Question about Hayward SAND FILTER, PRO SERIES
Started filter yesterday for 4 hours and then shut it off. do i need to do anything different when i restart it today?
    Problem Solver:
  • 10 Answers
No just turn it on pumps and filters are sized to turn over the pool volume in 6 hours so install a flow meter or just let the pump run for 6 hours to be safe
Posted on Sep 01, 2010
Testimonial: "thanks."
I bought a new one yesterday , loaded all my docs and today it is not being recognized by my computer whats going wrong ? need your help
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Dec 27, 2010 | Iomega Prestige 1 TB USB 20 Hard Drive
I have a 1997 Audi A4 1.8L Quattro that randomly shuts off after about 5-15 minutes of driving. It also shuts off even if its on park. It has some trouble restarting, but after a few tries it succesfully...
THE NEXT STEP IS ,( WHEN IT DOES NOT START), CHECK TO SEE IF IT IS : NO-SPARK, OR NO-FUEL CONDITION THIS WILL LEAD YOU TO THE NEXT STEP. YOU MUST HAVE THREE THINGS TO RUN. SPARK, FUEL & COMPRESSION. HOPE THIS HELPS MOTOR62500..
Dec 24, 2010 | 1996 Audi A4
My dryer starts the first time with no problem, but after about an hour it starts to make a kind of buzzing sound. If I don't shut it off at this point it shuts itself off after another minute or two....
You are absolutely correct that the motor is the problem and needs to be replaced. The motor is overheating and its thermal overload protector trips off causing the dryer to shut down. Thermal overload protector resets and allows the motor to run again only when it has cooled down. It is the reason why the dryer is not turning on immediately after it shuts off. Replacing the motor will definitely solve the problem.
Aug 11, 2010 | Maytag Dryers
The car was running started to stall shut off,then it would restart.shut off a couple of times last night but would restart.today it stalled and wont start at all cranks over fine but no attempt to fire?
Your fuel filter may have gotten to the end of it's life and needs to be replaced. Start with the simple and replace the fuel filter, a dirty fuel filter will not set the check engine light to come on, at worst it's a weak fuel pump and that may need to be replace. Good luck and thank you for using Fixya.
Mar 06, 2010 | 1996 Chevrolet Corvette
Screen is all white
the display screen is faulty have an expert change it for you
Nov 07, 2009 | Computers & Internet
2001 Chevy Blazer blower motor not working
It keeps burning out blower resistors because of the blower motor drawing to much amperage so you will need to replace the resistor and blower motor
Jun 27, 2009 | 1988 Chrysler Fifth Avenue
91 vw golf will not stay running after 15 minutes
You are losing oil pressure, this means your oil pump is probably out. Don't drive it anymore until you can get that repaired. It's shutting down because it's siezing up. You need the extra power to jump it because the piston rings and wall are sticking together, let it all cool down and the rings contract and loosens up. Allowing the engine to turn.
Apr 24, 2009 | 1991 Volkswagen Golf
My phone keeps freezing and restarting
Try pulling out your memory card if you have one. i had the same problem and come to find out my memory card must have come loose from dropping the phone. It's working fine ever since I took i out and put it back in. Good Luck.
Jun 23, 2008 | LG enV VX9900 Cellular Phone
Hayward SAND FILTER, PRO SERIES Logo
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
