor and memory speed and type to help. What is your old motherboard? It sound like Bios settings but I need to make sure the memory and processor will work with *********** board.
Jan 16, 2009 | ASUS P4B266-C (P4B266-C WA) Motherboard
Abit nf8-v keeps beeping when turned on. no video
How is the beep sounds? Long beep and three short beep or one (-...) or all long beep?
For the first, usualy the VGA connector is not correctly seated, so the motherboard can say it has no output device and beeping.
The last is usually memory problem. Try, unplug your memory board and replug it again, make sure that it is correctly seated.
Dec 10, 2008 | Abit NF8-V Pro Motherboard
Narly
  1. Clean cooling components that have become clogged with dust. If beeping persists, continue to the next step.
  2. Remove a memory module. If the PC stops beeping, the memory module may be bad, is the wrong type of memory for the motherboard, or was not fully seated/connected. Try reseating the memory into the socket to see if a connection was the problem, otherwise replace the module. Remove each memory module, replacing the one that was previously removed. Once all modules have been checked, if beeping persists, continue to the next step.
  3. If your computer has a graphics card, remove it. If the beep code changes or continues with the same beep pattern, the video card may still be good. reseat the video card into its socket and continue to the next step. If the beep code goes away, the video card may be bad. Try reseating the video card, making sure it is fully locked into the connector on the motherboard. If problems persist, replace the card.
  4. Remove a PCI card. If the beep code goes away, the card may be bad. Try reseating the card into its connector on the motherboard. If problems persist, replace the card. Remove each PCI card, replacing the one that was previously removed. Once all cards have been checked, if beeping persists, continue to the next step.
  5. Disconnect hard drives and CD/DVD drive cables (IDE/ATA) from the motherboard socket. If the beep code goes away, the cable or socket is probably bad. Look for bent pins inside the IDE socket on the motherboard and straighten any bent pins. Try reseating the cables into the connectors. If problems persist, the drive itself may be bad and may need to be replaced. Disconnect each drive cable, replacing the one that was previously disconnected, until all have been checked. Once all connections have been checked, if beeping persists, continue to the next step.
  6. At this point, the problem probably involves the motherboard or processor. Make sure any jumpers on the motherboard have not fallen off their pins and into the case. Make sure jumpers are set correctly.
Jun 09, 2008 | HP Pavilion 8860 (P2941A) PC Desktop
Foxconn 45CMX socket LGA775 motherboard (16897) Logo
82 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
