Question about Olympus SP-550 UZ Digital Camera
Olympus SP- 550 UZ , Model number Sp -550 UZ, L 08208054 UO 18x optical zoom - 28mm wide, Digital Camera DC 6V As soon as the power button is pressed, the screen lights up the lens comes out with a message "Zoom Error" and the lens immediately goes back into the camera. I can also hear light clicking sound as the lens goes back into the camera. This problem has been going on occasionally and then I could see the object to be photographed. Now for the last few days I am unable to take any pictures because of the constant message.
  • 919 Answers
SOURCE: I can't figure out how
On page 31 of your user manual describes how to enable the microphone on so you can have sound during movie clips.
Posted on Dec 17, 2008
  • 919 Answers
SOURCE: Zoom Error message
The problem you are describing is a problem with a sensor in the lens assembly of the camera. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $167.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Posted on Apr 29, 2009
SOURCE: can i use the olympus sp-550 UZ as a web cam?
It is not possible to use this as a webcam as the camera is not capable of sending streaming data over the data cable rpovided with it and also the software rpovided with it (drivers) is not programmed for the camera to be used as webcam.
Posted on Aug 12, 2009
  • 11967 Answers
SOURCE: My Olympus SP-550UZ 18x optical zoom has a
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 29, 2009
  • 11967 Answers
SOURCE: Zoom Error with my Olympus SP-550uz
Posted on Jan 04, 2010
An error information shows up: ZOOM ERROR
You need to send the camera back to Olympus for proper diagnostics and service sounds like there is a electronic fault in the lens zoom assembly which will most likely need to be replaced
Jan 10, 2016 | Olympus SP-550 UZ Digital Camera
Need free instructions for Olympus digital camera D-550 Zoom 3.0
You can get the user manual for this unit from this link, just click HERE.
Oct 18, 2011 | Olympus SP-550 UZ Digital Camera
Hi Ive got an Olympus SP-550UZ digital Camera
Hello
Thank you for using FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty. "Zoom error" is repairable
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Feb 21, 2010 | Olympus SP-550 UZ Digital Camera
Can i use the olympus sp-550 UZ as a web cam?
Aug 12, 2009 | Olympus SP-550 UZ Digital Camera
Broken Zoom on Olympus sp-510
Unfortunately this is a repair issue with the camera. You may want to call Olympus Customer Service to discuss their repair policy and procedures. Their telephone number is 800-622-6372 option 2 and then option 3.
Jan 02, 2009 | Olympus SP-510 UZ Digital Camera
Zoom error
reset camera but it would appear that the lens is not functioning properly and would need repair
Sep 06, 2008 | Olympus SP-550 UZ Digital Camera
Conversion of LCD
Unfortunately such conversion is not possible. If the "vari angle" screen is an essential your best approach would be to dispose of the SP 550 UZ and buy another camera meeting your need. Sorry!
Mar 25, 2008 | Olympus SP-550 UZ Digital Camera
Raw picture on olympus sp 550 uz
Assuming your SP 550 UZ is similar to the 510 UZ "RAW Mode" is not available in "Auto" or any of the "Scene" modes. If you set your camera to "P" and then access the Image Quality item in the Menu RAW is available as an option.
Hope this helps.
Mar 02, 2008 | Olympus SP-550 UZ Digital Camera
Olympus Camera
if you go to the olympusamerica.com/store you will see the telephoto lens but you will need the cla-10 adapter to use it with your camera
although you do get more telephoto with it... you can turn the digital zoom on in the camera and go to 90+ times zoom
Jan 28, 2008 | Olympus SP-550 UZ Digital Camera
Olympus SP-550 UZ Digital Camera Logo
96 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
