Whitch way do the washers go - Heating & Cooling
  • 107 Answers
Washers when looking real close have a sharper edge on one side than the other.. the rounded edge would face up and the sharper edge would face down
Posted on Sep 01, 2010
How do i know what # fuse control the washer motor on my 2009 ford ecape
Usually the cover has fuse information on the inside. Otherwise, the owner's manual. or check all fuses to see if they are "blown".
Google for a picture of the fuse box with fuse positions identified
Feb 14, 2015 | 2009 Ford Escape
Reversing lights not working
Check your owners manual. AutoZone has free repair manuals online.
May 19, 2013 | Cars & Trucks
Whitch slot to use on camshaft on suzuki carry
Do you mean timing the engine up and the slot on the back of the camshaft ?? by any chance
Jan 31, 2012 | Cars & Trucks
Hi. I have a Briggs & Stratton 2800PSI gas pressure washer. I can get it to start, but after about 5 min, then it quits. I have cleaned the carb, change oil, changed plug, new gas, cleaned/checked...
if it wont start, check for spark.how you do that,ok take the spark plug wire out put it close to the sparkplug(use some gloves or something to insulate your self from get electric shot from the spark) find some one who pull the start rope, if you dont see any spark between wire and spark plug, tehre its not spark ,it will never start.you will have to remove the start recoil on the botton is like a damper whitch will have to be remove also ,on botton of it its like a coil whitch with the rotation of the damper when you pull the starter rope provoke the spark and send it to spark plug along with the gas combution get the engine started.that coil some time goes bad and have to be change.if you have electric starter. check the starter also.good luck
May 30, 2011 | Briggs & Stratton Prosumer 20324 Gas...
Water level dont get high
the over fill velve is not working right,,,it may be just a slightly blocked pipe up to this velve,,,there is a small pipe from the bottom of the tub leading to the over fill velve whitch has lots of whiers coming from it pop this pipe off and with good lungs you should be able to blow through it to clear it out,,
Jun 08, 2010 | Frigidaire ATF6000ES Front Load Washer
I need to find out how to set up the camshaft on a Toyota cressida GLI 6
the camshaft (ohcs) it should have a keyway whitch fits only one way into the timing gear then line up the timing marks
Apr 09, 2010 | Whirlpool LSB6200KQ Top Load Washer
Where's the o2 sensor bank 1 on a 1999 suzuki grand vitara
O2 sensor is located on your exhaust around the catalytic converters
Aug 15, 2009 | 1999 Suzuki Grand Vitara
Kenmore 80 series
more than likely the dogs inside the agitator are bad
there are two different sets 1 set has 4 white ones part number is 285770 the 2 dog set whitch are red part number is 358692
replace these and it will fix your problem
Apr 11, 2008 | Kenmore 24032\24036 Top Load Washer
Washer discharges water so forcefully, it is backing up. Hose has been changed, and there is air around the standpipe. The drain appears clear as a water flows with a hose at full force. The clean out...
if the home drain pipe is larger than the washer drain pipe and water is backing up the house stand pipe, the issue is in the house not the washe, you cannot cut down the amount of water that the washer discharges during the pump out cycle, doing so will void your warranty and cause problems with the pump, whitch now are mostly electric and can not stand any backpressure on them
Apr 09, 2008 | Washing Machines
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
