Question about HP Compaq Presario V2000 Notebook
Internet connection how do i connect a computer from 2000 to a netgear modem to get internet
  • Mark Gil
    Mark Gil May 11, 2010
    Can you connect your laptop to the modem using a Ethernet cable?
    Sergeant:
  • 458 Answers
You get an Ethernet cable and plug it into your computer and plug the other end to the router. It does not matter what operating system you use.
With Windows 2000 there is a trick to make it recognize the router. Go to start - run - type - ipconfig - then you should get a command prompt. If you do not get a command prompt you will have to open up a Dos screen and type it in. After you get to ipconfig you will have to put in ipconfig / release. This will release the IP. Then you put in the next line - ipconfig / renew. That should do what you need to get onto the network. If this does not work. Try resetting your router by unplugging it and plugging it back in after about a minute then doing the steps over again. If this does not work you might have a bad router,network card, or cable. Let me know if this does not work and I will try to help you more.
If this does help, please rate this a fixed question so I will get the rating. Thanks. The ratings help me to help you.
Posted on Jun 04, 2008
Brighthouse internet modem
This is the page you want, connecting the modem and the router needs to be done through the WAN/Internet Ethernet port.
http://support.brighthouse.com/Article/Connect-Computer-Router-6628/?searchid=321247&pos=1
Oct 05, 2013 | NetGear Computers & Internet
How to connect to the internet
Connect the computer directly to the modem and make sure that Internet is working through the modem.
Connect the modem and computer to the router with the Ethernet cable.
Open the setup page of the router and change the settings manually. So that your computer can access Internet through the router.
You can this website to know how to connect to the Internet using NETGEAR router.
May 21, 2012 | NetGear WGR614 Wireless Router
Router problem. unable to connect wirelessly
This is usually up address conflict. You will have to assign the wifi or lap top to different IP addresses. You have to refer to the modem manufacturers instructions or search on net / YouTube how to do this. It's too detailed to do it here I think.
Oct 17, 2017 | NetGear WGR614 Wireless Router
Followed all the set up steps but my DSL light would not stay on
  • 1 Plug the Ethernet cable into the Internet port on your wall. If you do not have Internet ports installed in your home, connect a phone line adapter to a phone line jack. The adapter makes the phone line wider so Ethernet cables can connect to it. This does not block your phone from use.
  • 2 Plug the other end of the Ethernet cable into the Internet port on the back side of the Netgear DSL modem.
  • 3 Connect the Netgear DSL modem to a local power source. The power plug inserts into the modem via a small port on the rear of the modem.
  • 4 Insert a second Ethernet cable into one of the numbered ports on the back of the modem. Run the cable to your computer and plug it into the Ethernet port on the computer.
  • 5 Look on the back end of the DSL modem for an HTTP: address. Type this into your Internet browser's search bar. The Netgear DSL modem menu appears on the screen.
  • 6 Select how many computers are to use the modem, if you are using it with other DSL modems and set up a password (the default username and password is "admin"). Click "OK" to initiate the changes you made to the menu. You can now use your Netgear DSL modem to connect to the Internet.
  • Read more: How to Install a Netgear DSL Modem ' eHow.com http://www.ehow.com/how_5886784_install-netgear-dsl-modem.html#ixzz10lH4dl2y
    Sep 27, 2010 | NetGear DGN2000 Wireless Router
    PS3 and Netgear WGR614 V7 Router
    Basically the PS3 wireless settings needs to be configures with the Netgear wireless router settings.
    To test if the modem is connects to the Internet, connect a computer into the modem, if it works then the modem is configured correctly. If it doesn't work, then contact your ISP and get them to test your modem connection.
    For details on how to configure the PS3 click on the WEB link :-
    wii.php">http://fixhomenetwork.com/xbox-play-station-wii.php
    Dec 20, 2009 | NetGear WGR614 Wireless Router
    How to connect Netgear to Time Warner internet modem? I have Netgear installed on my computer, and I have the internet modem plugged in to my computer.
    Just disconnect the ethernet cable from the computer and put it into the slot called internet on the router then run ehernet cable from port 1 to computer.
    Dec 05, 2009 | NetGear WGR614 Router
    Could not make router to work, Netgear modem adding router.
    i suppose you have to connect modem to router's "source" socket and modem to socket "in wall" then reset and reconfig router and you should be ok
    Nov 10, 2009 | NetGear WGR614 Wireless Router
    Can't connect to netgear wnr 2000
    conect to netgear then shut down and turn it back on.
    May 27, 2009 | Acer TravelMate 5520 Notebook
    My Roadrunner Modem works fine when connected to an individual computer. When connected through my netgear modem I cannot get an internet connection on any computer wired directly to the router
    does the modem worked fine with ANY computer connected directly to it, or just ONE computer connected to it?
    did you have to install a connection program on one of your computers when you first installed the modem?
    do you have an account name and password from your internet service provider, which is required to connect?
    Mar 24, 2008 | NetGear WGR614 Router
    HP Compaq Presario V2000 Notebook Logo
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
