Question about Canon PowerShot A540 Digital Camera
Hi this edgard
I have a canon power shot camera and I have a problem.It was working very good 1 year ago,but 4 days ago the display is dark like black color and you can see the fictures and settings and this work when you shot a picture and the flsh works too,but you never can see anything ,i need help from you please.
  • dceccar Jun 06, 2008
    I have a Powershot 560. I dropped it and although it still works, the display is all black but I can see the settings on the edge of the display window.. If I press the reveiw button, the display will show previously taken pictures. Was something damaged when it was dropped, if so, is it worth it to replace it or purchase a new camera?
    Scholar:
  • 46 Answers
Dear Edgar:
It indeed sounds as if your CCD image sensor has gone out. If you call Canon (1-800-828-4040) you can have it repaired at the Factoyr Service Center for somewhere in the neighborhood of between $79 and $99, I believe.
You may also qualify for their upgrade program wherein you can get a refurbished, upgraded model camera, for approximately the same price as the repair. That way you will have a higher model camera , which comes with a complete camera kit, you get to keep you old accessories, and you will have another 6 months worth of warranty, which the upgraded camera carries. All in all it's usually a pretty good deal. Call them and see what's available.
Hope this helps.
Sincerely,
HeavyDLB
Posted on Jun 03, 2008
  • 477 Answers
The camera's CCD is out and it requires replacement cost is about 75.00 plus shipping. goto www.digitalcamrepair.com for contact info.
Posted on Jun 02, 2008
No image is captured by the screen itself (LCD screen works but completely dark).
Did you try pressing the display button several times? in both viewing mode and record mode? Cycle through all display modes, s you get used to the button, so it does not trow you off when it happens again.
Feb 16, 2015 | Canon Cameras
I have 2 Canon Power Shot 70 cameras (one was a gift) The oldest I have owned for approximately 4 years...the other one slightly less. About one year ago while on vacation, the camera refused to take...
Yes it is a design flaw, basically what happend is the image interpereter and preprocessor are shot.. The integrated method of the design leaves the irrepirable.. I dont use canon products except for printers and scanners when it comes to camera's i use Hp or Pioneer, Consumer support suggested a new camera cause they know where they messed up
Jul 14, 2008 | Canon Cameras
Canon power shot sd1000 black dot on lens
If by saying the upper right corner of the lens you really mean that there is a dark spot on each image AND the rear display, there may be dirt or dust on the lens itself. Clean the lens with an optical quality cleaner. Do not use paper towels and Windex or the like - as paper towels can scratch the lens.
It is also possible that the dark spot is a "stuck pixel" on the image sensor inside the camera. There is no way to repair a stuck pixel outside of replacing the sensor. Any dark spot (regardless of source) can be edited out by using image editing software. This will allow you to to make the dark spot less noticeable - or practically invisible.
If the dark spot is on the rear display only, it can also be a result of a "stuck pixel" on the display itself. This should not show up an images, but only on the display. There is little that can be done outside of replacing the entire rear screen.
There are other things that can cause these problems, but those listed above are the most common.
I hope this was Very Helpful and good luck!
Nov 20, 2009 | Canon PowerShot SD1000 Digital Camera
Canon A630 lens error and black photos
hi u need to get the lens repaired the railing in the lessystem is no correct so pleas dont try to doit or push in .... it will be permanent damage ....get to the shot5 the camera is not broken need small fix....
Aug 30, 2009 | Canon PowerShot A630 Digital Camera
Canon A520 powershot camera - the display panel is dark
Use a memory card and memory card reader. If the images come out black you have a bad CCD in your camera.
Jul 03, 2009 | Canon PowerShot A520 Digital Camera
Black pictures when using flash
The black images with flash mean that the Iris mechanism in the lens is not working properly, and that needs a professional camera repair service.
Best regards,
Oct 19, 2008 | Canon PowerShot S2 IS Digital Camera
Geeting White Picture from Canon Shot shot s1 power shot camera
The pictures are over exposed. did you put the iso on max? Is the exposure correction set to the max?
Feb 04, 2008 | Canon Cameras
Light Metering Problem on Canon A80
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Dec 10, 2007 | Canon PowerShot A80 Digital Camera
Elura has gone dark
Call 1-800-828-4040.....there is a defective chip that needs to be replaced and Canon will fix it for free. They even sent me free shipping lables as well....
Dec 10, 2007 | Canon MV6iMC Mini DV Digital Camcorder
Canon PowerShot A540 Digital Camera Logo
47 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
